SU1500RTXL2UN
SU1500RTXL2UN
    TRIPPLITE
    UPS SMART ONLINE RACKMOUNT
SU1500RTXL2UN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 120V 1.5kVA 1.2kW DoubleConversion UPS, 2U Rack/Tower, Extended Run, Pre-installed WEBCARDLX Network Interface, USB, DB9 Serial MODEL NUMBER: SU1500RTXL2UN Highlights ● 1500VA / 1.5kVA / 1200 watt on-line double-conversion 2U rack/tower UPS ● 120V +/-2% output at 50/60Hz, High 95% efficiency economy mode option ● Expandable runtime, Hot-swap batteries; 19 in / 48.3cm installed depth ● USB, RS232, EPO and preinstalled WEBCARDLX Network Interface ● Front panel status LEDs with detailed load and battery metering ● 2 independently switchable output load banks ● NEMA 5-15P input; 5-15R outlets ● To enable the Auto Probe feature, this product requires LX firmware update 15.5.2 or later to be installed Package Includes Description Tripp Lite Smart Online UPS systems offer high performance power protection ideal for critical server and network equipment in datacenters, computer rooms and network closets. Online, double-conversion Uninterruptible Power Supply (UPS) maintains perfectly regulated output power by continuously converting raw AC input to DC, then re-converting output back to AC. Fully regulated sine wave AC output with +/-2% voltage regulation powers network equipment continuously, even during severe brownouts and overvoltages, all without depleting UPS battery reserves. Maintains battery-derived AC output during power failures with zero transfer time. Extended runtime options available. High 95% efficient operation in optional economy mode saves BTU heat output and energy costs. Network management interfaces support communications via USB port, DB9 serial port and pre-installed WEBCARDLX network management interface card. The Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities. Protocols supported include HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and NTP. Built-in DB9 port offers both enhanced RS-232 data and basic contact closure monitoring ability. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. PowerAlert UPS monitoring software is available via free download. Emergency Power Off (EPO) interface. LED display reports UPS operating mode, line power availability, battery mode operation, inverter operation and output power availability. Audible alarm with push-button momentary alarm-cancel. Programmable self-test. Fault-tolerant auto-bypass mode. Field-replaceable, hot-swappable internal batteries and external battery packs. Features ● Tripp Lite SU1500RTXL2UN 1500VA / 1.5kVA / 1200W on-line, double-conversion 2U rackmount UPS ● 120V output (120V factory preset) ● NEMA 5-15P input, 6 NEMA 5-15R ● Two switched load banks support remote reboot or programmable load shedding options ● Supports 2% output voltage regulation and zero transfer time in double conversion mode ● Economy mode option offers enhanced 95% efficiency operation, reduced power consumption and 1/7 ● SU1500RTXL2UN UPS with Pre-installed Network Management Card interface ● USB, DB9 & EPO Cables ● Mounting hardware for 4 post rack enclosures ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States lower BTU emissions ● 14 minutes runtime at 50% load (600W) and 5 minutes at 100% load (1200W) with internal batteries ● BP48V24-2U (limit 1), BP48V60RT-3U (multi-pack compatible) and BP48V27-2US (multi-pack compatible) external battery packs available (some configurations require Tripp Lite's External Battery Configuration Software) ● Intelligent battery management system extends battery life ● LED Display reports UPS operating mode, line power availability, battery mode operation, inverter status and output power availability ● Audible alarm with push-button momentary alarm-cancel ● 4 post installation hardware included, Optional 2POSTRMKITWM enables 2 post rack installation ● Single line TEL / Network surge suppression ● Electronic bypass maintains utility output during a variety of UPS fault conditions ● Network interfaces support communications via built-in USB, DB9 serial / contact-closure and preinstalled WEBCARDLX network management card ● WEBCARDLX interface allows full remote access for power monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH ● Optional E2 sensors enable site monitoring of temperature, humidity and contact-closure status ● Reduce Service Calls with Auto Probe Autonomous Device Management. Auto Probe feature (Firmware 15.5.2 and greater) of the LX Platform Interface checks the connectivity status of any networked device and automatically takes one or more user-configured actions if the device fails to respond; actions include outlet reboot, set SNMP traps, SNMP OID sets, and even script execution when used in conjunction with the Tripp Lite PowerAlert Network Shutdown Agent (PANSA) ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert Specifications OVERVIEW UPC Code 037332181473 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1200 Output Capacity (kW) 1.2 Output Capacity Details OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150% load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits) Power Factor 0.8 Crest Factor 3:1 Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Load Management Receptacles Two switchable 5-15R load banks (bank 1 - two outlets, bank 2 - four outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5 min. (1200W) Runtime Half Load (min.) 14 min. (600W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 80% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 150 Undervoltage Correction 2% output voltage regulation during undervoltages to 80 Severe Undervoltage Correction 2% output voltage regulation during undervoltages to 65 (under 70% load only) USER INTERFACE, ALERTS & CONTROLS Switches 2 switches control off/on power status and alarm-cancel/self-test operation. LX Platform Interface: Recessed reset switch for interface reboot and factory reset Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators 14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in rack/tower formats. Network Link/Activity (Green): Flashes for network activity. Network Speed (Yellow): 10 Mbps (Flashing), 100 Mbps (On steady). LX Platform Interface Status: Normal Operation (Solid Green); Software Update (Alternating Green/Orange ~1/sec); Factory Reset (Alternating Green/Orange ~2/sec). SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 600 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 55.88 Minimum Required Rack Depth (inches) 22 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth with External Battery Pack (cm) 66 Minimum Required Rack Depth with External Battery Pack (in.) 26 Minimum Required Rack Depth without External Battery Pack (cm) 56 Minimum Required Rack Depth without External Battery Pack (in.) 22 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 483 Primary UPS Height (mm) 89 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 9.10 x 20.00 x 23.40 Shipping Dimensions (hwd / cm) 23.11 x 50.80 x 59.44 Shipping Weight (lbs.) 58.00 Shipping Weight (kg) 26.31 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.89 x 44.45 x 48.26 UPS Power Module Dimensions (hwd, in.) 3.5 x 17.5 x 19 UPS Power Module Weight (kg) 20.00 UPS Power Module Weight (lbs.) 44.1 Unit Weight (lbs.) 45.2000 Unit Weight (kg) 20.50 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 612 AC Economy Mode BTU / Hr. (Full Load) 216 Battery Mode BTU / Hr. (Full Load) 667 AC Economy Mode Efficiency Rating (100% Load) 95% 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS Network Management Cards  WEBCARDLX  Network Monitoring Port Description Includes pre-installed WEBCARDLX Network Management Card; DB9 port supports RS232 and contact closure communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable connection OR installed Network Management Card PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications EPO Port RJ11 interface jack with 4-meter cable included. Supports normally open and normally closed EPO systems Network Management Card Description Network management card included Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 80V (100% load), 65V (
SU1500RTXL2UN
物料型号:SU1500RTXL2UN 器件简介:SmartOnline UPS系统提供高性能电源保护,适用于数据中心、计算机房和网络设备室中的关键服务器和网络设备。
在线双转换不间断电源(UPS)通过持续将原始交流输入转换为直流,然后重新转换为交流输出,从而维持完美调节的输出功率。
引脚分配:NEMA 5-15P输入,6个NEMA 5-15R输出 参数特性:1500VA/1.5kVA/1200W在线双转换2U机架式UPS,120V输出(出厂预设),支持2%的输出电压调节和双转换模式下的零转换时间。
经济模式选项提供95%的高效率运行,降低功耗和BTU排放。
功能详解:提供在线双转换电源调节,过压和欠压校正,用户界面、警报和控制,浪涌/噪声抑制,物理特性,环境参数,通讯功能,以及高可用性UPS特性。
应用信息:适用于关键任务应用。
封装信息:2U机架式安装,支持4柱19英寸机架安装,也支持2柱机架安装(需选购配件)。
SU1500RTXL2UN 价格&库存
很抱歉,暂时无法提供与“SU1500RTXL2UN”相匹配的价格&库存,您可以联系我们找货
