SU6000RT4UTFHW
SU6000RT4UTFHW
    TRIPPLITE
    UPS SMART ONLINE RACKMOUNT
SU6000RT4UTFHW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 208/240 & 120V 6kVA 5.4kW DoubleConversion UPS, 6U Rack/Tower, Extended Run, Network Card Options, USB, DB9 Serial, Bypass Switch, Hardwire MODEL NUMBER: SU6000RT4UTFHW Highlights ● 6kVA / 6000VA / 5400W on-line double-conversion UPS; 0.9 power factor ● 208/120V or 240/120V 60Hz output; Economy mode option ● 6U Rack/Tower installation; Hotswappable power and battery modules ● USB, RS232 & EPO ports; Network management and contact-closure card options ● Front panel LEDs with detailed LCD monitoring and control screen ● Expandable runtime with optional external battery packs ● Hardwire input (3 wire); NEMA 5-15R, 5-15/20R & Hardwire outputs Package Includes ● SU6000RT4UHVPM Hotswappable UPS Power Module ● SUPDMB6KHW Detachable PDU with Maintenance Bypass Switch ● SU6000XFMR2U Low voltage transformer ● 1 x 6-ft. USB Cable ● 1 x 6-ft. Serial Cable ● 4 Post Rackmount Hardware (2 sets) Description Tripp Lite SU6000RT4UTFHW 6000VA / 6kVA / 5400 watt on-line, double-conversion UPS system offers complete power protection for critical server, network and telecommunications equipment in a 6U rack/tower compatible configuration. Full-time active power conditioning provides clean, continuous dualconversion AC output free of voltage fluctuations, power interruptions and line noise. Fault-tolerant autobypass prevents unexpected service interruptions during UPS overload or internal fault conditions. Detachable back panel PDU with manual bypass switch supports hot-swappable UPS power module replacement with no interruption to connected equipment. 4U UPS power module and included 2U lowvoltage transformer install in only 6 rack spaces total (6U) with a maximum installed depth of only 21.8 in. / 55.3 cm. Maintains full-time sine wave output within 2% of selectable 208/240V and 120V nominal at 60Hz during brownouts as low 100V and overvoltages as high as 300V. Expandable runtime is supported with optional BP192V12-3U external battery packs. Battery independent restart ensures automatic UPS power-up without userinteraction after lengthy power outages, even when batteries are expired and require replacement. Double-conversion operation converts raw input from AC to DC, then resynthesizes output power back to perfect sine wave AC with enhanced protection from harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS types. Highly efficient operation in optional economy mode significantly reduces BTU heat output and operating energy costs. Network-grade AC surge and noise suppression. Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via built-in RS-232 and USB interfaces. Optional network management card options. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. PowerAlert monitoring software offers detailed site power and UPS updates with support for safe auto-shutdown of connected systems as UPS batteries become depleted. Supports Emergency Power Off (EPO) via built-in interface. Front panel LEDs and LCD readout with scroll controls support front-panel visual monitoring of all major UPS for a variety of control options to support advanced UPS settings and configurations. LED / LCD display panel rotates for viewing in rackmount or tower configurations. Hardwire input. Hardwire UPS output, plus 1 L630R, 8 5-15/20R and 4 5-15R outlets. External battery packs are field replaceable and hot swappable. $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Features ● Tripp Lite SU6000RT4UTFHW 6000VA / 6kVA / 5400 watt on-line, double-conversion UPS system in a 6U rack/tower compatible configuration (4U power module plus 2U low-voltage transformer) ● Full-time active power conditioning maintains clean, continuous dual-conversion AC output free of 1/7 1000 Eaton Boulevard Cleveland, OH 44122 United States voltage fluctuations, power interruptions and line noise ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Detachable back panel PDU contains input line cord connection, output receptacles and manual bypass switch to support hot-swappable whole UPS replacement with no interruption to connected equipment ● Hardwire input (208/240V L1, L2 + G) ● Hardwire high and low voltage output, plus 8 5-15/20R and 4 5-15R 120V outlets ● Included rail kit supports 4U 19 inch rackmount installation in 4 post racks ● Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (2 required for SU6000RT4UTFHW) ● Optional 2-9USTAND supports upright tower placement (1 required for SU6000RT4UTFHW) ● Maximum installed rack depth of only 21.8 in. / 55.3 cm ● Maintains full-time sine wave output within 2% of selected 208/240V and 120V nominal at 60Hz in double conversion mode ● Corrects brownouts to 156V at full load (100V at 50% load or less) ● Corrects overvoltages to 290V at full load (300V at 90% load or less) ● Double-conversion operation offers full-time AC to DC, then DC to AC conversion to maintain perfectly regulated sine wave AC output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS types ● High efficiency ECONOMY MODE operation significantly reduces BTU heat output and operating energy costs ● Network-grade AC surge and noise suppression ● Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via built-in RS-232, USB and optional SNMP card slot interfaces ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● Optional RELAYIOMINI interface module offers three configurable hard contact closure outputs for custom event notification (requires removal of USB interface module) ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Front panel LEDs and LCD readout with scroll controls support front-panel visual monitoring of all major UPS functions with support for a variety of control options to support advanced UPS settings and configurations ● LED/LCD display panel rotates for viewing in rackmount or tower configurations ● Supports Emergency Power Off (EPO) via built-in interface ● Battery independent restart ensures automatic UPS power-up without userinteraction after lengthy power outages, even when batteries areexpired and require replacement ● BP192V12-3U external battery packs are field replaceable and hot swappable ● Intelligent battery management system with temperature-compensated charging extends battery life ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications OVERVIEW UPC Code 037332157225 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 31.9A (200V), 30.6A (208V), 29A (220V), 27.7A (230V), 26.6A (240V) Nominal Input Voltage(s) Supported 208V AC; 240V AC Nominal Input Voltage Description Factory configured to 208V UPS Input Connection Type Hardwire UPS Input Connection Description 3 wire single phase input (L1, L2, G) Recommended Electrical Service 40A (200/208v); 30A (220/230/240v) OUTPUT Output Capacity (VA) 6000 Output Capacity (kVA) 6 Output Capacity (Watts) 5400 Output Capacity (kW) 5.4 Output Capacity Details Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power; Double conversion mode is automatically restored as the overload is cleared Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details This configuration requires the Power Module be set to 208 or 240V output voltage; included step-down transformer supports 120V output (when the voltage-selection switch on the transformer module is set to match the 208 or 240V power module setting) Frequency Compatibility 60 Hz Frequency Compatibility Details Output frequency regulation +/- 0.05Hz (free running) Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Output Receptacle Details Hardwire input and output connections are mounted on a detachable PDU backplate with bypass switch to enable hot-swappable power module replacement Output Circuit Breakers Low voltage 20A breakers on the transformer module protect 4 5-15/20R outlets each; Low voltage 15A breakers protect 2 5-15/20R outlets each Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V; 208V; 240V Output Receptacles (4) 5-15R; (8) 5-15/20R; (1) L6-30R; Hardwire 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 2 min. (5400W) Runtime Half Load (min.) 8.5 min. (2700W) Expandable Runtime Yes External Battery Pack Compatibility BP192V1037C-1PH;  BP192V12-3U ; BP192V1407C-1PH; BP192V557C-1PH;  BP192V787C1PH ;  BP192V5RT2U  (limit 1) DC System Voltage (VDC) 192 Battery Recharge Rate (Included Batteries) 6 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC5-192  Battery Replacement Description Hot-swappable, user replaceable internal batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction Corrects overvoltages as high as 300V (
SU6000RT4UTFHW
物料型号:SU6000RT4UTFHW 器件简介:SmartOnline 6000VA/5400W双转换UPS系统,适用于6U机架/塔式安装,具有热插拔电源和电池模块,支持USB、RS232和EPO端口,可选配网络管理和接触卡。
引脚分配:硬线输入(3线);NEMA 5-15R、5-15/20R和硬线输出。
参数特性:双转换UPS;0.9功率因数;208/120V或240/120V 60Hz输出;经济模式选项。
功能详解:提供全时主动功率调节,确保电压波动、电源中断和线路噪声得到有效抑制。
具有故障容限自动旁路功能,防止UPS过载或内部故障时意外中断服务。
应用信息:适用于关键服务器、网络和电信设备,提供全面电源保护。
封装信息:6U机架/塔式兼容配置,支持最大安装深度21.8英寸(553毫米)。
以上信息摘自PDF文档,提供了SU6000RT4UTFHW UPS系统的详细规格和特性。
SU6000RT4UTFHW 价格&库存
很抱歉,暂时无法提供与“SU6000RT4UTFHW”相匹配的价格&库存,您可以联系我们找货
