SU8000RT3UG
SU8000RT3UG
    TRIPPLITE
    UPS SMART ONLINE
SU8000RT3UG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 208/240, 230V 8kVA 7.2kW DoubleConversion UPS, 6U Rack/Tower, Extended Run, Network Card Options, USB, DB9, Bypass Switch, C19 outlets MODEL NUMBER: SU8000RT3UG Highlights ● 8kVA / 8000VA / 7200W on-line double-conversion 6U rack/tower UPS; Sine Wave ● Includes 3U UPS power module with maintenance bypass switch and 3U battery pack ● Extended runtime options, Interactive LCD interface, Economy-mode option, 0.9 power factor ● Add optional WEBCARDLX with latest version of PADM20 for enhanced remote management ● Hardwire 200-240V 50/60Hz input; C19 output; Configurable for 200/208/220/230/240V 50/60Hz output Package Includes Description Tripp Lite SU8000RT3UG 8000VA / 8kVA / 7200 watt online, double-conversion UPS system offers complete power protection for critical network applications. This system delivers online, double-conversion UPS protection with zero transfer time, suitable for advanced networking applications. Fault-tolerant autobypass prevents unexpected service interruptions during UPS overload or internal fault conditions. Included detachable PDU with manual bypass switch enables hot-swappable replacement of entire UPS power module with no interruption to connected equipment. Enhanced availability, fault tolerance and simple hot-swap replacement options make this UPS ideal for advanced networking applications in data centers, computer rooms, network closets and rugged industrial locations. Features ● Tripp Lite SU8000RT3UG 8kVA / 8000VA / 7200 watt on-line, double-conversion UPS system in 6U total rack/tower configuration (3U UPS power module and 3U external battery pack) ● Detachable PDU with manual bypass switch enables hot-swappable UPS power module replacement with no interruption in output power to connected networking equipment ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Hardwire input; 6 C19 outlets ● Maximum installed rack depth of only 32.5 in. / 82.6cm inches ● Full-time active power conditioning provides clean, continuous dual-conversion AC output free of voltage fluctuations, power interruptions and line noise ● Double-conversion operation converts raw input from AC to DC, then resynthesizes output power back to perfect sine wave AC with enhanced protection from harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS types ● Maintains full-time sine wave output within 2% of selectable 200/208/220/230/240V nominal during brownouts as low as 100V and overvoltages as high as 300V ● Supports 50/60Hz operation for worldwide frequency compatibility ● Expandable runtime is supported with optional BP240V10RT3U; BP240V787C-1PH external battery packs ● Intelligent battery management system with temperature-compensated charging extends battery life 1/7 ● SU8000RT3UPM 3U UPS power module ● BP240V10RT3U external battery pack ● SUPDMB710IEC Detachable PDU with manual bypass switch ● Four post compatible rack rail kit (2 sets) ● USB, DB9 and EPO cables 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Highly efficient operation in optional economy mode significantly reduces BTU heat output and operating energy costs ● Battery independent restart ensures automatic UPS power-up without user interaction after lengthy power outages, even when batteries are expired and require replacement ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Includes slot for network management card options ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities ● PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations ● Optional RELAYIOMINI interface module offers three configurable hard contact closure outputs for custom event notification (requires removal of USB interface module) ● Supports Emergency Power Off (EPO) via built-in interface ● Included rail kit supports 6U 19 inch rackmount installation in 4 post racks ● Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks ● Optional 2-9USTAND supports upright tower placement ● Front panel LEDs and LCD readout with scroll controls and password option supports visual monitoring of all major UPS functions and advanced UPS settings for charge level, nominal voltage selection, frequency conversion and other operational parameters ● LED / LCD display panel rotates for viewing in rackmount or tower configurations ● Network-grade AC surge and noise suppression ● Industrial mode option (factory preset) enables supports high current startup loads by momentarily switching to bypass mode in response to short duration overload conditions ● Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating) ● External battery packs are field replaceable and hot swappable Specifications OVERVIEW UPC Code 037332146342 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 46A (200V), 44.2A (208V), 41.8A (220V), 40A (230V), 38.3A (240V) Nominal Input Voltage(s) Supported 200V AC; 208V AC; 230V AC; 240V AC UPS Input Connection Type Hardwire UPS Input Connection Description Supports North American 208/240V input (L1,L2,G) and International 230/220/240V (L,N,PE) input wiring 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service 50A Voltage Compatibility (VAC) 200; 208; 230; 240 OUTPUT Output Capacity (VA) 8000 Output Capacity (kVA) 8 Output Capacity (Watts) 7200 Output Capacity (kW) 7.2 Output Capacity Details Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power; Double conversion mode is automatically restored as load levels are reduced to 95% or less Power Factor 0,9 Crest Factor 3:1 Nominal Voltage Details Voltage selection via front panel LCD interface Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details Output frequency matches input nominal on startup; Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating) Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Output Circuit Breakers 20A double-pole (x6) protects 1 C19 outlet each Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 200V; 208V; 220V; 230V; 240V Output Receptacles (6) C19 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5.5 min. (7200W) Runtime Half Load (min.) 13.5 min. (3600W) Expandable Runtime Yes External Battery Pack Compatibility  BP240V10RT3U ;  BP240V787C-1PH  DC System Voltage (VDC) 240 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% (typical, full load discharge) Battery Replacement Description Hot-swappable, user replaceable external battery packs VOLTAGE REGULATION Voltage Regulation Description 2% output voltage regulation in standard online, double-conversion mode Overvoltage Correction Corrects overvoltages up to 300V Undervoltage Correction Corrects undervoltages as low as 100V USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options; LED/LCD panel rotates for viewing in rack/tower formats; LCD Display supports ENGLISH, FRENCH, GERMAN, ITALIAN, SPANISH and PORTUGUESE (see manual) Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and execute scrolling LCD functions; bundled PDU includes bypass switch to enable hot-swap UPS power module replacement Alarm Cancel Operation Alarm cancel switch Audible Alarm Unique audible alarms for all major UPS, environmental and power conditions (see manual) LED Indicators 6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD screen offers additional information and control options SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 2565 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 6U Cooling Method Fan Included Battery Pack Dimensions (hwd / in.) 5.25 x 17.5 x 25 Included Battery Pack Weight (lbs.) 158.7 Included Battery Pack Weight (kg) 71.99 Included Mounting Accessory Description 2 sets of adjustable 4 post rack rails included (for separate UPS and battery pack components); 2-9USTAND tower kit included (supports up to 9U in tower format) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ) Maximum Device Depth (cm) 82.55 Maximum Device Depth (in.) 32.5 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Device Depth (mm) 826 Minimum Required Rack Depth (cm) 96.52 Minimum Required Rack Depth (inches) 38 Optional Mounting Accessory Notes 2 sets of  2POSTRMKITHD  required for 2 post rackmount installation of separate power module and battery pack Primary UPS Depth (mm) 656 Primary UPS Height (mm) 131 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 35.00 x 25.50 x 40.50 Shipping Dimensions (hwd / cm) 88.90 x 64.77 x 102.87 Shipping Weight (lbs.) 322.11 Shipping Weight (kg) 146.11 Unit Dimension Details Includes 3U UPS/power module, 3U external battery pack plus SUPDMB710IEC PDU with bypass; MAXIMUM DEVICE DEPTH specification refers to the whole UPS installed depth with bypass PDU installed UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 13.06 x 44.45 x 65.58 UPS Power Module Dimensions (hwd, in.) 5.14 x 17.5 x 25.82 UPS Power Module Weight (kg) 19.50 UPS Power Module Weight (lbs.) 43 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 2732 AC Economy Mode BTU / Hr. (Full Load) 1024 Battery Mode BTU / Hr. (Full Load) 2432 AC Mode Efficiency Rating (100% Load) 91% AC Economy Mode Efficiency Rating (100% Load) 96% Operating Elevation (ft.) 0-3000m (0 to 10,000 ft.) Audible Noise 60 dBA at front side 1 meter Operating Elevation (m) 0-3000 m COMMUNICATIONS 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Additional contact closure support with optional RELAYIOCARD and RELAYIOMINI interface cards. RELAYIOMINI installation requires removal of panel containing USB ports PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB, DB9 serial and EPO cables included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Transfer Time (Economy Mode) 8 ms. typical power failure response in optional economy mode Low Voltage Transfer to Battery Power (Setpoint) 100V High Voltage Transfer to Battery Power (Setpoint) 300V FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported Economy Mode Operation Optional economy mode enables high efficiency bypass operation with a maximum output voltage variation of +/10%. Double conversion mode is automatically restored as mains voltage varies beyond +/-10% with less than 1 millisecond transfer time between modes. High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries; Hot swappable UPS power module; Manual bypass switch; Remote management; Surge/noise protection; Zero transfer time Green Energy-Saving Features High efficiency economy mode operation; Schedulable daily hours of economy mode operation STANDARDS & COMPLIANCE Product Certifications IEC 61000; CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
SU8000RT3UG 价格&库存
很抱歉,暂时无法提供与“SU8000RT3UG”相匹配的价格&库存,您可以联系我们找货
