SMART1500CRMXL
SMART1500CRMXL
    TRIPPLITE
    UPS SMART RACKMOUNT AVR USB DB9
SMART1500CRMXL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1.5kVA 1.44kW Line-Interactive Sine Wave UPS, 2U, Extended Run, Network Card Options, USB, 8 Outlets MODEL NUMBER: SMART1500CRMXL Highlights ● Corrects under- and overvoltages from 83V to 145V ● 8 NEMA 5-15R outlets—3 switchable via network interface ● Network power management and control capability ● Expandable runtime with optional external battery packs ● 14 min. runtime at half load; 6 min. at full load ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Ideal solution for data centers, VoIP systems and network closets. Features Protects Mission-Critical Rack-Mounted Equipment ● Provides fully regulated sine wave AC output for servers, network storage devices and telecom hardware ● Audible alarm signals loss of utility power, overload and low battery ● 8 NEMA 5-15R outlets ● 10-ft. (3.05 m) power cord with 120V NEMA 5-15P input ● 570-joule surge suppression rating Reliable Battery Backup with Expandable Runtime ● Supports half load up to 14 min. and full load up to 6 min. ● Internal batteries designed for hot-swap field replacement ● 97% line-power efficiency rating saves money in energy costs ● Expandable runtime with optional external battery packs, such as Tripp Lite's BP48V24-2U 3 Load Banks with Switchable Outlets ● Can control 3 outlets remotely to reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR) ● Maintains 120V nominal output over input range of 83V-145V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment's 1/6 ● SMART1500CRMXL SmartPro 120V 1.5kVA 1.44kW LineInteractive Sine Wave UPS ● USB cable ● DB9 cable ● EPO cable ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States performance LED Indicators ● Front-panel LEDs signal indicate line power, battery power, overload, voltage regulation and battery status Network Management Cards ● Compatible with Tripp Lite UPS management card options WEBCARDLX and SNMPWEBCARD Communications Ports ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● EPO port supports emergency shutdown in large facilities Versatile Installation Options ● Hardware included for 4-post mounting in 2U of EIA-standard 19 in. rack ● Mounts on wall or 2-post rack with optional 2POSTRMKITWM accessory ● Mounts in upright tower position with optional 2-9USTAND accessory Specifications OVERVIEW UPC Code 037332142115 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1440 Output Capacity (kW) 1.44 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Factor 1 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -14%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Three switchable single-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 6 min. (1440W) Runtime Half Load (min.) 14 min. (720W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 3 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 145 Overvoltage Correction Input voltages between 127 and 145 are reduced by 12% Undervoltage Correction Input voltages between 96 and 108 are boosted by 12% Severe Undervoltage Correction Input voltages between 83 and 95 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; rear panel protected switches support nominal voltage selection Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 58.42 Minimum Required Rack Depth (inches) 23 Minimum Required Rack Depth with External Battery Pack (cm) 67 Minimum Required Rack Depth with External Battery Pack (in.) 26.5 Minimum Required Rack Depth without External Battery Pack (cm) 57 Minimum Required Rack Depth without External Battery Pack (in.) 22.5 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Depth (mm) 493 Primary UPS Height (mm) 87 Primary UPS Width (mm) 439 Shipping Dimensions (hwd / in.) 8.70 x 23.00 x 19.30 Shipping Dimensions (hwd / cm) 22.10 x 58.42 x 49.02 Shipping Weight (lbs.) 68.00 Shipping Weight (kg) 30.84 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.71 x 43.94 x 49.28 UPS Power Module Dimensions (hwd, in.) 3.43 x 17.3 x 19.4 UPS Power Module Weight (kg) 27.22 UPS Power Module Weight (lbs.) 60 Unit Weight (lbs.) 60.0000 Unit Weight (kg) 27.22 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 152 Battery Mode BTU / Hr. (Full Load) 546 AC Mode Efficiency Rating (100% Load) 97% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 5.5 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART1500CRMXL 价格&库存
很抱歉,暂时无法提供与“SMART1500CRMXL”相匹配的价格&库存,您可以联系我们找货
