SMART1500RMXLN
SMART1500RMXLN
    TRIPPLITE
    UPS SMART LCD RACKMOUNT AVR
SMART1500RMXLN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1.5kVA 1.35kW Line-Interactive Sine Wave UPS, 2U Rack/Tower, Extended Run, WEBCARDLX Network Interface, LCD MODEL NUMBER: SMART1500RMXLN Highlights ● Corrects under- and overvoltages from 83V to 145V ● 8 NEMA 5-15R outlets—4 switchable via network interface ● Pre-installed WEBCARDLX network interface ● Expandable runtime with optional external battery packs ● 14 min. runtime at half load; 4.9 min. at full load ● To enable the Auto Probe feature, this product requires LX firmware update 15.5.2 or later to be installed Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Pre-installed WEBCARDLX network interface permits remote UPS management, including reboots. Description The SMART1500RMXLN SmartPro 120V 1.5kVA 1.35kW Line-Interactive Sine Wave UPS provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up servers and network storage devices, the SMART1500RMXLN switches to battery mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Featuring eight NEMA 5-15R outlets (four switchable) and a 10-ft. (3.05 m) power cord with 120V NEMA 5-15P input, the SMART1500RMXLN has an internal battery that provides 14 minutes of support at half load and 4.9 minutes at full load. Adding external battery packs, such as Tripp Lite's BP36V15-2U (sold separately), provides extended runtime. The Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities. Protocols supported include HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and NTP. Automatic voltage regulation (AVR) maintains 120V nominal output over an input range of 83V to 145V without using battery power. A 570-joule surge suppression rating protects your equipment from harmful power surges. Features Protects Mission-Critical Rack-Mounted Equipment ● Provides fully regulated sine wave AC output for servers, network storage devices and telecom hardware ● Audible alarm signals loss of utility power, overload, low battery and fault conditions ● 10-ft. (3.05 m) power cord with 120V NEMA 5-15P input ● 0.9 power factor rating ● 570-joule surge suppression rating 1/7 ● SMART1500RMXLN SmartPro 120V 1.5kVA 1.35kW LineInteractive Sine Wave UPS ● Pre-installed WEBCARDLX network interface ● USB cable ● DB9 cable ● EPO cable ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Reliable Battery Backup with Expandable Runtime ● Supports half load up to 14 min. and full load up to 4.9 min. ● Internal batteries designed for hot-swap field replacement ● 95% line-power efficiency rating saves money in energy costs ● Expandable runtime with optional external battery packs, such as Tripp Lite's BP36V15-2U Pre-Installed WEBCARDLX Network Interface ● Allows full remote access for power monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH ● Optional EnviroSense2 sensors (sold separately) enable site monitoring of temperature, humidity and contact-closure status Reduce Service Calls with Auto Probe Autonomous Device Management ● Auto Probe feature (Firmware 15.5.2 and greater) of the LX Platform Interface checks the connectivity status of any networked device and automatically takes one or more user-configured actions if the device fails to respond; actions include outlet reboot, set SNMP traps, SNMP OID sets, and even script execution when used in conjunction with the Tripp Lite PowerAlert Network Shutdown Agent (PANSA) 8 NEMA 5-15R Outlets in 2 Load Banks ● 4 outlets are switchable to remotely reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR) ● Maintains 120V nominal output over input range of 83V-145V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment's performance Interactive LCD Screen ● Front-panel LCD signals operating mode, load level, voltage, battery charge and estimated runtimes ● Rotates for easy viewing in rack-mount or tower configurations Communications Ports ● USB and DB9 ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software (available via free download from tripplite.eaton.com/products/power-alert) ● EPO port supports emergency shutdown in large facilities Versatile Installation Options ● Hardware included for 4-post mounting in 2U of EIA-standard 19 in. rack ● Mounts on wall or 2-post rack with optional 2POSTRMKITWM accessory ● Mounts in upright tower position with optional 2-9USTAND accessory Specifications OVERVIEW UPC Code 037332178022 UPS Type Line-Interactive 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1350 Output Capacity (kW) 1.35 Output Capacity Details Output is reduced to 1200 watts maximum when used with external battery packs Power Factor 0.9 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -14%, +6% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.9 min. (1350W) Runtime Half Load (min.) 14 min. (675W) Expandable Runtime Yes 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States External Battery Pack Compatibility  BP36V15-2U  (limit 1);  BP36V42-3U  (multi-pack compatible);  BP36V27-2US  (multi-pack compatible) DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC93-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 145 Overvoltage Correction Input voltages between 127 and 145 are reduced by 12% Undervoltage Correction Input voltages between 95 and 108 are boosted by 12% Severe Undervoltage Correction Input voltages between 83 and 94 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) Switches 3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions. LX Platform Interface: Recessed reset switch for interface reboot and factory reset Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators Network Link/Activity (Green): Flashes for network activity. Network Speed (Yellow): 10 Mbps (Flashing), 100 Mbps (On steady). LX Platform Interface Status: Normal Operation (Solid Green); Software Update (Alternating Green/Orange ~1/sec); Factory Reset (Alternating Green/Orange ~2/sec). SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 43.18 Minimum Required Rack Depth (inches) 17 Minimum Required Rack Depth with External Battery Pack (cm) 51 Minimum Required Rack Depth with External Battery Pack (in.) 20 Minimum Required Rack Depth without External Battery Pack (cm) 42 Minimum Required Rack Depth without External Battery Pack (in.) 16.5 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 342 Primary UPS Height (mm) 88 Primary UPS Width (mm) 439 Shipping Dimensions (hwd / in.) 8.80 x 18.90 x 23.30 Shipping Dimensions (hwd / cm) 22.35 x 48.01 x 59.18 Shipping Weight (lbs.) 55.20 Shipping Weight (kg) 25.04 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.76 x 43.94 x 34.16 UPS Power Module Dimensions (hwd, in.) 3.45 x 17.3 x 13.45 UPS Power Module Weight (kg) 21.09 UPS Power Module Weight (lbs.) 46.5 Unit Weight (lbs.) 46.5000 Unit Weight (kg) 21.09 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 237 Battery Mode BTU / Hr. (Full Load) 751 AC Mode Efficiency Rating (100% Load) 95% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards  WEBCARDLX  Network Monitoring Port Description Includes Pre-installed WEBCARDLX Network Management Card interface PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable Micro-USB, USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications EPO Port RJ11 interface jack with 4-meter cable included. Supports normally open and normally closed EPO systems SNMP Compatibility SNMP V1, V2c, V3 Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management card included Communications Interface DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4 milliseconds (AC to battery mode), 1 millisecond (Battery to AC mode) Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (included); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug 6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
SMART1500RMXLN 价格&库存
很抱歉,暂时无法提供与“SMART1500RMXLN”相匹配的价格&库存,您可以联系我们找货
