1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240V 3kVA 2.4kW DoubleConversion UPS, 3U Rack/Tower, Extended Run,
Network Card Options, DB9 Serial
Highlights
3000VA / 3kVA / 2400 watt online double-conversion 3U
rack/tower UPS
208/240V +/-2% output at
50/60Hz
Expandable runtime, Hotswappable battery modules
RS232 port; slot for network
management card options
Front panel status LEDs with
detailed load and battery
metering
NEMA L6-20P input; 6-15/20R &
L6-20R outlets
MODEL NUMBER: SU3000RTXL3UHV
Package Includes
Description
3000VA / 3kVA on-line, double-conversion UPS system for critical server, network and
telecommunications equipment. 3U rackmount form factor with an installed depth of 20 inches (50.8cm).
Expandable battery runtime with optional external battery packs BP72V15-2U (limit 1), BP72V28RT-3U
(multi-pack compatible) and BP72V18-2US (multi-pack compatible). Full time sine wave
200/208/220/240V AC output with +/-2% voltage regulation. Online, double-conversion Uninterruptible
Power Supply (UPS) actively converts raw incoming AC power to DC, then re-converts output back to
completely regulated, filtered AC output. Operates continuously without using battery power during
brownouts to 130V and overvoltages to 275V. NEMA L6-20P input plug. NEMA 6-15/20R & L6-20R output
receptacles. Network-grade AC surge and noise suppression. Zero transfer time between AC and battery
operation. Network management interfaces support simultaneous communications via DB9 serial port and
slot for network management card options. Built-in DB9 port offers both enhanced RS-232 enabled
monitoring data, plus contact closure monitoring ability. Supports simultaneous detailed monitoring of
equipment load levels, self-test data and mains power conditions via all network interfaces. PowerAlert
UPS monitoring software is available via free download. Integrated two bank PDU switching supports load
shedding and remote-reboot of connected equipment. Multi-stage metered current monitoring and battery
charge status LEDs. Mains power and voltage regulation LEDs. Audible Alarm. Self-test. Fault-tolerant
auto-bypass mode. 4 post rackmount accessories included; 2-9USTAND tower kit and 2POSTRMKITWM
2-post rackmount accessories available. Field replaceable, hot swappable internal batteries and external
battery packs. Attractive all-black UPS design. $250,000 Ultimate Lifetime Insurance (U.S., Canada, and
Puerto Rico only).
Features
True on-line, double conversion UPS provides pure, sine wave AC output at all times
Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer
1/6
SU3000RTXL3UHV RackTower UPS System
DB9 Cable
Mounting hardware for 4 post
rackmount enclosures
Warranty information
Instruction manual
Cleveland, OH 44122
United States
time
Removes harmonic distortion, electrical impulses, frequency variations and other hard to solve power
problems
Accepts input voltages between 160 and 275 (130 to 275 at loads under 70%), regulating output to
selectable 200/208/220/240V +/-2%
3000VA/2400 watt power capacity with 8 total outlets (6 NEMA6-15/20R & 2 NEMAL6-20R)
Standard internal battery set provides 14 minutes runtime at half load
Expandable runtime with external battery packs BP72V15-2U (limit 1), BP72V28RT-3U (multi-pack
Intelligent battery management system extends battery life
Innovative design makes unit adaptable for rackmount, tower, or stacking applications
Uses only 3 rack spaces (3U) in standard 19 inch rack
DB9 serial port for network interface
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Compatible with Tripp Lite's Watchdog Service Monitoring/Reboot Software
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Diagnostic LEDs
Battery replacement door
Mounting hardware included for 4 post rack enclosures, tower placement supported with optional 29USTAND accessory, 2 post telecom rack compatible with optional 2POSTRMKITHD accessory
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332118035
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
14.9A (200V), 14.3A (208V), 13.1A (220V), 12.1A (240V)
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 240V AC
UPS Input Connection Type
L6-20P
Input Circuit Breakers
25A double pole
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
20A
OUTPUT
2/6
Cleveland, OH 44122
United States
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2400
Output Capacity (kW)
2.4
Output Capacity Details
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0.8
Crest Factor
3:1
Nominal Voltage Details
208V default
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Load Management Receptacles
Two switchable 6-15/20R load banks (bank 1 - two outlets, bank 2 - four outlets)
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 208V; 220V; 240V
Output Receptacles
(6) 6-15/20R; (2) L6-20R
Individually Controllable Load Banks
Yes
BATTERY
Runtime Full Load (min.)
5 min. (2400w)
Runtime Half Load (min.)
14 min. (1200w)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V18-2US (multi-pack compatible); BP72V28RT-3U (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC96-3U
Battery Replacement Description
Hot-swappable, user replaceable batteries
3/6
Cleveland, OH 44122
United States
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
Maintains output during overvoltages to 275
Undervoltage Correction
Maintains output during undervoltages to 160V AC
Severe Undervoltage Correction
At load levels less than 70%, UPS maintains output during undervoltages to 130V AC
USER INTERFACE, ALERTS & CONTROLS
Switches
2 switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, bypass mode, on-battery, overload, battery low, replace battery and fault
status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in rack/tower
formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
2670
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL or Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
3U
Cooling Method
Fan
Included Mounting Accessory
Description
Includes 4 post rackmount installation accessories
Installation Form Factors Supported
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
66.04
(inches)
26
Primary UPS Depth (mm)
533
Primary UPS Height (mm)
133
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
26.00 x 13.00 x 24.00
Shipping Dimensions (hwd / cm)
66.04 x 33.02 x 60.96
Shipping Weight (lbs.)
96.60
4/6
Cleveland, OH 44122
United States
Shipping Weight (kg)
43.82
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.34 x 44.45 x 53.34
(hwd, in.)
5.25 x 17.5 x 21
UPS Power Module Weight (kg)
33.97
UPS Power Module Weight (lbs.)
74.9
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1117
Battery Mode BTU / Hr. (Full Load)
1224
AC Mode Efficiency Rating (100%
Load)
88%
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable
connection OR via select Network Management Card options
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
Contact closure; DB9 Serial; Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
160V (100% load), 130V (
