HCRK-54
HCRK-54
    TRIPPLITE
    MEDICALMOBILECARTPOWERKIT
HCRK-54 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 300W Medical-Grade Mobile Power Retrofit Kit with 54 Amp-hour Battery and 3 Outlets Highlights ● Provides UL 60601-1 compliance for connected mobile equipment (used in every sector of healthcare facilities, both inside and outside of patient-care areas ● Adds reliable mobile AC power source to medical carts ● Saves money by upgrading new or existing non-powered carts for a fraction of the cost of buying new powered models ● Simultaneously powers connected equipment while recharging batteries ● Includes everything needed to retrofit a cart: mobile power supply, 54 amp-hour userreplaceable battery module, PowerAlert data-saving software, remote user interface (RUI) and mounting hardware kit MODEL NUMBER: HCRK-54 Package Includes Description Tripp Lite's Medical-Grade Mobile Power Retrofit Kit provides UL 60601-1 compliance (a required patient shock-prevention measure) for all connected mobile electronic devices. The Mobile Power Retrofit Kit includes everything needed to add AC power to medical carts. The kit's power supply features an isolation transformer that reduces the cumulative shock potential of connected equipment, helping to ensure UL 60601-1 compliance. The included 54 amp-hour battery module provides long-lasting mobile power. The Mobile Power Retrofit Kit also includes a remote user interface (RUI), mounting hardware and standard cabling. Tripp Lite's Medical-Grade Mobile Power Retrofit Kit is fully compatible with most popular carts by AFC, Anthro, Datalux, GCX, Hergo, Humanscale, Jaco, Knurr, Stinger and more. Features ● Provides UL 60601-1 compliance for connected mobile equipment (used in every sector of healthcare facilities, both inside and outside of patient-care areas) ● Adds reliable mobile AC power source for medical carts ● Medical-Grade Mobile Power Supply (included) features an isolation transformer, providing UL 60601-1 compliance for connected equipment ● The Power Supply's advanced 3-stage charger recharges batteries faster and safer than conventional chargers ● The Power Supply's internal Automatic Transfer Switch (ATS) allows the power supply to simultaneously run connected equipment while recharging the battery module ● The Power Supply also features 3 NEMA 5-15R AC outlets, a 10-ft. coiled AC input cord with a hospitalgrade NEMA 5-15PHG plug, a USB communication port and a compact, all-metal housing that stands up to the most demanding environments ● 54-amp hour user-replaceable Battery Module (included) provides long-lasting mobile power. maintenance-free, spill-/leak-proof sealed lead-acid (SLA) AGM battery features simple, plug-in connection with included cable ● Remote User Interface (RUI) displays output and battery charge status at a glance. Includes on/off and alarm-mute switches. Mounts anywhere on the cart for easy access with included mounting material and cable ● Mounting Hardware Kit retrofits most standard medical carts from AFC, Anthro, Datalux, GCX, Hergo, Humanscale, Jaco, Knurr, Stinger and more 1/3 ● Medical-Grade Mobile Power Supply ● 54-amp hour user-replaceable Battery Module and cabling ● PowerAlert Software CD and USB cable ● Remote User Interface (RUI) and cabling ● Mounting Hardware Kit and owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332142795 Accessory Type Retrofit Kit INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Connection Type NEMA 5-15P-HG Hospital-Grade Voltage Compatibility (VAC) 120 Voltage Compatibility (VDC) 12 Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (3) 5-15R Continuous Output Capacity (Watts) 300 Peak Output Capacity (Watts) 750 BATTERY DC System Voltage (VDC) 12 Battery Charge Equal to discharge time. Includes advanced 3-stage (10A) battery charger USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs On Remote User Interface (RUI): Output AC Power, Battery Charge Level and Battery Charging Status Switches On Remote User Interface (RUI): On/Off Switch and Alarm-Mute Switch Audible Alarm Low Battery Alarm SURGE / NOISE SUPPRESSION EMI / RFI AC Noise Suppression Yes PHYSICAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Material of Construction Metal (Power Supply and Battery Module) Cooling Method Fan Form Factors Supported Retrofits most standard medical cart configurations Shipping Dimensions (hwd / in.) 19.40 x 15.10 x 17.90 Shipping Dimensions (hwd / cm) 49.28 x 38.35 x 45.47 Shipping Weight (lbs.) 84.00 Shipping Weight (kg) 38.10 Unit Dimensions (hwd / in.) 3.500 x 11.500 x 6.000 COMMUNICATIONS Network Monitoring Port USB STANDARDS & COMPLIANCE Product Certifications IEC 60601-1; CAN/CSA-C22.2 No. 601.1; UL 1778 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year power module and 6-month battery module limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
HCRK-54
1. 物料型号: - HCRK54
2. 器件简介: - HCRK54是一款过流保护继电器,主要用于保护电路免受过电流的损害。它具有快速响应时间和高可靠性,适用于各种需要过流保护的应用场合。
3. 引脚分配: - 引脚1:常闭触点(NC) - 引脚2:常开触点(NO) - 引脚3:共用端(COM) - 引脚4:线圈正极(A1) - 引脚5:线圈负极(A2)
4. 参数特性: - 线圈电压:5V DC - 触点额定电流:10A(电阻性负载) - 触点电压:28V DC - 触点类型:单刀双掷(SPDT) - 响应时间:小于5ms
5. 功能详解: - 当输入电流超过设定值时,继电器的线圈会产生磁场,吸引触点臂,使常闭触点断开,常开触点闭合,从而切断或改变电路状态,实现过流保护。 - 触点具有快速响应和高可靠性,确保电路安全。
6. 应用信息: - 适用于需要过流保护的各种电子设备,如电源供应器、电机驱动、电池管理系统等。
7. 封装信息: - 封装类型:SIP(单列直插式封装) - 封装尺寸:根据PDF文档,封装的具体尺寸为15.24mm x 7.62mm x 12.7mm。
HCRK-54 价格&库存
很抱歉,暂时无法提供与“HCRK-54”相匹配的价格&库存,您可以联系我们找货
