1000 Eaton Boulevard
Cleveland, OH 44122
United States
3 Breaker Maintenance Bypass Panel for select
Tripp Lite 20 and 30kVA UPS systems
Highlights
Wallmount manual bypass panel
isolates UPS from connected
loads for maintenance with no
loss of network availability
Mechanical interlock system
enhances system reliability
Minimizes sequencing errors
3 built-in CH Type circuit
breakers
Compatible with select Tripp Lite
20 and 30kVA 3 phase UPS
systems
MODEL NUMBER: SU2030KMBP
Description
Wallmount 3 breaker manual bypass panel with mechanical interlock system isolates the UPS from
connected loads for maintenance with no loss of network availability. 100A breaker with KAIC rating of 10.
Compatible with Tripp Lite SU20K3/3, SU20K3/3XR5, SU30K3/3 and SU30K3/3XR5.
Features
Isolates the UPS from connected loads for maintenance with no loss of network availability
Compatible with Tripp Lite SU20K3/3, SU20K3/3XR5, SU30K3/3, SU30K3/3XR5 and SV20K__ models.
Specifications
OVERVIEW
UPC Code
037332181800
Accessory Type
Bypass Panel
Accessory Class
UPS Accessories
INPUT
Nominal Input Voltage Description
208Y/120 VAC 3 phase, 4 wire, Ground
OUTPUT
Output Capacity Details
100A maximum per phase
1/2
Cleveland, OH 44122
United States
PHYSICAL
Form Factors Supported
Wallmount
Shipping Dimensions (hwd / in.)
7.50 x 14.50 x 26.50
Shipping Dimensions (hwd / cm)
19.05 x 36.83 x 67.31
Shipping Weight (lbs.)
33.50
Shipping Weight (kg)
15.20
Unit Dimensions (hwd / in.)
12.000 x 24.000 x 5.560
Unit Dimensions (hwd / cm)
30.5 x 61 x 11.7
Unit Weight (lbs.)
27.5
Unit Weight (kg)
12.47
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“SU2030KMBP”相匹配的价格&库存,您可以联系我们找货
