SU3000XLCD
SU3000XLCD
    TRIPPLITE
    UPS SMART ONLINE LCD TOWER
SU3000XLCD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton Tripp Lite series SmartOnline 120V 3kVA 2.7kW Double-Conversion UPS, Tower, Extended Run, Network Card Options, LCD, USB, DB9 Highlights ● 3000VA / 3kVA / 2700 watt online double-conversion tower UPS ● 100/110/120/127V 50/60Hz output, high efficiency economy mode option ● Interactive LCD with 10 selectable screens of UPS and site power data ● Expandable runtime, Hotswappable batteries ● USB, RS232 & EPO ports, slot for network management card options ● 2 independently switched load banks ● NEMA L5-30P input; 8 5-15/20R & 1 L5-30R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SU3000XLCD Package Includes Description Do you need to protect medium- to large-size servers, networking equipment and telecom systems against data loss, downtime and equipment damage due to power outages, voltage fluctuations and transient surges? Tripp Lite’s SU3000XLCD SmartOnline® Tower UPS System is the solution! Featuring a 3000VA/2700W capacity and true on-line operation with pure sine wave output and zero transfer time to battery, it provides the highest level of power protection for mission-critical equipment. The SU3000XLCD’s large internal battery set supports connected equipment during blackouts, and runtime is expandable with optional external battery packs (Tripp Lite model BP72V15-2U or BP72V28RT-3U), sold separately. The SU3000XLCD has 9 AC outlets (8 5-15/20R, 1 L5-30R), including 2 load banks of 3 outlets each that are individually controllable to reboot select equipment on demand or maximize battery runtime for mission-critical equipment. USB and DB9 communication ports support messaging of detailed UPS operational parameters and line power status. PowerAlert UPS management software is available via free download. The SU3000XLCD also accepts an optional network management card option. It comes backed by $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features Ideal for Protection of Mission-Critical Equipment True On-Line Operation with Pure Sine Wave Output and Zero Transfer Time Individually Controllable Outlets Reliable, Expandable Battery Backup High Power Factor and Highly Efficient Operation Reduces BTU Output 1/6 ● SU3000XLCD SmartOnline® Tower UPS System ● USB, DB9 and EPO cables ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States AC and Tel/Ethernet Line Surge Suppression EMI/RFI Line Noise Filtering LCD Screen and Audible Alarm USB/DB9 Ports, Management Card Options and Included PowerAlert Software tripplite.eaton.com/products/power-alert Emergency Power Off (EPO) Capability Peace of Mind Specifications OVERVIEW UPC Code 037332158871 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 24A Nominal Input Voltage(s) Supported 100V AC; 110V AC; 120V AC; 127V AC Nominal Input Voltage Description 120V factory default UPS Input Connection Type L5-30P Input Circuit Breakers 40A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 30A 120V OUTPUT Output Capacity (VA) 3000 Output Capacity (kVA) 3 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (Watts) 2700 Output Capacity (kW) 2.7 Output Capacity Details ON LINE MODE: Maximum output capacity rating is reduced to 2430W (115V), 2295W (110V), 2160W (100V); FREQUENCY REGULATION / CONVERSION MODE: Maximum output ratings are reduced in frequency regulation / conversion mode (127/120V 1890 watts, 115V 1701 watts, 110V 1607 watts, 100V 1512 watts) OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150% load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits) Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details 120V default Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details ON LINE MODE: Output frequency is automatically configured to match nominal input frequency on startup; Output matches input frequency when +/-5Hz of nominal; Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal. UPS switches to battery mode when input frequency is below 40Hz or above 70Hz. FREQUENCY REGULATION / CONVERSION MODE: Output is regulated to +/-0.05Hz of selected output frequency when input is 40 to 70Hz; UPS switches to battery mode when input frequency is below 40Hz or above 70Hz. BATTERY MODE: Output is regulated to +/-0.05Hz of selected nominal. Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 3% Load Management Receptacles Two switchable four-outlet load banks Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 100V; 110V; 120V; 127V Output Receptacles (8) 5-15/20R; (1) L5-30R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.1 min. (2700W) Runtime Half Load (min.) 13.2 min. (1350W) Expandable Runtime Yes Expandable Runtime Description External battery configurations require the use of Tripp Lite's External Battery Configuration Software, see manual for details External Battery Pack Compatibility  BP72V15-2U  (limit 1);  BP72V28RT-3U  (multi-pack compatible);  BP72V18-2US  (multi-pack compatible) 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States DC System Voltage (VDC) 72 Battery Recharge Rate (Included Batteries) Less than 3 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC96-3U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 150 Undervoltage Correction 2% output voltage regulation during undervoltages to 55V (33% load), 70V (70% load), 100V (100% load) USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, frequency, operating mode, alarm function and a variety of additional options Switches 2 switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 495 Primary UPS Height (mm) 259 Primary UPS Width (mm) 229 Shipping Dimensions (hwd / in.) 14.70 x 23.30 x 12.60 Shipping Dimensions (hwd / cm) 37.34 x 59.18 x 32.00 Shipping Weight (lbs.) 76.00 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 34.47 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.91 x 22.86 x 49.53 UPS Power Module Dimensions (hwd, in.) 10.2 x 9 x 19.5 UPS Power Module Weight (kg) 31.98 UPS Power Module Weight (lbs.) 70.5 Unit Weight (lbs.) 70.5 Unit Weight (kg) 31.98 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 801 AC Economy Mode BTU / Hr. (Full Load) 188 Battery Mode BTU / Hr. (Full Load) 1626 AC Mode Efficiency Rating (100% Load) 92% AC Economy Mode Efficiency Rating (100% Load) 98% Audible Noise < 51.5 dB at front side 1m Operating Elevation (m) Up to 3000m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure communications PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time Zero transfer time (0 ms.) in online, double-conversion and frequency regulation / conversion modes; Low Voltage Transfer to Battery Power (Setpoint) 55V (33% load), 70V (70% load), 100V (100% load) High Voltage Transfer to Battery Power (Setpoint) 150 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries; Remote management; Surge/noise protection; Zero transfer time Green Energy-Saving Features High efficiency economy mode operation; Individually controllable load banks; Schedulable daily hours of economy mode operation STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SU3000XLCD
物料型号:SU3000XLCD
器件简介:这是一款在线双转换UPS系统,专为教育、医疗保健、军事、政府和其他IT应用提供纯正弦波输出,在小型或中型网络中提供最高级别的电力保护和电池备份。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 额定输入电流:24A - 输出容量:3000VA / 2700W - 电池类型:阀控铅酸(VRLA) - 运行时间:全负载5.7分钟,半负载16.7分钟 - 扩展运行时间:可通过连接最多四个外部电池模块(BP96V)来扩展 - EMI/RFI滤波:减少电磁和射频干扰,提高设备性能和寿命
功能详解: - 零转换时间:在线模式和电池模式之间无中断切换 - 可选网络管理卡:实现24/7远程访问和管理 - NEMA插座:提供纯正弦波交流输出,保护连接设备 - 清晰的LCD界面:提供系统状态、事件日志等详细信息 - 高级通信端口:支持自动保存和关机 - 自动重新启动:市电恢复后自动启动UPS
应用信息:适用于关键任务应用,如数据中心、计算机房、网络柜等。
封装信息:塔式设计,支持平面安装,金属外壳,带风扇冷却。
SU3000XLCD 价格&库存
很抱歉,暂时无法提供与“SU3000XLCD”相匹配的价格&库存,您可以联系我们找货
