SU2200XLA
SU2200XLA
    TRIPPLITE
    UPS SMART ONLINE
SU2200XLA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 120V 2.2kVA 1.6kW DoubleConversion UPS, Tower, Extended Run, Network Card Options, USB, DB9 Highlights ● 2200VA / 2.2kVA / 1600 watt on-line double-conversion tower UPS ● 120V +/-2% output at 50/60Hz, high efficiency economy mode option ● Expandable runtime, Hotswappable battery modules ● USB, RS232 & EPO ports; network management card options ● Front panel status LEDs with detailed load and battery metering ● 2 independently switchable output load banks ● NEMA 5-20P input; L5-20R & 515/20R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SU2200XLA Package Includes Description Tripp Lite's Smart Online SU2200XLa on-line, double conversion UPS protects critical server, networking or telecommunications equipment from blackouts, brownouts, voltage fluctuations and surges in an attractive all-black upright tower form factor. Large capacity 2200VA/1600W UPS continuously converts incoming AC to DC, then back to perfect sine wave AC output at 120V AC (+/-2%). Removes harmonic distortion, fast electrical impulses, frequency fluctuations and other hard-to-solve power problems not addressed by other UPS systems. True sine wave output and zero transfer time offers guaranteed compatibility with all equipment types. Includes 7 UPS supported outlets. 2 three-outlet load banks can be independently controlled via software interface to selectively reboot remote equipment or automatically shed less critical loads to extend battery runtime for the most critical equipment. Battery support can be extended with the addition of external battery packs. Includes slot for network management card options, plus DB9 enhanced serial monitoring port for unattended shutdown, remote control and monitoring of UPS system and power data. Network management interfaces support simultaneous communications via USB port, DB9 serial port and slot for network management card options. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Tripp Lite's PowerAlert UPS Management Software is available via free download. Compatible with Tripp Lite's Watchdog Service Monitoring and Control Software. Features ● True on-line, double conversion UPS provides a constant, pure sine wave AC output ● Maintains continuous operation through blackouts, brownouts, voltage fluctuations and surges with zero transfer time ● Zero transfer time, on-line, double-conversion and economy-mode operation supported ● Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power problems ● Accepts input voltages between 80V and 150V (65V to 150V at loads under 70%), regulating output to 120V AC +/-2% ● 2200VA/1600W output capacity with 7 total outlets (6 NEMA5-15/20R and 1 L5-20R) ● Two built-in individually switchable load banks, each with three outets, can be controlled via software interface to selectively reboot remote equipment or automatically shed less critical loads to extend battery runtime for the most critical equipment ● Standard internal battery set provides 14 min. runtime at half load and 4.5 min. at full load 1/6 ● SU2200XLa On-line DoubleConversion UPS System ● USB, DB9 and USB cables ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Runtime is expandable with BP48V60RT-3U and BP48V27-2US external battery packs ● Intelligent battery management system extends battery life ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration software (see manual) ● Attractive all-black upright tower format ● Simultaneous communications via HID-compliant USB port, serial port, and SNMP/web card slot ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● DB9 serial network interface supports RS-232 and contact closure messaging ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● Compatible with Tripp Lite's WatchDog Service Monitoring and Control Software (part# WATCHDOGSW) ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Diagnostic LEDs ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications OVERVIEW UPC Code 037332126566 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 16A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-20P Input Circuit Breakers 30A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 20A 120V OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1600 Output Capacity (kW) 1.6 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity Details OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150% load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits) Power Factor 0.7 Crest Factor 3:1 Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Load Management Receptacles Two switchable three-outlet 5-15/20R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15/20R; (1) L5-20R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (1600W) Runtime Half Load (min.) 14 min. (800W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V27-2US  (multi-pack compatible);  BP48V60RT-3U  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 6 hours to 80% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC48-SUTWR  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 150 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Undervoltage Correction 2% output voltage regulation during undervoltages to 80 Severe Undervoltage Correction 2% output voltage regulation during undervoltages to 65 (under 70% load only) USER INTERFACE, ALERTS & CONTROLS Switches 2 switches control off/on power status and alarm-cancel/self-test operation Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators 14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery and fault status information - includes 4-LED meter display for load and battery charge level SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 495 Primary UPS Height (mm) 259 Primary UPS Width (mm) 229 Shipping Dimensions (hwd / in.) 14.80 x 23.10 x 12.40 Shipping Dimensions (hwd / cm) 37.59 x 58.67 x 31.50 Shipping Weight (lbs.) 59.00 Shipping Weight (kg) 26.76 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.91 x 22.86 x 49.53 UPS Power Module Dimensions (hwd, in.) 10.2 x 9 x 19.5 UPS Power Module Weight (kg) 23.90 UPS Power Module Weight (lbs.) 52.7 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 816 AC Economy Mode BTU / Hr. (Full Load) 169 Battery Mode BTU / Hr. (Full Load) 889 AC Mode Efficiency Rating (100% Load) 87% AC Economy Mode Efficiency Rating (100% Load) 97% Audible Noise < 45 dB at front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable connection OR via select Network Management Card options PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 80V (100% load), 65V (
SU2200XLA
物料型号:SU2200XLA
器件简介: - 这是一款在线双转换UPS,能够保护关键的服务器、网络或电信设备免受停电、电压波动和电涌的影响。 - UPS能够将输入的交流电转换为直流电,然后再转换回完美的正弦波交流电输出,输出电压为120V交流电(±2%)。 - 该设备具有真正的正弦波输出和零转换时间,确保与所有设备类型的兼容性。
引脚分配: - 包含7个UPS支持的插座,其中6个为NEMA5-15/20R,1个为L5-20R。 - 有两个内置的、可独立切换的负载银行,每个银行有三个插座,可以通过软件界面控制。
参数特性: - 输出容量为2200VA/1600W。 - 支持输入电压范围在80V到150V之间(在负载低于70%时为65V到150V)。 - 内部电池组在半负载时可提供14分钟的运行时间,在全负载时可提供4.5分钟的运行时间。 - 电池运行时间可以通过外部电池组扩展。
功能详解: - 具有智能电池管理系统,可延长电池寿命。 - 支持通过HID兼容的USB端口、串行端口和SNMP/Web卡插槽进行通信。 - 兼容Tripp Lite的PowerAlert UPS管理软件和Watchdog服务监控和控制软件。
应用信息: - 适用于关键任务应用,如服务器、网络设备和电信设备。
封装信息: - UPS的物理尺寸为高259毫米、宽229毫米、深495毫米。 - 运输重量为26.76公斤,UPS电源模块重量为23.90公斤。
SU2200XLA 价格&库存
很抱歉,暂时无法提供与“SU2200XLA”相匹配的价格&库存,您可以联系我们找货
