SMX5000XLRT3U
SMX5000XLRT3U
    TRIPPLITE
    INTL UPS SYSTEM SMARTPRO RACK
SMX5000XLRT3U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 230V 5kVA 3.75kW Line-Interactive Sine Wave UPS, 3U, Extended Run, Network Card Options, USB, DB9 Highlights ● 5kVA / 5000VA line interactive 3U rack/tower UPS; Sine wave output ● 230V nominal output during brownouts to 170V and overvoltages to 282V ● Add optional WEBCARDLX with latest version of PADM20 for enhanced remote management ● 3U all-in-one chassis; 98% efficiency ● Hardwire input; 8 C13 & 3 C19 outlets MODEL NUMBER: SMX5000XLRT3U Package Includes Description 5000VA line interactive UPS system for server, network and telecommunications equipment. 5kVA UPS with internal batteries installs in only 3 rack spaces with a depth of only 635mm / 25 inches. High 98% line-power efficiency rating reduces energy consumption and BTU heat output. Expandable battery runtime with optional BP48V24-2U (limit 1), BP48V60RT-3U (multi-pack compatible) and BP48V27-2US (multi-pack compatible) external battery packs. Uninterruptible Power Supply (UPS) switches to batteryderived AC output during power failures and extreme voltage variations. Line interactive Automatic Voltage Regulation (AVR) offers voltage boost during brownouts and voltage reduction during overvoltage conditions to maintain regulated 230v output over an input range of 170-282V. Supports hardwire input. Includes C19 and C13 output receptacles. Network-grade AC surge and noise suppression. Network management interfaces support communications via USB, DB9 serial and slot for network management card options. Supports simultaneous detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces at once. PowerAlert UPS monitoring software is available via free download. Emergency Power Off (EPO) interface. 3-stage metered current monitoring and battery charge status LEDs. Utility power and voltage regulation LEDs. Audible alarm. Self-test. 4-post rackmount installation accessories included; 2-9USTAND tower kit and 2POSTRMKITHD two post rack mounting accessories available. Field-replaceable, hot-swappable internal batteries and external battery packs. Features ● 5000VA/3750 watt max. output power capacity compatible with International 230V input voltage ● 3U rack/tower UPS installs in standard 19 inch rack enclosures with an installed depth of only 635mm / 25in ● Protects sensitive networking equipment from blackouts, voltage fluctuations and transient surges ● Line Interactive Automatic Voltage Regulation (AVR) corrects 230V nominal input from 170 to 282VAC to usable 230V levels without consuming battery power ● AVR circuits boost undervoltages from 170 to 199V by 12% and reduce overvoltages from 245 to 282V by 12% ● Network interfaces support simultaneous communications via USB, DB9 serial or contact closure and slot for network management card options ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD ● Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware 1/6 ● SMX5000XLRT3U UPS system ● USB, DB9 and EPO Cabling ● Mounting hardware for 4 post rackmount installation ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States (PADM20) provides enhanced remote management capabilities ● PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Built-in Emergency Power Off (EPO) interface with cable ● Sine wave output in AC and battery mode ● Expandable runtime with optional BP48V24-2U (limit 1), BP48V60RT-3U (multi-pack compatible) and BP48V27-2US (multi-pack compatible) external battery packs ● Half/full load runtime of 20/8.5 minutes with internal batteries ● Intelligent battery management system extends battery life ● Includes 11 output receptacles (3 C19/8 C13) ● Hardwire input AC connection ● 3 stage metered LEDs offer current monitoring and battery charge level ● Mains power and voltage regulation LEDs offer at-a-glance power status information ● Front panel switches support self-test and alarm cancel functions ● Included adjustable mounting rails support installation in 4 post 19 inch racks ● Supports upright tower placement with optional 2-9USTAND accessory ● CE, GOST, SASO listed Specifications OVERVIEW UPC Code 037332121455 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 27A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type Hardwire UPS Input Connection Description Hardwire input supports International 230V input (L, N, PE) OUTPUT Output Capacity (VA) 5000 Output Capacity (kVA) 5 Output Capacity (Watts) 3750 Output Capacity (kW) 3.75 Power Factor 0.75 Nominal Voltage Details 230v nominal inverter output voltage 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) -17%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Included Output Power Cables Includes 3 C13 to C14 output power cables Output Circuit Breakers 15A (x3) breaker supports 1 C19 outlet each, 10A (x2) breaker supports 4 C13 outlets each Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (8) C13; (3) C19 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 8.5 min. (3750W) Runtime Half Load (min.) 20 min. (1875W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-3U  (quantity 3) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 170 to 282 Overvoltage Correction Input voltages between 245 and 282 are reduced by 12% Undervoltage Correction Input voltages between 170 and 199 are boosted by 12% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 3U Cooling Method Fans Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 71.12 Minimum Required Rack Depth (inches) 28 Minimum Required Rack Depth with External Battery Pack (cm) 81 Minimum Required Rack Depth with External Battery Pack (in.) 32 Minimum Required Rack Depth without External Battery Pack (cm) 72 Minimum Required Rack Depth without External Battery Pack (in.) 28.5 Primary UPS Depth (mm) 635 Primary UPS Height (mm) 132 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 11.25 x 22.52 x 31.50 Shipping Dimensions (hwd / cm) 28.58 x 57.20 x 80.01 Shipping Weight (lbs.) 182.00 Shipping Weight (kg) 82.55 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 13.21 x 44.45 x 63.50 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Dimensions (hwd, in.) 5.2 x 17.5 x 25 UPS Power Module Weight (kg) 64.86 UPS Power Module Weight (lbs.) 143 Unit Weight (lbs.) 143.3000 Unit Weight (kg) 65.00 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 271 Battery Mode BTU / Hr. (Full Load) 1267 AC Mode Efficiency Rating (100% Load) 98% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB LINE / BATTERY TRANSFER Transfer Time 7 ms (AC to Battery); 1 ms (Battery to AC) typical Low Voltage Transfer to Battery Power (Setpoint) 170 High Voltage Transfer to Battery Power (Setpoint) 282 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMX5000XLRT3U
物料型号:SMX5000XLRT3U 器件简介:这是一台5000VA的在线互动式UPS系统,适用于服务器、网络和电信设备。
它具有3U机架/塔式设计,安装深度仅为635mm/25英寸。
该UPS系统在230V交流输入下提供高达98%的线路功率效率,减少能源消耗和BTU热量输出。
通过可选的外部电池包扩展电池运行时间。
引脚分配:包括8个C13和3个C19输出插座。
参数特性:230V交流输入下5000VA/3750W最大输出功率,支持硬线输入,包括C19和C13输出插座。
网络级AC浪涌和噪声抑制。
支持USB、DB9串行和插槽用于网络管理卡选项。
功能详解:在电源故障和极端电压变化期间,UPS切换到由电池供电的交流输出。
在线互动式自动电压调节(AVR)在电压过低和过高时提供电压增益和降低,以维持230V的稳定输出。
应用信息:适用于大型网络、高端桌面/小型网络等应用场景。
封装信息:3U机架/塔式设计,支持4柱19英寸机架安装,可选2柱机架安装和塔式安装配件。
前面板开关支持自检和报警取消功能。
包括可调节安装导轨,支持在4柱19英寸机架中安装。
支持直立塔式放置,可选2-9USTAND配件。
CE、GOST、SASO认证。
SMX5000XLRT3U 价格&库存
很抱歉,暂时无法提供与“SMX5000XLRT3U”相匹配的价格&库存,您可以联系我们找货
