SU5000RT4U
SU5000RT4U
    TRIPPLITE
    UPS 5KVA 3800W 12OUT RACK MOUNT
SU5000RT4U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 208/240 & 120V 5kVA 3.8kW DoubleConversion UPS, 4U Rack/Tower, Extended Run, Network Card Options, USB, DB9 Serial, Bypass Switch MODEL NUMBER: SU5000RT4U Highlights ● 5kVA / 5000VA / 3800W on-line double-conversion 4U rack/tower UPS, Sine Wave ● Included maintenance bypass switch enables live replacement of UPS with zero downtime ● Extended runtime options, Interactive LCD interface ● USB, RS232 & EPO ports; Slot for network management card options ● NEMA L14-30P 208/240V 60Hz input (4 wire split phase); L630R, L6-20R (208/240V) & 515/20R (120V) outlets System Requirements ● Electrical Service: 125/250V, 4wire, split phase, 30A ● Communication Interface: serial DB-9 or USB ● Compatible with all standard 19in. equipment Package Includes Description ● SU5000RT4U UPS System (with SUPDMB56 detachable PDU module) ● USB, DB9 and EPO cabling ● Rackmount installation kit for 4 post rack enclosures ● Owner's manual and warranty information Tripp Lite 5kVA SmartOnline Hot-Swappable Modular Rack/Tower UPS. 5000VA on-line, doubleconversion UPS for server, network and telecommunications equipment. Maintains battery-derived AC output during blackouts with active, full-time power conditioning. Fault tolerant auto-bypass prevents unexpected service interruptions during overload or internal fault conditions. Single all-in-one housing installs in 4 rack spaces (4U). Upright tower installation with optional 2-9USTAND accessory. 2-post rackmount installation with optional 2POSTRMKITHD. Full-time sine wave output within 3% of selectable 208/120 or 240/120V AC. Corrects brownouts and overvoltages from 65V to 140V (L-N). Expandable runtime with optional external battery packs. Dual-conversion UPS converts raw input from AC to DC, then back to perfect sine wave AC output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS types. Highly efficient operation in optional economy mode setting, saving BTU heat output and energy costs. Networkgrade AC surge and noise suppression. Network management interfaces include combination RS-232 enabled and contact closure serial port, enhanced USB port and slot for network management card options. Includes USB and DB9 serial ports. Built-in DB9 port offers both enhanced RS-232 enabled monitoring data, plus contact closure monitoring ability. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports simultaneous detailed monitoring of equipment load levels, self-test data and mains power conditions via all 3 network interfaces. PowerAlert monitoring software is available via free download. Emergency Power Off (EPO) interface. Front panel LEDs and LCD readout with scroll controls support visual monitoring of all major UPS functions. LED/LCD display panel easily rotates for viewing in rackmount or tower configurations. Audible alarm. Self test. 4-post rackmount accessories. Includes NEMA L14-30P split phase 4 wire input plug and 12 total output receptacles (2 L6-30R, 2 L6-20R and 8 5-15/20R). Input cord and outlets are mounted on a detachable backplate with manual bypass switch to enable hot-swappable 1/7 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS replacement without powering off connected equipment. Optional SUPDMB568HW detachable backplate accessory enables hardwire input-output connections to the UPS. Additional external Power Distribution Unit (PDU) options available. Internal batteries and optional external battery packs are field replaceable and hot swappable. Attractive all-black color scheme. $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● True on-line, double-conversion UPS provides pure, full-time sine wave AC output free of surges, voltage fluctuations and line noise ● 5000VA/3800 watt output power capacity with dual voltage output of 208/120 or 240/120V ● 4U all-in-one high power density housing supports rackmount installation in only 4 rack spaces ● Dual conversion UPS actively converts raw input from AC to DC, then back to perfect sine wave AC output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-tosolve power problems not addressed by other UPS types ● Input cord and outlets are mounted on a detachable backplate with manual bypass switch to enable hotswappable UPS replacement without powering off connected equipment ● Provides perfectly regulated, sine wave output power free of line noise, transient surges and frequency variation for the most efficient operation of critical servers, networking and telecommunications equipment ● Maintains output within 3% of selected 208/120 or 240/120V nominal voltage during brownouts and overvoltages ● Supports connected equipment during blackouts for 14/6 minutes at half/full load levels, runtime is further expandable with optional external battery packs ● Intelligent battery management system extends battery life ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Network interfaces support simultaneous communications via DB9 port, USB port and slot for network management card options ● Compatible with Tripp Lite UPS management card options WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Includes USB and DB9 serial ports; Built-in DB9 port offers both enhanced RS-232 enabled monitoring data, plus contact closure monitoring ability ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. ● Built-in Emergency Power Off (EPO) interface with cable ● Includes 12 built-in output receptacles (2 L6-30R, 2 L6-20R, 8 NEMA 5-15/20R) ● L14-30P split phase, 4 wire plug-in connection (featured on included detachable PDU). Optional hardwire input/output PDU available separately ● Front panel LEDs and LCD readout with scroll button enables visual confirmation of all major UPS functions and current site electrical conditions ● Front panel switches enable power on/off control, self-test and alarm cancel functions ● Included adjustable mounting rails support installation in 4 post 19-inch rack enclosures ● Optional 2-9USTAND set of tower stands supports upright tower installation ● Optional 2POSTRMKITHD accessory enables 2-post rackmount installation ● UPS ships fully assembled in full compliance with DOT regulations, no time consuming connection of internal batteries by user is required ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Detachable PDU with built-in manual bypass switch enables hot-swappable UPS replacement without powering off connected equipment 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications OVERVIEW UPC Code 037332126481 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 21A Nominal Input Voltage(s) Supported 120/208V (Split phase L1,L2,N,G); 120/240V (Split phase L1,L2,N,G) UPS Input Connection Type L14-30P UPS Input Connection Description 4 wire split-phase input (L1, L2, N, G) UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 30A 208/120V Split Phase Input Cord Length (m) 3 OUTPUT Output Capacity (VA) 5000 Output Capacity (kVA) 5 Output Capacity (Watts) 3800 Output Capacity (kW) 3.8 Output Capacity Details Supports up to 105% load continuously in double conversion mode, 106 to 125% for 3 minutes, 126 to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support equipment directly from mains power; Double conversion mode is automatically restored as the overload is cleared Power Factor 0.8 Crest Factor 3:1 Nominal Voltage Details 240/120V or 208/120V split phase output Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) +/- 3% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 3% Output Circuit Breakers 20A branch rated breakers (x4) protect 2 5-15/20R outlets each, 20A double pole breakers (x2) protect one L6-20R each, L6-30R outlets are unbreakered 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V; 208V; 240V Output Receptacles (8) 5-15/20R; (2) L6-20R; (2) L6-30R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 6 min. (3800w) Runtime Half Load (min.) 14 min. (1900w) Expandable Runtime Yes External Battery Pack Compatibility  BP192V12-3U ;  BP192V5RT2U  (limit 1);  BP192V787C-1PH  DC System Voltage (VDC) 192 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 80% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC9-192  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description +/-3% output voltage regulation in online, double-conversion mode Overvoltage Correction Corrects overvoltages to 140 (measured L1-N : L2-N) Undervoltage Correction Corrects undervoltages to 65 (measured L1-N : L2-N) USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options; LED/LCD panel rotates for viewing in rack/tower formats Switches Includes main power off/on switch, plus 2 switches to set and execute scrollable LCD functions. A manual bypass switch featured on the detachable PDU allows for complete removal of the UPS during routine maintenance without disrupting power to connected loads. Battery Charge level switch allows the charger output to be adjusted to a higher charge rate when additional battery packs are added. Alarm Cancel Operation Alarm cancel switch Audible Alarm Unique audible alarms for all major UPS, environmental and power conditions (see manual) LED Indicators 6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD screen offers additional information and control options 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 1810 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 4U Cooling Method Fan Included Mounting Accessory Description Includes 4 post rackmount installation accessories Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Maximum Device Depth (cm) 77.72 Maximum Device Depth (in.) 30.6 Maximum Device Depth (mm) 777 Minimum Required Rack Depth with External Battery Pack (cm) 87 Minimum Required Rack Depth with External Battery Pack (in.) 34.2 Minimum Required Rack Depth without External Battery Pack (cm) 87 Minimum Required Rack Depth without External Battery Pack (in.) 34.2 Primary UPS Depth (mm) 777 Primary UPS Height (mm) 175 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 14.00 x 24.00 x 36.00 Shipping Dimensions (hwd / cm) 35.56 x 60.96 x 91.44 Shipping Weight (lbs.) 208.00 Shipping Weight (kg) 94.35 Unit Dimension Details MINIMUM REQUIRED RACK DEPTH specifications refer to the internal FRONT RAIL to REAR DOOR dimension a compatible rack enclosure is required to accommodate for the UPS configuration described; All minimum required rack depth figures include any additional distance required to accommodate connected equipment plugs UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 17.50 x 44.45 x 77.72 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Dimensions (hwd, in.) 6.89 x 17.5 x 30.6 UPS Power Module Weight (kg) 67.86 UPS Power Module Weight (lbs.) 149.6 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 1441 AC Economy Mode BTU / Hr. (Full Load) 827 Battery Mode BTU / Hr. (Full Load) 1283 AC Economy Mode Efficiency Rating (100% Load) 94% Operating Elevation (ft.) 0-3000m (0 to 10,000 ft.) Audible Noise 60 dBA at front side 1 meter Operating Elevation (m) 0-3000 m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description RS232 and contact closure communications are supported on one DB9 port PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 65V (L1-N:L2-N) High Voltage Transfer to Battery Power (Setpoint) 140V (L1-N:L2-N) FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported 6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Expandable battery backup; Hot swappable batteries; Hot swappable UPS power module; Manual bypass switch; On-Line/Double-Conversion; Remote management; Sine wave output; Surge/noise protection; Zero transfer time Green Energy-Saving Features High efficiency economy mode operation; Schedulable daily hours of economy mode operation WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
SU5000RT4U 价格&库存
很抱歉,暂时无法提供与“SU5000RT4U”相匹配的价格&库存,您可以联系我们找货
