1000 Eaton Boulevard
Cleveland, OH 44122
United States
120V 2200VA 1600W A/V Pure Sine Wave UPS,
Extended Run, 3U Rack-Mount, DB9 Serial, 9
Outlets
Highlights
2200VA/1600W on-line, doubleconversion, extended-run UPS;
rackmount hardware included
9 outlets; 2 switchable load
banks
IP remote access, control and
diagnostics capability with email
notification (built-in accessory
slot, SNMPWEBCARD available
separately)
Zero transfer time to battery
takes incoming AC power and
remakes it into perfect output
power with a pure sine wave
Maintains sine wave 100/110 or
120V +/-2% output during
overvoltages to 138 and
brownouts as low as 65V
(50/60Hz auto-sensing)
Pure Sine Wave operation
completely isolates connected
components from power
problems
Drivers written for Crestron,
AMX and Savant for seamless
integration
$250,000 Ultimate Lifetime
Insurance (U.S., Canada, and
Puerto Rico only)
MODEL NUMBER: HTR22-3U
Description
Tripp Lite's HTR22-3U Pure Sine Wave 2200VA/1600W on-line, double-conversion UPS system prevents
media data loss, equipment freeze-ups, downtime and equipment damage due to power outages, voltage
fluctuations and transient surges. Provides full-time sine wave 100, 110 or 120V +/-2% output with zero
transfer time between AC and battery operation. Actively converts raw incoming AC power to DC, then re-
Package Includes
HTR22-3U Audio/Video Pure
Sine Wave UPS System
PowerAlert Software and
cabling
load runtime and 6 min. full load runtime; runtime is expandable with optional BP72V15-2U and
Optional-use NEMA 5-15P Plug
BP72V28RT-3U external battery packs. 2200VA/1600W power handling capacity is compatible with
Mounting hardware for 4-post
rack enclosures
Instruction manual with warranty
information
converts output back to completely regulated, filtered AC output. Operates continuously without using
battery power during brownouts to 65V and overvoltages to 138V. Network-grade AC surge and EMI/RFI
line noise suppression. Requires only 3 rack spaces (3U). Large internal batteries provide 18 min. half-
audio/video components and other sensitive electronic applications. Includes 9 UPS-supported outlets
arranged in two switchable load banks that can be individually controlled via software interface to reboot
selected equipment on demand or automatically shed less significant loads to extend battery runtime for
more critical equipment. Supports real time UPS communications via DB9 serial port or SNMPWEBCARD
slot for the ultimate in IP remote access, control and diagnostics capability with email notification.
Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via both
network interfaces. Includes PowerAlert monitoring software and complete cabling. Multi-function audible
alarms and front-panel LEDs provide at-a-glance notification of UPS and line power status. Attractive allblack color scheme. $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Features
HTR22-3U Pure Sine Wave UPS provides perfectly regulated sine wave output within 2% of 120V
under all usage conditions
2200VA/1600W power handling capacity compatible with control systems, HD sources, Audio/Video
editing suites, digital consoles, DVD/music/PCs/servers, RAIDs, media centers, PVRs/DVRs,
boardrooms, digital processors/EFX, racks and other sensitive electronics
1/5
Cleveland, OH 44122
United States
Removes harmonic distortion, fast electrical impulses, frequency variations and other hard-to-solve
power problems not addressed by other UPS types
Corrects line voltage conditions as low as 65V and as high as 138V back to 120V (+/-2%) values
2 switchable load banks (each with 4 outlets) enable remote outlet management for load shedding or
remote reboot of individual devices from anywhere in the world
Standard internal battery set offers 18 min. runtime at half load (800W) and 6 min. at full load (1600W)
Optional BP72V15-2U external battery pack increases runtime to 98 min. at half load (800W) and 41
min. at full load (1600W); limit 1
Optional BP72V28RT-3U external battery pack increases runtime to 160 min. at half load (800W) and
69 min. at full load (1600W); multi-pack compatible
Fault-tolerant auto-bypass maintains continuous utility output to connected equipment, even in cases
where the UPS suffers internal failure and requires maintenance
Offers complete UPS monitoring through included DB9 interface or SNMP interface (requires optional
SNMPWEBCARD), or the monitoring of any number of additional UPS systems over IP with included
PowerAlert UPS monitoring and unattended shutdown software enables configurable network broadcast
messaging, pager and email notification, event logging and running user-defined script commands
Front panel LEDs offer current monitoring and battery charge level information
UPS ships fully assembled in full compliance with DOT regulations; no time-consuming connection of
internal batteries by user required
Specifications
OVERVIEW
UPC Code
037332134875
INPUT
Rated input current (Maximum Load)
16A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-20P
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
120V 20A dedicated circuit
Voltage Compatibility (VAC)
120
OUTPUT
Output Capacity (VA)
2200
Output Capacity (Watts)
1600
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup
Output Voltage Regulation (Line
Mode)
+/- 2%
2/5
Cleveland, OH 44122
United States
Load Management Receptacles
Two switchable four-outlet load banks (bank 1 - four 5-15R outlets, bank 2 - four 5-15/20R outlets)
Output Circuit Breakers
15A branch rated breakers (x2) protect 4 outlets each, L5-20R outlet is unbreakered
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(4) 5-15R; (4) 5-15/20R; (1) L5-20R
BATTERY
Runtime Full Load (min.)
7 min. (1600w)
Runtime Half Load (min.)
18 min. (800w)
Expandable Runtime
Yes
Expandable Runtime Description
Supports extended runtime with optional external battery packs BP72V15-2U (limit 1) and BP72V28RT-3U (multipack compatible)
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80%
Battery Access
Hot-swap battery replacement supported via front access panel
Internal UPS Replacement Battery
Cartridge
RBC96-3U (quantity 1)
Typical Battery Lifespan
3-6 years, depending on usage
VOLTAGE REGULATION
Voltage Regulation Description
On-line, double-conversion power conditioning maintains output within 2% of 100/110/120 volts at all times
Overvoltage Correction
Maintains output of selected nominal +/-2% during overvoltages to 138V AC
Undervoltage Correction
2% output voltage regulation during undervoltages to 80
Severe Undervoltage Correction
Maintains output within 2% of nominal during undervoltages to 65 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
Power off/on switch and battery charge/load level display select switch
Audible Alarm
Multi-function audible alarm with distinctive ring patterns offer notification of backup operation (2 sec. on / 0.5 sec.
off), low battery warning (1.25 sec. on / 0.5 sec. off), overload (sounds continuously), UPS fault (4.2 sec. on / 1 sec.
off), input voltage out of frequency (2.1 sec. on / 0.14 sec. off) and high input voltage (2.1 sec. on 0.07 sec. off)
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
1014
3/5
Cleveland, OH 44122
United States
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
PHYSICAL
Cooling Method
Built-in cooling fan
Installation Form Factors Supported
with Optional Accessories
2 post rackmount ( 2POSTRMKITWM ); Tower
( 2-9USTAND )
Primary UPS Depth (mm)
521
Primary UPS Height (mm)
132
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
25.40 x 23.40 x 13.10
Shipping Dimensions (hwd / cm)
64.52 x 59.44 x 33.27
Shipping Weight (lbs.)
94.20
Shipping Weight (kg)
42.73
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.21 x 44.45 x 52.07
(hwd, in.)
5.2 x 17.5 x 20.5
UPS Power Module Weight (kg)
33.97
UPS Power Module Weight (lbs.)
74.9
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
812.9
Battery Mode BTU / Hr. (Full Load)
885.6
COMMUNICATIONS
WatchDog Compatibility
Compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot
of application / OS or hard power off/on reboot of connected equipment - ideal for unattended kiosk applications
EPO Port
Supports Emergency Power Off function via set of dedicated built-in EPO jacks
SNMP Compatibility
Slot for optional SNMPWEBCARD accessory (Tripp Lite Model # SNMPWEBCARD)
Communications Interface
DB9 Serial; Contact closure; EPO (emergency power off); Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
4/5
Cleveland, OH 44122
United States
Low Voltage Transfer to Battery
Power (Setpoint)
80V (100% load), 65V (
