SM2200RMXL2UTAA
SM2200RMXL2UTAA
    TRIPPLITE
    UPS SMART RACKMOUNT AVR USB DB9
SM2200RMXL2UTAA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States TAA SmartPro 120V 2.2kVA 1.92kW LineInteractive Sine Wave UPS, 2U, Extended Run, Network Card Options, LCD, USB, DB9 Highlights ● 2.2kVA / 2200VA / 1920W line interactive 2U rack/tower UPS, Sine Wave ● Extended runtime options up to 1600W, 0.9 Power Factor, Interactive LCD interface ● USB, RS232, EPO and slot for network communication card options ● 120V NEMA 5-20P input, 4 NEMA 5-15R & 4 NEMA 515/20R outlets ● TAA Compliant for GSA Schedule purchases ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SM2200RMXL2UTAA Package Includes Description The SM2200RMXL2UTAA is compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Tripp Lite SmartPro Line Interactive UPS with enhanced LCD interface offers network-grade power protection for critical server, network and telecommunications equipment. Line Interactive Uninterruptible Power Supply (UPS) with built-in Auto-Voltage Regulation (AVR) actively corrects brownouts and overvoltages back to usable levels while maintaining a full battery charge in case of power failure. Tripp Lite's unique configuration excels in exceptionally poor-power environments with two separate levels of voltage boost to correct both slight undervoltages and severe brownout conditions. Interactive LCD interface reports UPS operating mode, detailed UPS and site-power data, plus enables a variety of UPS setup and configuration options. Super-fast switchover from line to battery power occurs within milliseconds to maintain operation of connected equipment without interruption or reboot. 96% linemode efficiency offers reduced heat emissions and operating costs. Communications interfaces support communications via USB, DB9 serial and a slot for an optional network management card. HID-compliant USB port enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Network communications ports enable detailed monitoring of equipment load levels, selftest data and utility power conditions. PowerAlert UPS monitoring and auto-shutdown software is available via free download. Switched output load banks enable scheduled and real-time remote reboot and load shedding of select outlets. Emergency Power Off (EPO) interface. LCD display panel easily rotates for viewing in rackmount or tower configurations. Audible alarm with push-button momentary alarm-cancel and silent-mode configuration options. Programmable self-test. Field-replaceable, hot-swappable battery modules. Features ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● Tripp Lite SMART2200RMXL2U line interactive 2U rack/tower UPS with 2200VA / 2.2kVA / 1920W capacity and extended runtime optionsLine interactive UPS with Automatic Voltage Regulation (AVR) corrects brownouts and overvoltages from 83 to 145V ● NEMA 5-20P input plug; 4 NEMA 5-15/20R and 4 5-15R output receptacles, Two independently switched output load banks ● Maintains uninterrupted operation of connected networking equipment during blackouts, surges, brownouts and overvoltages ● High 96% efficiency rating in line-power mode offers reduced power consumption and BTU emisssions ● Internal batteries offer 12 minutes at 50% load (960W) and 4.5 minutes at 100% load (1920W) 1/6 ● SM2200RMXL2UTAA TAA Compliant UPS system ● USB, Serial & EPO cabling ● 4 post installation kit ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Extended runtime is available with optional BP48V24-2U / BP48V242UTAA (limit 1) OR BP48V60RT3U / BP48V60RT3UTAA (no limit), Output is reduced to 1600 watts maximum with external battery packs ● External battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Hot-swappable, user-replaceable internal batteries and external battery packs can be replaced with no disruption to connected equipment ● Following an extended power outage, the UPS will automatically restart into line-power mode, begin powering connected equipment and recharge the battery system, all without user interaction ● Front panel LCD monitoring screen with MODE and ENTER buttons reports operating mode with 5-bar battery charge graphic, plus 7 selectable screens of detailed UPS and site power information ● LCD interface also supports a number of advanced user setup and operating preferences ● Ships with 4 post rackmount installation hardware; Optional 2POSTRMKITWM enables 2 post rackmount/wallmount installation; Optional 2-9USTAND enables tower placement ● Communications interfaces support communications via USB, DB9 serial and slot for network management card options; Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD ● HID-compliant USB port enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Built-in Emergency Power Off (EPO) interface with cable Specifications OVERVIEW UPC Code 037332152800 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 16A (120V) Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-20P UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 20A 120V OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1920 Output Capacity (kW) 1.92 Output Capacity Details Output is reduced to 1600 watts maximum when used with external battery packs 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Factor 0.87 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -14%, +6% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switched single outlet load banks (1 5-15/20R & 1 5-15R) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (4) 5-15R; (4) 5-15/20R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (1920W) Runtime Half Load (min.) 12 min. (960W) Expandable Runtime Yes Expandable Runtime Description Extended runtime supported via optional external battery packs; 1600 watts maximum load with external battery packs External Battery Pack Compatibility  BP48V24-2U  (limit 1); BP48V242UTAA (limit 1);  BP48V27-2US  (multi-pack compatible);  BP48V60RT-3U  (multi-pack compatible);  BP48V60RT3UTAA  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 145 Overvoltage Correction Voltage reduction of 12% applies when input is between 127 and 145 Undervoltage Correction Voltage boost of 12% applies when input voltage is between 96 and 108 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Severe Undervoltage Correction Voltage boost of 24% applies when input voltage is between 83 and 95 USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) Switches Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 55.88 Minimum Required Rack Depth (inches) 22 Minimum Required Rack Depth with External Battery Pack (cm) 66 Minimum Required Rack Depth with External Battery Pack (in.) 26 Minimum Required Rack Depth without External Battery Pack (cm) 62 Minimum Required Rack Depth without External Battery Pack (in.) 24.5 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 490 Primary UPS Height (mm) 88 Primary UPS Width (mm) 440 Shipping Dimensions (hwd / in.) 8.80 x 24.00 x 20.90 Shipping Dimensions (hwd / cm) 22.35 x 60.96 x 53.09 Shipping Weight (lbs.) 78.00 Shipping Weight (kg) 35.38 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.79 x 43.99 x 49.00 UPS Power Module Dimensions (hwd, in.) 3.46 x 17.32 x 19.29 UPS Power Module Weight (kg) 26.13 UPS Power Module Weight (lbs.) 57.6 Unit Weight (lbs.) 57.600 Unit Weight (kg) 26.13 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 306 Battery Mode BTU / Hr. (Full Load) 1157 Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 5 milliseconds (line to battery mode); 1 millisecond (battery to line mode) Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SM2200RMXL2UTAA 价格&库存
很抱歉,暂时无法提供与“SM2200RMXL2UTAA”相匹配的价格&库存,您可以联系我们找货
SM2200RMXL2UTAA
    库存:3
