SMART2200RMXLN
SMART2200RMXLN
    TRIPPLITE
    UPS SMART RACKMOUNT AVR
SMART2200RMXLN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 2.2kVA 1.92kW Line-Interactive Sine Wave UPS, 2U Rack/Tower, Extended Run, Pre-Installed WEBCARDLX Network Interface, LCD Display, USB, DB9 Serial MODEL NUMBER: SMART2200RMXLN Highlights ● 2.2kVA / 2200VA / 1920W line interactive 2U rack / tower UPS; 0.9 power factor ● 120V nominal output during brownouts to 83V and overvoltages to 145V ● Interactive LCD provides UPS status information and advanced configuration options ● USB, RS232, EPO and preinstalled WEBCARDLX Network Interface ● Expandable runtime, Hot-swap batteries, 96% efficiency, Sine wave output ● NEMA 5-20P input; 4 NEMA 515/20R & 4 5-15R outlets ● To enable the Auto Probe feature, this product requires LX firmware update 15.5.2 or later to be installed Package Includes Description Tripp Lite SmartPro Line Interactive UPS with enhanced LCD interface offers network-grade power protection for critical server, network and telecommunications equipment. Line Interactive Uninterruptible Power Supply (UPS) with built-in Auto-Voltage Regulation (AVR) actively corrects brownouts and overvoltages back to usable levels while maintaining a full battery charge in case of power failure. Tripp Lite's unique configuration excels in exceptionally poor-power environments with two separate levels of voltage boost to correct both slight undervoltages and severe brownout conditions. Interactive LCD interface reports UPS operating mode, detailed UPS and site-power data, plus enables a variety of UPS setup and configuration options. Super-fast switchover from line to battery power occurs within milliseconds to maintain operation of connected equipment without interruption or reboot. 96% line-mode efficiency offers reduced heat emissions and operating costs. The Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities. Protocols supported include HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and NTP. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Network communications ports enable detailed monitoring of equipment load levels, self-test data and utility power conditions. PowerAlert UPS monitoring software is available via free download. Switched output load banks enable scheduled and real-time remote reboot and load shedding of select outlets. Emergency Power Off (EPO) interface. LCD display panel easily rotates for viewing in rack-mount or tower configurations. Audible alarm with push-button momentary alarm-cancel and silent-mode configuration options. Programmable self-test. Field-replaceable, hotswappable battery modules. Features ● Tripp Lite SMART2200RMXLN line interactive 2U rack/tower UPS with 2200VA / 2.2kVA / 1920W capacity and extended runtime options ● Line interactive UPS with Automatic Voltage Regulation (AVR) corrects brownouts and overvoltages from 83 to 145V ● NEMA 5-20P input plug; 4 NEMA 5-15/20R and 4 5-15R output receptacles, Two independently switched output load banks 1/7 ● SMART2200RMXLN UPS system ● Pre-installed WEBCARDLX network interface ● USB, Serial & EPO cabling ● 4-post installation kit ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Maintains uninterrupted operation of connected networking equipment during blackouts, surges, brownouts and overvoltages ● High 96% efficiency rating in line-power mode offers reduced power consumption and BTU emisssions ● Internal batteries offer 12 minutes at 50% load (960W) and 4.5 minutes at 100% load (1920W) ● Extended runtime is available with optional BP48V24-2U (limit 1), BP48V60RT-3U (multi-pack compatible) and BP48V27-2US (multi-pack compatible); Output is reduced to 1600 watts maximum with external battery packs ● External battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Hot-swappable, user-replaceable internal batteries and external battery packs can be replaced with no disruption to connected equipment ● Intelligent battery management system extends battery life ● Front panel LCD monitoring screen with MODE and ENTER buttons reports operating mode with 5-bar battery charge graphic, plus 7 selectable screens of detailed UPS and site power information ● LCD interface also supports a number of advanced user setup and operating preferences ● Ships with 4 post rackmount installation hardware; Optional 2POSTRMKITWM enables 2 post rackmount/wallmount installation; Optional 2-9USTAND enables tower placement ● Network interfaces support communications via built-in USB, DB9 serial / contact-closure and preinstalled WEBCARDLX network management card ● WEBCARDLX interface allows full remote access for power monitoring, configuration, control and email notifications via secure web browser, SNMP, Telnet, SSH, or Command Line ● Reduce service calls with Auto Probe Autonomous Device Management. The Auto Probe feature (Firmware 15.5.2 and greater) checks the connectivity status of any networked device and automatically takes one or more user-configured actions if the device fails to respond; actions include outlet reboot, set SNMP traps, SNMP OID sets, and even script execution when used in conjunction with the Tripp Lite PowerAlert Network Shutdown Agent (PANSA) ● Optional EnviroSense2 sensors (sold separately) enable site monitoring of temperature, humidity and contact-closure status ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● USB and DB9 ports enable data-saving unattended shutdown when used with Tripp Lite’s PowerAlert software (available via free download at tripplite.eaton.com/products/power-alert) ● Built-in Emergency Power Off (EPO) interface with cable Specifications OVERVIEW UPC Code 037332177926 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 16A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-20P UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service 20A 120V OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1920 Output Capacity (kW) 1.92 Output Capacity Details Output is reduced to 1600 watts maximum when used with external battery packs Power Factor 0.87 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -14%, +6% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switched single outlet load banks (1 5-15/20R & 1 5-15R) Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (4) 5-15R; (4) 5-15/20R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (1920W) Runtime Half Load (min.) 12 min. (960W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) 4.5 hours maximum from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  Battery Replacement Description Hot-swappable, user replaceable batteries 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 145 Overvoltage Correction Voltage reduction of 12% applies when input is between 127 and 145 Undervoltage Correction Voltage boost of 12% applies when input voltage is between 96 and 108 Severe Undervoltage Correction Voltage boost of 24% applies when input voltage is between 83 and 95 USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) Switches 3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions. LX Platform Interface: Recessed reset switch for interface reboot and factory reset Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators Network Link/Activity (Green): Flashes for network activity. Network Speed (Yellow): 10 Mbps (Flashing), 100 Mbps (On steady). LX Platform Interface Status: Normal Operation (Solid Green); Software Update (Alternating Green/Orange ~1/sec); Factory Reset (Alternating Green/Orange ~2/sec). SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 2-9USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 58.42 Minimum Required Rack Depth (inches) 23 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth with External Battery Pack (cm) 67 Minimum Required Rack Depth with External Battery Pack (in.) 26.5 Minimum Required Rack Depth without External Battery Pack (cm) 62 Minimum Required Rack Depth without External Battery Pack (in.) 24.5 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 494 Primary UPS Height (mm) 87 Primary UPS Width (mm) 440 Shipping Dimensions (hwd / in.) 8.90 x 23.90 x 22.00 Shipping Dimensions (hwd / cm) 22.61 x 60.71 x 55.88 Shipping Weight (lbs.) 77.85 Shipping Weight (kg) 35.31 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.71 x 43.99 x 49.43 UPS Power Module Dimensions (hwd, in.) 3.43 x 17.32 x 19.46 UPS Power Module Weight (kg) 26.13 UPS Power Module Weight (lbs.) 57.6 Unit Weight (lbs.) 57.6000 Unit Weight (kg) 26.13 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 5 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 306 Battery Mode BTU / Hr. (Full Load) 1157 AC Mode Efficiency Rating (100% Load) 96% Audible Noise 45 dBA maximum, front side 1m 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS Network Management Cards  WEBCARDLX  Network Monitoring Port Description Pre-installed WEBCARDLX network management card; Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management card included Communications Interface DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 5 milliseconds (line to battery mode); 1 millisecond (battery to line mode) Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (included); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
SMART2200RMXLN
1. 物料型号: - 型号编号:SMART2200RMXLN
2. 器件简介: - SMART2200RMXLN是一款智能专业1950VA/1950W/120V的在线互动式正弦波UPS电源,提供7个输出插座,支持远程配置和管理,内置网络卡,LCD显示屏,USB和DB9接口,符合ENERGY STAR V2.0标准,适用于2U机架/塔式安装。
3. 引脚分配: - 提供一个L5-20R和六个管理的5-20R输出插座,这些插座提供纯正弦波交流输出,并允许对电能消耗进行监控,直至输出组级别。
4. 参数特性: - 输出容量:1950VA/1.95kVA/1950W/1.95kW,功率因数为1.0。 - 支持的额定输入电压:120V。 - 输出电压调节(在线模式):120V(-13%,+15%)。 - 输出电压调节(电池模式):-10%,+6%。 - 电池类型:阀控式铅酸电池(VRLA)。 - 全负载运行时间(分钟):4分钟(1950W)。 - 半负载运行时间(分钟):12分钟(975W)。 - 支持通过连接最多四个可选的扩展电池模块(BP72VRM2U,单独出售)来扩展运行时间。
5. 功能详解: - 提供电池备份和纯正弦波电力输出,保护服务器、交换机等高端分布式IT设备。 - 内置WEBCARDLXE网络管理卡,支持全天候远程监控和管理。 - 自动电压调节(AVR)功能,可在80V至151V的电压范围内保持120V的额定输出。 - 提供EMI/RFI线路噪声过滤,提高连接设备的运行性能和寿命。 - 符合ENERGY STAR 2.0认证,节省电力,降低成本,保护环境。
6. 应用信息: - 适用于分布式IT、电信或企业部署,保护设备免受停电、电压暂降、瞬变浪涌和线路噪声的影响。
7. 封装信息: - 主要形态因素:机架安装。 - 机架高度:2U。 - 冷却方式:风扇。 - 支持的安装形态因素:4柱19英寸机架安装;塔式。 - 包含的安装配件:机架安装硬件、塔式支撑架。
SMART2200RMXLN 价格&库存
很抱歉,暂时无法提供与“SMART2200RMXLN”相匹配的价格&库存,您可以联系我们找货
