SMART1200XLHGL
SMART1200XLHGL
    TRIPPLITE
    SMARTPRO120V1KVA750WMEDICAL-
SMART1200XLHGL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1kVA 750W Medical-Grade LineInteractive Tower UPS with 4 Outlets, Full Isolation, USB, Lithium Battery MODEL NUMBER: SMART1200XLHGL Highlights ● 28 min. runtime at half load; 10 min. at full load ● Reduces cumulative leakage current to under 100 A ● Approved for use within the Patient Care Vicinity ● Approved to EN60601-1-2:2015 & IEC60601-1-2:2014, 4th Edition ● 940 joules of surge protection ● 10,000-cycle LiFePO4 battery Package Includes Provides UL 60601-1 compliant, medical-grade 1kVA/750W power backup, ideal for use in patient-care vicinities. Lithium Iron Phosphate batteries provide 20–30 times the cycle life of traditional batteries. Description Tripp Lite’s SMART1200XLHGL medical-grade UPS system provides dependable lithium iron phosphate (LiFePO4) battery backup, so you can work through short power failures and perform an orderly system shutdown in a prolonged blackout. It’s fully compliant with UL 60601-1 regulations when plugged into a hospital-grade outlet, making it ideal for use in patient-care vicinities. The 1kVA/750W capacity provides up to 28 minutes of runtime for a half load and 10 minutes for a full load. Built-in line-interactive voltage regulation corrects brownouts as low as 81V and overvoltages as high as 143V to normal 120V nominal output, without drawing battery power. A built-in isolation transformer with Faraday shield offers full isolation and removes common mode noise while maintaining full AC surge suppression in all modes. It also reduces the cumulative leakage current of connected equipment to less than 100 A. Floating AC output prevents noise coupling from noisy hospital ground systems. This UPS system features four NEMA 5-15R-HG hospital-grade outlets and has a hospital-grade NEMA 5-15P-HG plug with a six-foot cord for flexibility in placement. All four outlets provide both backup protection and 940 joules of surge protection. The SMART1200XLHGL also features diagnostic LEDs, as well as a USB port and a DB9 serial port that work with Tripp Lite’s free downloadable PowerAlert® software for safe, unattended system shutdown and file saves in the event of a prolonged power failure. Features Provides Ideal UPS Backup in Healthcare FacilitiesCompliant with UL 60601-1 standards for use in patient-care vicinities when plugged into a hospital-grade outletBuilt-in isolation transformer with Faraday shield offers full isolation and reduces cumulative leakage current of connected equipment to less than 100 AHospital-grade NEMA 5-15P-HG plug with 6 ft. cord provides flexibility in placement Battery Backup and Full Surge ProtectionSupports half load for 28 min. and full load for 10 min. with standard LiFePO4 internal batteryHospital-grade NEMA 5-15R-HG outlets provide 940 joules of surge protectionEMI/RFI noise filtering ensures equipment runs smoothly without line noise interferenceResistant to electrostatic discharge10,000-cycle LiFePO4 battery LEDs and Audible Alarms Keep You Aware of Power StatusIndicator lights monitor when the UPS is on and supplying utility power, when operating in voltage correction mode or in battery mode, relative load level and low-battery warningAudible alarms alert you to power failure, overload and low battery conditionsMute/quiet mode ensures “alarm fatigue” compliance 1/5 ● SMART1200XLHGL 1kVA/750W Medical-Grade Tower UPS System ● USB monitoring cable, 6 ft. ● DB9 serial monitoring cable, 6 ft. ● 5 yr. warranty on UPS and batteries ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Saves Your Files, Even When You’re AwayWorks with Tripp Lite PowerAlert software (available as a free download) to enable safe, unattended system shutdown and files saves during prolonged power failuresConnects to your computer via DB9 or USB port Specifications OVERVIEW UPC Code 037332192202 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 9.2A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P-HG Input Circuit Breakers 15A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity (VA) 1000 Output Capacity (kVA) 1 Output Capacity (Watts) 750 Output Capacity (kW) 0.75 Power Factor 0.8 Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) 115V (+/- 5%) Output Receptacle Details Hospital grade output receptacles Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 115V; 120V 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Receptacles (4) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Lithium Ion Runtime Full Load (min.) 10 min. (750W) Runtime Half Load (min.) 28 min. (375W) Expandable Runtime No DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge RBC53L VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 81 to 143 Overvoltage Correction Input voltages between 126 and 143 are reduced by 9% Undervoltage Correction Input voltages between 96 and 106 are boosted by 10% Severe Undervoltage Correction Input voltages between 81 and 95 are boosted by 21% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Factory-muted audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status ISOLATION Output Isolation Transformer Hospital grade load isolation transformer Leakage Current Less than 100 microamps SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 940 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 940 PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 241 Primary UPS Height (mm) 318 Primary UPS Width (mm) 191 Shipping Dimensions (hwd / in.) 17.00 x 11.40 x 13.10 Shipping Dimensions (hwd / cm) 43.18 x 28.96 x 33.27 Shipping Weight (lbs.) 36.54 Shipping Weight (kg) 16.57 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 31.75 x 19.05 x 24.13 UPS Power Module Dimensions (hwd, in.) 12.5 x 7.5 x 9.5 UPS Power Module Weight (kg) 15.24 UPS Power Module Weight (lbs.) 33.6 Unit Weight (lbs.) 33.6000 Unit Weight (kg) 15.24 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 162.8 Battery Mode BTU / Hr. (Full Load) 315.2 AC Mode Efficiency Rating (100% Load) 94% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 serial cabling included Network Management Card Description Network management not supported Communications Interface USB; DB9 Serial 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 81 High Voltage Transfer to Battery Power (Setpoint) 143 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries; Surge/noise protection Grounding Lug Grounding lug (equipotential) STANDARDS & COMPLIANCE Product Certifications CSA (Canada); UL 1778; UL 60601-1 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART1200XLHGL 价格&库存
很抱歉,暂时无法提供与“SMART1200XLHGL”相匹配的价格&库存,您可以联系我们找货
