1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 120V 3kVA 2.4kW DoubleConversion UPS, 3U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial
Highlights
3000VA / 3kVA / 2400 watt online double-conversion 3U
rack/tower UPS
120V +/-2% output at 50/60Hz,
high efficiency economy mode
option
Expandable runtime, Hot-swap
batteries, 26 in. / 66cm installed
depth
USB, RS232 & EPO ports; slot
for network management card
options
Front panel status LEDs with
detailed load and battery
metering
2 independently switchable
output load banks
NEMA L5-30P input; L5-30R, 515/20R & 5-15R outlets
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
MODEL NUMBER: SU3000RTXL3U
Description
3000VA on-line, double-conversion UPS system for critical server, network and telecommunications
equipment. 3U rackmount form factor with an installed depth of 26 inches. Expandable battery runtime
with optional BP72V15-2U (limit 1), BP72V28RT-3U (multi-pack compatible) and BP72V18-2US (multipack compatible) external battery packs. Full time sine wave 120V output with +/-2% voltage regulation.
Online, double-conversion Uninterruptible Power Supply (UPS) actively converts raw incoming AC power
to DC, then re-converts output back to completely regulated, filtered AC output. Operates continuously
without using battery power during brownouts to 65V and overvoltages to 150V. Highly efficient operation
in optional economy mode saves BTU heat output and energy costs. NEMA L5-30P input plug. NEMA 515, NEMA 5-15/20R and NEMA L5-30R output receptacles. Network-grade AC surge and noise
suppression. Zero transfer time between AC and battery operation. Network management interfaces
support simultaneous communications via USB port, DB9 serial port and slot for network management
card options. Built-in DB9 port offers both enhanced RS-232 enabled monitoring data, plus contact
closure monitoring ability. HID-compliant USB interface enables integration with built-in power
management and auto shutdown features of Windows and Mac OS X. Supports simultaneous detailed
monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces.
PowerAlert UPS monitoring software is available via free download. Emergency Power Off (EPO)
interface. Integrated two-bank PDU switching supports load shedding and remote reboot of connected
equipment. 3-stage metered current monitoring and battery charge status LEDs. LED display panel easily
rotates for viewing in rackmount or tower configurations. Dataline surge suppression for dialup, DSL or
network Ethernet connection. Utility power and voltage regulation LEDs. Audible alarm. Self-test. Faulttolerant auto-bypass mode. 4-post rackmount accessories included; 2-9USTAND tower kit and
2POSTRMKITHD 2-post rackmount accessories available. Field-replaceable, hot-swappable internal
batteries and external battery packs. Attractive all-black color scheme. $250,000 Ultimate Lifetime
Insurance (U.S., Canada, and Puerto Rico only).
Features
SmartOnline high performance UPS system is ideal for critical voice, data, medical and industrial
network applications
True on-line, double-conversion UPS provides perfectly regulated sine wave output within 2% of 120V
under all usage conditions
Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer
time
Highly efficient operation in optional economy mode setting, saving BTU heat output and energy costs
1/7
Package Includes
SU3000RTXL3U UPS System
USB, DB9 and EPO cabling
Mounting hardware for 4 post
rack enclosures
Instruction manual
Cleveland, OH 44122
United States
Removes harmonic distortion, fast electrical impulses, frequency variations and other hard to solve
power problems not addressed by other UPS types
Corrects line voltage conditions as low as 65V and as high as 150V back to 120V (+/-2%) values
Standard internal battery set offers 14 minutes runtime at half load (1200W) and 5 minutes at full load
(2400W)
Expandable battery runtime with optional BP72V15-2U (limit 1), BP72V28RT-3U (multi-pack
compatible) and BP72V18-2US (multi-pack compatible) external battery packs
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Intelligent battery management system extends battery life
Compact rackmount form factor installs using only 3 rack spaces (3U) with a maximum installed depth
of 26 inches
Ships with all mounting accessories for 4 post rackmount installation
Optional 2POSTRMKITHD enables 2 post rackmount installation (not wallmount compatible)
Optional 2-9USTAND accessory enables small-footprint upright tower placement
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Network interfaces support simultaneous communications via built-in USB, DB9 serial / contact-closure
and slot for network management card options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
HID compliant USB interface enables integration with built-in power management and auto shutdown
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Built-in Emergency Power Off (EPO) interface with cable
NEMA L5-30P input plug; NEMA 5-15/20R & L5-30R output receptacles
Integrated 2 bank switched PDU enables remote outlet management for load shedding or remote reboot
of individual load banks (each bank has four outlets)
Front panel LEDs offer current monitoring and battery charge level information
UPS ships fully assembled in full compliance with DOT regulations; no time consuming connection of
internal batteries by user required
Single line TEL/DSL or network ethernet line surge suppression
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332117991
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
L5-30P
2/7
Cleveland, OH 44122
United States
Input Circuit Breakers
40A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A 120V
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2400
Output Capacity (kW)
2.4
Output Capacity Details
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0.8
Crest Factor
3:1
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Load Management Receptacles
Two switchable four-outlet load banks, (bank 1 - four 5-15/20R, bank 2 - four 5-15R outlets)
Output Circuit Breakers
15A branch rated (x2) - each breaker protects 4 outlets, L5-30R is unbreakered
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(4) 5-15R; (4) 5-15/20R; (1) L5-30R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5 min. (2400W)
Runtime Half Load (min.)
14 min. (1200W)
Expandable Runtime
Yes
3/7
Cleveland, OH 44122
United States
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible); BP72V18-2US (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC96-3U (quantity 1)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 150
Undervoltage Correction
2% output voltage regulation during undervoltages to 80
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 65 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
510
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
3U
Cooling Method
Fan
Included Mounting Accessory
Description
Includes 4 post rackmount installation accessories
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
4/7
Cleveland, OH 44122
United States
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
73.66
(inches)
29
Minimum Required Rack Depth with
External Battery Pack (cm)
81
External Battery Pack (in.)
32
without External Battery Pack (cm)
79
without External Battery Pack (in.)
31
Primary UPS Depth (mm)
660
Primary UPS Height (mm)
132
Primary UPS Width (mm)
452
Shipping Dimensions (hwd / in.)
10.00 x 23.00 x 33.00
Shipping Dimensions (hwd / cm)
25.40 x 58.42 x 83.82
Shipping Weight (lbs.)
112.00
Shipping Weight (kg)
50.80
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.21 x 45.21 x 66.04
(hwd, in.)
5.2 x 17.8 x 26
UPS Power Module Weight (kg)
33.48
UPS Power Module Weight (lbs.)
73.8
Unit Weight (lbs.)
73.8500
Unit Weight (kg)
33.50
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1117
AC Economy Mode BTU / Hr. (Full
Load)
523
Battery Mode BTU / Hr. (Full Load)
1224
AC Economy Mode Efficiency Rating
(100% Load)
94%
5/7
Cleveland, OH 44122
United States
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable
connection OR via select Network Management Card options
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
80V (100% load), 65V (
