SUINT2200LCD2U
SUINT2200LCD2U
    TRIPPLITE
    2200VA 1600W UPS
SUINT2200LCD2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton Tripp Lite series SmartOnline 208/230V 2200VA 1.98kW Double-Conversion UPS - 9 Outlets, Extended Run, Card Slot, LCD, USB, DB9, 2U MODEL NUMBER: SUINT2200LCD2U Highlights ● Offers network-grade protection against power failures and voltage fluctuations ● Zero transfer time between online and battery modes for uninterrupted operation ● Optional external battery packs provide additional runtime for applications requiring it ● Add optional WEBCARDLX with latest version of PADM20 for IPbased Auto Probe feature ● ENERGY STAR-certified to save electricity, lower costs, and protect the environment Applications On-line double-conversion UPS provides pure sine wave AC output to server and network equipment in data centers and computer rooms. ● Deliver perfectly regulated sine wave output to mission-critical equipment ● Protect connected components from dangerous surges, spikes and line noise ● Keep equipment operational through power failures ● Allow time to save data and safely shut down components in case of a prolonged blackout Features Double-Conversion UPS Protects Equipment against Damage, Downtime and Data Loss This 200/208/220/230/240V 50/60 Hz UPS system maintains perfect output by converting AC input to DC, then reconverting UPS output to fully regulated sine wave AC with +/-2% voltage regulation in online and battery modes. Featuring a 1980W capacity, high 0.9 power factor, 936 joules of surge suppression, true on-line operation with pure sine wave output and zero transfer time to battery mode in on-line doubleconversion mode, the SmartOnline® SUINT2200LCD2U double-conversion UPS provides the highest level of AC power protection and battery backup for critical network closet, computer room and data center equipment. Set Power Strategies to Reflect Your Protection Priorities Pick your power strategy, from precise power for sensitive systems to the highest possible electrical efficiency, while ensuring 100% uptime. Choose from five selectable strategies: Max Efficiency, Max Quality, Frequency Regulation, Frequency Conversion and Auto Adaptive, which automatically offers increased efficiency when power conditions are good and enhanced power quality when power conditions are poor. Individually Controllable Load Banks Let You Access and Control Outlets Remotely Six C13 outlets are split into two individually switchable load banks, one with three C13 outlets and the other with three C13 and one C19 outlet, allowing you to reboot select components or shed loads remotely. In addition to those seven outlets, this UPS provides two more C13 outlets in their own unswitched bank for powering critical components. Reliable, Expandable Battery Backup Keeps You Operational Through Power Outages The field-replaceable, hot-swappable internal battery (RBC48S) provides 11.7 minutes of support at half load (990W) and 4.3 minutes at full load (1980W), keeping protected equipment operational through power failures. For mission-critical applications demanding scalable extended runtime, the UPS supports “smart” external battery packs, such as Tripp Lite’s BP48V27-2US (sold separately). Both the internal and external batteries are automatically sensed and configured during replacement to offer accurate runtimeremaining and battery age notifications during outages. The intelligent battery management system with 1/7 Package Includes ● SUINT2200LCD2U SmartOnline Double-Conversion UPS ● USB cable ● RS-232 cable ● EPO cable ● C19-to-C20 power cable ● (2) C13-to-C14 power cables ● 4-post rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States temperature-compensated charging extends battery life. Automatic Bypass Maintains Utility Output During Fault Conditions Auto-bypass mode keeps connected equipment powered and operational, even during UPS fault conditions. ENERGY STAR-Certified Economy Mode Helps You Save Money and Protect the Environment By meeting strict EPA efficiency guidelines, this ENERGY STAR-certified UPS system helps you save money and energy. A power-saving Economy mode setting option offers enhanced efficiency and reduced BTU output when utility power is already high quality. Automatically Turns Back On After Power Is Restored Battery-independent restart ensures automatic UPS power-up without user interaction after lengthy power outages, even when batteries are expired and require replacement. Intuitive Front-Panel Interface for Convenient UPS Operation and Monitoring The front-panel LCD screen reports UPS operating mode, detailed UPS status and site-power information, as well as a variety of advanced UPS setup and configuration options. LEDs indicate AC input/output, battery and fault status. Advanced Communications Ports Allow for Automatic Saves and Shutdowns RS-232 and HID-compliant USB ports connect to a computer running Tripp Lite’s free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. An EPO port connects the UPS to a contact closure switch to enable emergency inverter shutdown. Cables are included. Optional WEBCARDLX Network Interface Offers 24/7 Access The optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities, including customizable dashboard graphs to fit user preferences. The PADM20 upgrade and Tripp Lite’s PowerAlert Element Manager (PAEM) software form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations. Auto Probe allows a UPS with switched loads to automatically reboot devices if a network communication failure is detected. This preserves uptime and minimizes the time and expense associated with on-site support. Versatile Installation Options Hardware is included for mounting the UPS system in 2U of space in an EIA-standard 19-inch 4-post rack. Use the optional 2POSTRMKITWM (sold separately) for 2-post rack mounting or the optional 2-9USTAND (sold separately) for mounting in an upright tower position. The C20 power inlet accepts a variety of usersupplied input cords. Specifications OVERVIEW UPC Code 037332183330 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10.94A Nominal Input Voltage(s) Supported 200V AC; 208V AC; 220V AC; 230V AC; 240V AC UPS Input Connection Type C20 inlet 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Total Harmonic Distortion 150% for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits). Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details Nominal output voltage is user configured on first power-on Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details Output frequency matches input nominal on startup; Output capacity de-rates by 30% during frequency conversion operation Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Included Output Power Cables Includes 2 C13 to C14 and 1 C19 to C20 power cables Load Management Receptacles Two switchable outlet load banks (Bank 1: 3 C13 outlets / Bank 2: 1 C19 + 3 C13 outlets) Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 200V; 208V; 220V; 230V; 240V Output Receptacles (8) C13; (1) C19 Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.3 min. (1980W) Runtime Half Load (min.) 11.7 min. (990W) Expandable Runtime Yes 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V272US  (multi-pack compatible);  BP48V60RT3U  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 3.0 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC48S  Battery Replacement Description Hot-swappable, replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 288V Undervoltage Correction 2% output voltage regulation during undervoltages to 160V (100% load), 130V (70% load), 100V (30% load) USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Interactive front-panel LCD interface reports UPS operating mode, detailed UPS status and site-power information; LCD interface also enables a variety of advanced UPS setup and configuration options Switches 5 front panel switches: On/Off, Up, Down and Escape Alarm Cancel Operation Power-fail alarm can be silenced by following on-screen prompts Audible Alarm Audible alarm indicates power failure, low battery, overload and fault LED Indicators 4 front panel LEDs: AC input (green), AC output (green), Battery (yellow), Fault (red) SURGE / NOISE SUPPRESSION UPS Dataline Suppression Details Single line dialup / network dataline protection included EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 936 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 58.42 Minimum Required Rack Depth (inches) 23 Minimum Required Rack Depth with External Battery Pack (cm) 67 Minimum Required Rack Depth with External Battery Pack (in.) 26.5 Minimum Required Rack Depth without External Battery Pack (cm) 58 Minimum Required Rack Depth without External Battery Pack (in.) 23 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 496 Primary UPS Height (mm) 88 Primary UPS Width (mm) 438 Shipping Dimensions (hwd / in.) 9.45 x 22.24 x 27.56 Shipping Dimensions (hwd / cm) 24.00 x 56.49 x 70.00 Shipping Weight (lbs.) 64.00 Shipping Weight (kg) 29.03 UPS Housing Material Metal UPS Power Module Dimensions (hwd, cm) 8.79 x 43.79 x 49.61 UPS Power Module Dimensions (hwd, in.) 3.46 x 17.24 x 19.53 UPS Power Module Weight (kg) 23.11 UPS Power Module Weight (lbs.) 50.94 Unit Weight (lbs.) 50.9400 Unit Weight (kg) 23.11 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 5 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 675 AC Economy Mode BTU / Hr. (Full Load) 356 Battery Mode BTU / Hr. (Full Load) 1012 AC Mode Efficiency Rating (100% Load) >90% AC Economy Mode Efficiency Rating (100% Load) >95% Audible Noise
SUINT2200LCD2U
物料型号: - 型号编号:SUINT2200LCD2U
器件简介: - 该设备是一款双转换在线式UPS,提供2200VA/2000W的功率,适用于教育、医疗保健、军事、政府等关键IT应用,以及空间有限但对电力可靠性要求高的小型或中型网络环境。
引脚分配: - 输出插座:8个C13和2个C19插座,分为两组负载银行,第一组包括两个C13插座和一个C19插座,第二组包括两个C13插座。
参数特性: - 输入电压:支持200V至240V AC,出厂默认为208V。 - 输出电压:208V默认,支持200V至240V。 - 输出波形:纯正弦波。 - 功率因数:0.9。 - 效率:在线模式93%,经济模式98%。 - 电池类型:阀控铅酸(VRLA)。 - 电池运行时间:全负载6分钟,半负载16.6分钟。 - 扩展运行时间:可通过连接最多四个扩展电池模块(BP72RT)来扩展。
功能详解: - 提供纯正弦波输出,保护设备免受停电、电压骤降、瞬变浪涌和线路噪声的影响。 - 零切换时间,确保在线模式和电池模式之间的不间断运行。 - 可选的WEBCARDLXE网络卡支持全天候远程访问和控制。 - 前面板LCD提供详细的报警和通知,帮助诊断问题,并提供系统状态、事件日志、电池和电源模块状态、使用分析等信息。
应用信息: - 适用于关键任务应用,如数据中心、服务器室等。
封装信息: - 机架式安装,占用2U空间。 - 冷却方式:风扇。 - 包含安装配件:适用于4柱19英寸机架安装。 - 可选配件:2柱机架安装套件(RK2PC)。
SUINT2200LCD2U 价格&库存
很抱歉,暂时无法提供与“SUINT2200LCD2U”相匹配的价格&库存,您可以联系我们找货
