SU12KRT4UHW
SU12KRT4UHW
    TRIPPLITE
    UPS SMART ONLINE RACKMOUNT
SU12KRT4UHW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 200-240V 12kVA 10.8kW DoubleConversion UPS, N+1, 8U, Extended Run, Network Card Slot, USB, DB9, Bypass, Hardwire Highlights ● 12kVA / 12,000VA / 10,800 watt on-line double-conversion 8U rack/tower UPS ● 200/208/220/230/240V +/-2% 50/60Hz output ● Hot-swap power & battery modules, N+1 fault tolerance at loads up to 6kVA ● Add optional WEBCARDLX with latest version of PADM20 for enhanced remote management ● Front panel LEDs, Detailed LCD monitoring and control screen ● Expandable runtime with optional external battery packs MODEL NUMBER: SU12KRT4UHW Package Includes Description Tripp Lite SU12KRT4UHW 12,000VA / 12Kva / 10,800 watt online, double-conversion UPS system offers complete power protection for critical server, network and telecommunications equipment in an 8U rack/tower configuration. This system delivers complete N+1 redundancy when used at loads up to 6kVA, and non-redundant operation at loads between 6 and 12kVA. Fault-tolerant auto-bypass prevents unexpected service interruptions during UPS overload or internal fault conditions. Included parallel PDU with manual bypass switching enables hot-swappable replacement of all major UPS system components in both N+1 and combined operating modes. Enhanced availability, fault tolerance and simple hot-swap replacement options make this UPS ideal for advanced networking applications in data centers, computer rooms, network closets and rugged industrial locations. Features ● Tripp Lite SU12KRT4UHW 12kVA, 12,000VA / 10,800 watt on-line, double-conversion UPS system in 8U total rack/tower configuration ● Unique configuration offers 12kVA non-redundant operation and automatic N+1 redundancy at load levels of 6kVA and under ● Included Parallel PDU with manual bypass switch enables hot-swap replacement of power modules at any supported load level ● Hardwire input and output connections ● Maintains sine wave output within 2% of selectable 200/208/220/230/240V nominal ● Supports 50/60Hz operation for worldwide frequency compatibility ● Expandable runtime with optional external battery packs ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Intelligent battery management system with temperature-compensated charging extends battery life ● Battery independent restart ensures automatic UPS power-up after lengthy power outages, even with expired batteries ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● Optional WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20) 1/6 ● 2 SU6000RT4UHVPM UPS Power Modules ● SUPDMB12KHW Detachable PDU with manual bypass switch ● 4 post compatible rack rail kit (2 sets) ● USB, DB9 and EPO cables 1000 Eaton Boulevard Cleveland, OH 44122 United States provides enhanced remote management capabilities ● PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations ● Optional RELAYIOMINI interface modules available (requires removal of USB interface module) ● Applications utilizing the optional network communications card require two compatible card accessories (install one per included power module) ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (2 required) ● Optional 2-9USTAND supports upright tower placement (1 required) ● Supports Emergency Power Off (EPO) via built-in interface ● Front panel LEDs and LCD readout with scroll controls ● LED / LCD display panel rotates for viewing in rackmount or tower configurations ● External battery packs are field replaceable and hot swappable ● Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating) ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications OVERVIEW UPC Code 037332157119 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 63.8A (200V), 61.2A (208V), 58A (220V), 55.4A (230V), 53.2A (240V) Nominal Input Voltage(s) Supported 200V AC; 208V AC; 220V AC; 230V AC; 240V AC UPS Input Connection Type Hardwire UPS Input Connection Description Supports North American 208/240V input (L1,L2,G) and International 230/220/240V (L,N,PE) input wiring Recommended Electrical Service 70A OUTPUT Output Capacity (VA) 12000 Output Capacity (kVA) 12 Output Capacity (Watts) 10800 Output Capacity (kW) 10.8 Output Capacity Details Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power; Double conversion mode is automatically restored as load levels are reduced to 95% or less 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Factor 0,9 Crest Factor 3:1 Nominal Voltage Details Voltage selection via front panel LCD interface Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details Output frequency matches input nominal on startup; Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating) Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Battery Mode) +/- 2% Output Receptacle Details Supports North American 208/240V* output (L1,L2,G) and International 230/220/240V (L,N,PE) hardwire output; *For 120V output with 208/240V (L1,L2,G) input wiring, use optional SU6000XFMR2U transformer Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 200V; 208V; 220V; 230V; 240V Output Receptacles Hardwire Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 2 min. (10800W) Runtime Half Load (min.) 8.5 min. (5400W) Expandable Runtime Yes Expandable Runtime Description For best results, add external batteries in multiples of two so that both included 6kVA power modules have an equal number and type of connected battery packs External Battery Pack Compatibility  BP192V12-3U ;  BP192V787C-1PH  DC System Voltage (VDC) 192 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge Each of the two included 6kVA power modules contain one  RBC5-192  internal replacement battery cartridge Battery Replacement Description Hot-swappable, user replaceable internal battery cartridges and external battery packs VOLTAGE REGULATION Voltage Regulation Description +/-2% output voltage regulation in standard online, double-conversion mode Overvoltage Correction Corrects overvoltages as high as 300V (
SU12KRT4UHW 价格&库存
很抱歉,暂时无法提供与“SU12KRT4UHW”相匹配的价格&库存,您可以联系我们找货
