SUINT3000RTXL2U
SUINT3000RTXL2U
    TRIPPLITE
    3000VA 2500W UPS
SUINT3000RTXL2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline Double-Conversion UPS - 2U, USB, DB9, 230V, 3kVA, 2.5kW, On-Line MODEL NUMBER: SUINT3000RTXL2U Highlights ● Zero transfer time between AC power and battery for uninterrupted operation ● 8 C13 outlets in 2 switchable load banks + 2 C19 outlets power critical equipment ● Field-replaceable internal batteries are hot-swappable for convenient replacement ● Optional external batteries provide additional runtime for essential applications ● Front-panel status LEDs indicate detailed load and battery metering at a glance ● Add optional WEBCARDLX with latest version of PADM20 for IPbased Auto Probe feature Applications ● Deliver perfectly regulated sine wave output to mission-critical equipment ● Protect connected components from dangerous surges, spikes and line noise ● Keep equipment operational through short power failures ● Allow time to save data and safely shut down components in case of a prolonged blackout 3kVA UPS converts raw incoming AC power to DC, then re-converts DC to fulltime sine wave 230V AC output with zero transfer time. Features Double-Conversion UPS Protects Equipment against Damage, Downtime and Data LossThis 230V 2U UPS system protects connected equipment against damage, downtime and data loss due to power outages, voltage fluctuations and transient surges. Featuring a 2500W capacity, high 0.8 power factor, 420 joules of surge suppression, true on-line operation with pure sine wave output and zero transfer time to battery, the SmartOnline® SUINT3000RTXL2U double-conversion UPS provides the highest level of battery backup and AC power protection for critical network closet, computer room and data center equipment. Package Includes Individually Controllable Load Banks Let You Access and Control OutletsEight C13 outlets are even split into two switchable load banks, each allowing you to reboot connected equipment or shed loads remotely. In addition to the C13 outlets, this UPS provides two C19 outlets for powering critical components. Reliable, Expandable Battery Backup Keeps You Operational Through Power OutagesUPS battery backup keeps connected equipment operational through short power failures, and provides time to save data and perform an orderly system shutdown in case of a prolonged blackout. The field-replaceable, hotswappable internal battery provides 15 minutes of support at half load and six minutes at full load. During normal operation, incoming utility power keeps the battery fully charged so backup power will be available when needed. For mission-critical applications demanding continuous uptime, the 3kVA UPS can provide expandable runtime with optional external battery packs, such as Tripp Lite’s BP72V15-2U (sold separately). Easily Hot-Swappable with No Expensive Service Calls or Downtime NeededTripp Lite’s optional PDUBHV20 bypass PDU (sold separately) enables hot-swappable UPS replacement with no disruption of power to connected equipment. When making repairs or replacing a battery, no lengthy service calls or downtime are necessary. Optional WEBCARDLX Network Interface Offers 24/7 Remote Access for Monitoring and ControlThe optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities, including customizable dashboard graphs to fit user preferences. The PADM20 upgrade and Tripp Lite’s PowerAlert Element Manager (PAEM) software form a powerful tool for expanding maintenance functions in large 1/6 ● SUINT3000RTXL2U SmartOnline Double-Conversion UPS ● C19 to C20 power cable, 5 ft. ● USB cable ● DB9 cable ● EPO cable ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States installations, including firmware update checks and backup and restoration of device configurations. Auto Probe allows a UPS with switched loads to automatically reboot devices if a network communication failure is detected. This preserves uptime and minimizes the time and expense associated with on-site support. Intuitive Front-Panel Interface for Convenient UPS Operation and MonitoringFront-panel LEDs provide information on load and battery levels, operating mode, fault status and other critical data at a glance. The LED panel rotates for comfortable viewing in rack-mount or tower configuration. Advanced Communications PortsThis USB UPS system has USB and DB9 ports (cables are included) that enable data-saving unattended shutdown of connected systems when used with Tripp Lite’s free downloadable PowerAlert® software. Capabilities include detailed monitoring of load levels, self-test data and utility power conditions. Versatile Installation OptionsHardware is included for mounting the UPS system in 2U of space in an EIA-standard 19-inch 4-post rack with a depth of only 66 centimeters (26 inches). Use the optional 2POSTRMKITWM (sold separately) for 2-post rack mounting or the optional 2-9USTAND (sold separately) for mounting in an upright tower position. The C20 power inlet accepts a variety of usersupplied input cords. Specifications OVERVIEW UPC Code 037332198495 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 15A Nominal Input Voltage(s) Supported 230V AC Nominal Input Voltage Description 230V factory configuration UPS Input Connection Type C20 inlet UPS Input Cord Length (ft.) 5 UPS Input Cord Length (m) 1.5 OUTPUT Output Capacity (VA) 3000 Output Capacity (kVA) 3 Output Capacity (Watts) 2500 Output Capacity (kW) 2.5 Output Capacity Details OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes, 150% for 30 seconds and >150% for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits of ±10% and ±5Hz) or SHUTDOWN (when bypass input voltage and frequency are OUTSIDE bypass limits of ±10% and ±5Hz) Power Factor 0.83 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Crest Factor 3:1 Nominal Voltage Details 230V default Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup, defaults to 50 Hz on cold-start Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/-10% Output Voltage Regulation (Battery Mode) +/- 2% Included Output Power Cables Includes 2 C13 to C14 and 1 C19 to C20 power cables Load Management Receptacles Two switchable 4 C13 outlet load banks Hot-Swap PDU options PDUBHV20 (2U / 6 C13, 2 C19 outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 230V Output Receptacles (8) C13; (2) C19 Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 6 min. (2500W) Runtime Half Load (min.) 15 min. (1250W) Expandable Runtime Yes External Battery Pack Compatibility  BP72V15-2U  (limit 1);  BP72V28RT-3U  (multi-pack compatible);  BP72V18-2US  (multi-pack compatible) DC System Voltage (VDC) 72 Battery Recharge Rate (Included Batteries) Less than 4.8 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge See RBC selector Battery Replacement Description Hot-swappable, replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Overvoltage Correction 2% output voltage regulation during overvoltages to 288 Undervoltage Correction 2% output voltage regulation during undervoltages to 160V (70-100% load) / 130V (30-70% load) / 100V (Under 30% load) USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates power failure, low battery, overload, replace battery and EPO operation LED Indicators 14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in rack/tower formats SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 71.12 Minimum Required Rack Depth (inches) 28 Minimum Required Rack Depth with External Battery Pack (cm) 77 Minimum Required Rack Depth with External Battery Pack (in.) 30.25 Minimum Required Rack Depth without External Battery Pack (cm) 75 Minimum Required Rack Depth without External Battery Pack (in.) 29.5 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 616 Primary UPS Height (mm) 88 Primary UPS Width (mm) 438 Shipping Dimensions (hwd / in.) 9.70 x 23.70 x 29.80 Shipping Dimensions (hwd / cm) 24.64 x 60.20 x 75.69 Shipping Weight (lbs.) 84.70 Shipping Weight (kg) 38.42 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.79 x 43.79 x 61.60 UPS Power Module Dimensions (hwd, in.) 3.46 x 17.24 x 24.25 UPS Power Module Weight (kg) 31.17 UPS Power Module Weight (lbs.) 68.72 Unit Weight (lbs.) 68.720 Unit Weight (kg) 31.17 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 5 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 742 AC Mode Efficiency Rating (100% Load) 92% COMMUNICATIONS Network Management Cards  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure communications PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 160V (70-100% load), 130V (30-70% load), 100V (less than 33% load) High Voltage Transfer to Battery Power (Setpoint) 288V FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries; Remote management; Surge/noise protection; Zero transfer time Green Energy-Saving Features High efficiency economy mode operation; Individually controllable load banks Grounding Lug Grounding screw STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CSA (Canada); UL 1778 Product Compliance RoHS; CE (Europe); EAC (Belarus, Kazakhstan, Russia); REACH; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SUINT3000RTXL2U 价格&库存
很抱歉,暂时无法提供与“SUINT3000RTXL2U”相匹配的价格&库存,您可以联系我们找货
