SMART2200CRMXL
SMART2200CRMXL
    TRIPPLITE
    UPS SMART RACKMOUNT AVR
SMART2200CRMXL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 2.2kVA 1.9kW Line-Interactive Sine Wave UPS, 4U Short Depth, Extended Run, Network Card Options, USB, DB9 Highlights ● 2.2kVA / 2200VA / 1900W line interactive 4U reduced-depth rack/tower UPS, Sine Wave ● Reduced depth housing is ideal for 2 post rackmount installations ● 97% line-mode efficiency, 3 switched load banks, 2-post mounting kit ● USB, RS232 & EPO and slot for network management card options ● 120V NEMA 5-20P input, 4 NEMA 5-15R & 4 NEMA 515/20R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SMART2200CRMXL Package Includes Description Tripp Lite's SmartPro Compact Rackmount Uninterruptible Power Supply (UPS) offers line interactive voltage regulation, network grade surge suppression and long lasting battery support for critical network hardware during blackouts and extended power failures. Special reduced-depth housing, larger internal batteries, higher rated wattage and included 2 post rackmount installation hardware makes these systems ideal for network and telecom wiring closets and other limited-space installations. 97% line power mode efficiency saves operating costs over less efficient UPS types. Runtime is expandable with optional BP48V24-2U (limit 1), BP48V48RT4U (multi-pack compatible) and BP48V27-2US (multi-pack compatible) reduced-depth external battery packs. SMART2200CRMXL 4U rackmount 2200VA/1900 watt UPS offers battery-derived sine wave AC output during power failures and extreme voltage variations. Line interactive Automatic Voltage Regulation (AVR) provides two levels of voltage boost during brownouts and one level of voltage cut during overvoltage conditions to maintain regulated 120V nominal output over an input range of 83-145V. Includes NEMA 520P input plug, NEMA 5-15R and 5-15/20R output receptacles. Network management interfaces support simultaneous communications via USB port, DB9 serial port and optional network management accessory card slot. HID-compliant USB interface enables full integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces at once. PowerAlert monitoring software is available via free download. Emergency Power Off (EPO) interface. Integrated 3-bank programmable PDU switching supports load shedding and remote-reboot of up to 3 individual connected devices. 3-stage metered current monitoring and battery charge status LEDs. Utility power and voltage regulation LEDs. Audible alarm. Self-test. 2-post rackmount accessories included; 2-9USTAND tower stands. Field-replaceable, hot-swappable internal batteries and external battery packs. Attractive all-black color scheme. Features ● Tripp Lite's SmartPro Compact Rackmount Uninterruptible Power Supply (UPS) offers line interactive voltage regulation, network grade surge suppression and long lasting battery support for critical network hardware during blackouts and extended power failures ● Special reduced-depth housing, larger internal batteries, higher rated wattage and included 2 post rackmount installation hardware makes these systems ideal for network and telecom wiring closets and other limited-space installations ● Runtime is expandable with optional BP48V24-2U (limit 1), BP48V48RT4U (multi-pack compatible) and BP48V27-2US (multi-pack compatible) reduced-depth external battery packs 1/6 ● SmartPro Compact 4U Rackmount UPS system ● 2 post rackmount installation brackets ● USB and Serial Cabling ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Some external battery configurations require the use of Tripp Lite's External Battery Configur (see manual) ● Intelligent battery management system extends battery life ● SMART2200CRMXL 4U rackmount 2200VA/1900 watt UPS offers battery-derived sine wave AC output during power failures and extreme voltage variations ● Line interactive Automatic Voltage Regulation (AVR) provides two levels of voltage boost during brownouts and one level of voltage cut during overvoltage conditions to maintain regulated 120V nominal output over an input range of 83-145V ● Includes NEMA 5-20P input plug, NEMA 5-15R and 5-15/20R output receptacles ● Network management interfaces support simultaneous communications via USB port, DB9 serial port and optional network management accessory card slot ● Compatible with Tripp Lite UPS management card options WEBCARDLX, SNMPWEBCARD and RELAYIOCARD ● HID-compliant USB interface enables full integration with built-in power management and auto shutdown features of Windows and Mac OS X ● 97% efficiency in line power mode offers substantially lower operating costs than lower efficiency UPS types ● Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces at once ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Emergency Power Off (EPO) interface ● Integrated 3-bank programmable PDU switching supports load shedding and remote-reboot of up to 3 individual connected devices ● 3-stage metered current monitoring and battery charge status LEDs; Utility power and voltage regulation LEDs; Audible alarm; Self-test ● 2-post rackmount accessories included; 2-9USTAND tower stands available ● Field-replaceable, hot-swappable internal batteries and external battery packs ● Attractive all-black color scheme Specifications OVERVIEW UPC Code 037332142368 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 16A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-20P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 20A 120V 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1900 Output Capacity (kW) 1.9 Power Factor 0.86 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Three switchable single-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (4) 5-15R; (4) 5-15/20R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 11 min. (1900W) Runtime Half Load (min.) 28 min. (950W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V48RT4U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 3.6 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  (quantity 2) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 145 Overvoltage Correction Input voltages between 127 and 145 are reduced by 12% Undervoltage Correction Input voltages between 96 and 108 are boosted by 12% Severe Undervoltage Correction Input voltages between 83 and 95 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; rear panel protected switches support low/high charger settings Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 4U Cooling Method Fan Included Mounting Accessory Description Included 2POSTRMKITWM mounting accessory enables 2-post rackmount installation Installation Form Factors Supported with Included Accessories 2 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 4 post rackmount full-depth ( 4POSTRAILKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 53.34 Minimum Required Rack Depth (inches) 21 Minimum Required Rack Depth with External Battery Pack (cm) 64 Minimum Required Rack Depth with External Battery Pack (in.) 25 Minimum Required Rack Depth without External Battery Pack (cm) 58 Minimum Required Rack Depth without External Battery Pack (in.) 22.8 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  4POSTRAILKIT  mounting bracket enables installation in 4 post racks from 20.5 to 36 inches;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm) Primary UPS Depth (mm) 452 Primary UPS Height (mm) 175 Primary UPS Width (mm) 439 Shipping Dimensions (hwd / in.) 14.00 x 23.00 x 23.50 Shipping Dimensions (hwd / cm) 35.56 x 58.42 x 59.69 Shipping Weight (lbs.) 124.00 Shipping Weight (kg) 56.25 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 17.50 x 43.94 x 45.21 UPS Power Module Dimensions (hwd, in.) 6.89 x 17.30 x 17.80 UPS Power Module Weight (kg) 45.50 UPS Power Module Weight (lbs.) 100.3 Unit Weight (lbs.) 100.300 Unit Weight (kg) 45.50 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 242 Battery Mode BTU / Hr. (Full Load) 885 AC Mode Efficiency Rating (100% Load) 97% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 5 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Product Warranty Period (Puerto Rico) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART2200CRMXL 价格&库存
很抱歉,暂时无法提供与“SMART2200CRMXL”相匹配的价格&库存,您可以联系我们找货
