1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 120V 3kVA 2.4kW DoubleConversion UPS, 3U, Oversize Batteries, Network
Card Slot, USB, DB9, Hardwire
Highlights
3000VA / 3kVA / 2400 watt online double-conversion 3U rack /
tower UPS
120V +/-2% output at 50/60Hz,
high efficiency economy mode
option
Oversize internal batteries,
Expandable runtime, Hotswappable batteries
USB, RS232 & EPO ports; slot
for network management card
options
Front panel status LEDs with
detailed load and battery
metering
Hardwire input & output
connections
MODEL NUMBER: SU3000RTXR3UHW
Package Includes
Description
3000VA / 3kVA online, double-conversion UPS system in 3U rackmount form factor for critical server,
network and telecommunications equipment. 3U rackmount form factor with an installed depth of 29.5
inches (75cm). Expandable battery runtime with optional BP72V15-2U (limit 1), BP72V28RT-3U (multipack compatible) and BP72V18-2US (multi-pack compatible) external battery packs. Full time sine wave
120V output with +/-2% voltage regulation. Online, double-conversion Uninterruptible Power Supply (UPS)
actively converts raw incoming AC power to DC, then re-converts output back to completely regulated,
filtered AC output. Operates continuously without using battery power during brownouts to 65V and
overvoltages to 150V. Hardwired AC input and output (L-N-G, 120V). Highly efficient operation in optional
economy mode setting, saves BTU heat output and energy costs. Network-grade AC surge and noise
suppression. Zero transfer time between AC and battery operation. Network management interfaces
support simultaneous communications via USB port, DB9 serial port and slot for network management
card options. Includes USB and DB9 serial ports. Built-in DB9 port offers both enhanced RS-232 enabled
monitoring data, plus contact closure monitoring ability. HID-compliant USB interface enables integration
with built-in power management and auto shutdown features of Windows and Mac OS X. Supports
simultaneous detailed monitoring of equipment load levels, self-test data and mains power conditions via
all 3 network interfaces. PowerAlert UPS monitoring software is available via free download. Emergency
Power Off (EPO) interface. Multi-stage metered current monitoring and battery charge status LEDs. LED
display panel easily rotates for better viewing in rackmount or tower configurations. Dataline surge
suppression for dialup, DSL or network ethernet connection. Mains power and voltage regulation LEDs.
Audible Alarm. Self-test. Fault-tolerant auto-bypass mode. 4 post rackmount accessories included; 29USTAND tower kit and 2POSTRMKITHD 2-post rackmount accessories available. Field replaceable, hot
swappable internal batteries and external battery packs. Attractive all-black UPS design. $250,000
Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only).
Features
3000VA / 3kVA / 2400 watt online, double-conversion UPS system in 3U rackmount form factor for
critical server, network and telecommunications equipment
True online, double-conversion UPS provides perfectly regulated sine wave output within 2% of 120V
under all usage conditions
Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer
time
Removes harmonic distortion, fast electrical impulses, frequency variations and other hard to solve
power problems not addressed by other UPS types
1/6
SU3000RTXR3UHW UPS
System
USB, DB9 and EPO cabling
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Corrects line voltage conditions as low as 65V and as high as 150V back to 120V (+/-2%) values
Highly efficient operation in optional economy mode setting, saving BTU heat output and energy costs
Internal battery set offers 30 minutes runtime at half load (1200W) and 12 minutes at full load (2400W)
Optional BP72V15-2U (limit 1), BP72V28RT-3U (multi-pack compatible) and BP72V18-2US (multi-pack
Intelligent battery management system extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Compact rackmount form factor installs using only 3 rack spaces (3U) with a maximum installed depth
of 26 inches
Ships with all mounting accessories for 4 post rackmount installation
Optional 2POSTRMKITHD enables 2 post rackmount installation
Optional 2-9USTAND accessory enables small-footprint upright tower placement
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Network interfaces support simultaneous communications via built-in USB, DB9 serial/contact-closure
and slot for network management card options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
HID compliant USB interface enables integration with built-in power management and auto shutdown
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Built-in Emergency Power Off (EPO) interface with cable
Hardwire 120V AC input/output (L-N-G)
Front panel LEDs offer current monitoring and battery charge level information
Single line TEL/DSL or network ethernet line surge suppression
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332164636
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
Hardwire
Recommended Electrical Service
30A 120V (L-N-G)
OUTPUT
Output Capacity (VA)
3000
2/6
Cleveland, OH 44122
United States
Output Capacity (kVA)
3
Output Capacity (Watts)
2400
Output Capacity (kW)
2.4
Output Capacity Details
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0.8
Crest Factor
3:1
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
Hardwire
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
12 min. (2400W)
Runtime Half Load (min.)
30 min. (1200W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible); BP72V18-2US (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC96-3U (quantity 2)
Battery Replacement Description
Hot-swappable, user replaceable batteries
3/6
Cleveland, OH 44122
United States
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 150
Undervoltage Correction
2% output voltage regulation during undervoltages to 80
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 65 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
3U
Cooling Method
Fan
Included Mounting Accessory
Description
Includes 4 post rackmount installation accessories
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
73.66
(inches)
29
Minimum Required Rack Depth with
External Battery Pack (cm)
90
External Battery Pack (in.)
35.5
without External Battery Pack (cm)
75
4/6
Cleveland, OH 44122
United States
without External Battery Pack (in.)
29.5
Optional Mounting Accessory Notes
Wallmount installation not recommended
Primary UPS Depth (mm)
749
Primary UPS Height (mm)
132
Primary UPS Width (mm)
452
Shipping Dimensions (hwd / in.)
12.00 x 23.50 x 33.00
Shipping Dimensions (hwd / cm)
30.48 x 59.69 x 83.82
Shipping Weight (lbs.)
150.00
Shipping Weight (kg)
68.04
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.21 x 45.21 x 74.93
(hwd, in.)
5.2 x 17.8 x 29.5
UPS Power Module Weight (kg)
50.48
UPS Power Module Weight (lbs.)
111.3
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius.
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1117
AC Economy Mode BTU / Hr. (Full
Load)
253
Battery Mode BTU / Hr. (Full Load)
1224
AC Mode Efficiency Rating (100%
Load)
88%
AC Economy Mode Efficiency Rating
(100% Load)
97%
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable
connection OR via select Network Management Card options
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
5/6
Cleveland, OH 44122
United States
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
80V (100% load), 65V (
