SU20KX
SU20KX
    TRIPPLITE
    UPS SMART ONLINE
SU20KX 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 20kVA 16kW Modular 3-Phase UPS System, Double-Conversion UPS, Network Card Slot, DB9 Serial Highlights ● 20,000 VA (20kVA) 3-phase tower UPS ● 1+1 parallel capability allows for system redundancy or increased capacity ● Low THDi reduces installation costs by permitting 1:1 generator sizing ● 3-phase hardwire (220/380V, 230/400V or 240/415V AC, 3phase, 4-wire + ground, wye) input/output ● IGBT technology and zero transfer time, on-line, doubleconversion operation ● Runtime is expandable with the addition of two SURBC2030 internal battery packs or via external battery cabinet options MODEL NUMBER: SU20KX Package Includes Description Tripp Lite's SU20KX (20kVA) SmartOnline Modular 3-Phase Intelligent, True On-Line UPS System provides 100% system availability with 1+1 parallel capability. In 1+1 configuration , two SU20KX models connected in parallel can provide fail-safe redundancy (two 20kVA models supporting a 20kVA load) or increased capacity (two 20kVA models supporting an 40kVA load). The SU20KX provides mission-critical equipment with the highest level of power protection available. Large capacity 20,000VA/16,000W UPS continually converts incoming AC power into filtered DC power, and then resynthesizes it back into AC power with a pure sine wave. Perfectly regulated, continuous sine wave output with zero transfer time assures compatibility with all equipment types. High input power factor, advanced IGBT inverter technology and Digital Signal Processor (DSP) technology produce less than 3% input total harmonic distortion (THDi). With low THDi, generators run cooler and last longer, allowing managers to save installation costs by installing a generator with a capacity equal to the equipment load (1:1 ratio). Extremely efficient operation (up to 97%) saves money by lowering electricity consumption. Hardwire input and output connections. The SU20KX features 50 or 60 Hz (auto-selectable) frequency. The SU20KX combines internal power and battery modules in a single small-footprint tower compartment. Typical halfload/full-load runtimes are 13 min./5.5 min. Battery runtime can be extended with optional stand-alone hardwired external battery modules (Models BP480V26B and BP480V40C, available separately). A manual bypass breaker and an automatic bypass function ensure 100% availability of connected equipment by safely passing through AC power if the UPS requires maintenance. Features ● 1+1 configuration: Two SU20KX can be connected in parallel to provide either fail-safe redundancy or increased capacity ● Low THDi (less than 3%) reduces installation costs by allowing 1:1 generator sizing ● Extremely efficient operation (up to 97%) saves money by reducing electricity consumption 1/5 ● SU20KX UPS System ● DB9 cable ● Instruction manual ● Warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● True on-line, double-conversion UPS with IGBT technology provides pure sine wave AC output at all times ● Maintains continuous operation with zero transfer time through blackouts, voltage fluctuations and surges ● Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power problems ● 20,000VA/16,000W power capacity with 3-phase, hardwire input/output connections ● Wide input voltage correction range: 173-276V/300-477V AC ● Precision +/-1% output voltage regulation ● Internal power and battery modules are combined in a single small-footprint tower compartment. Typical half-load/full-load runtimes are 13 min./5.5 min. Battery runtime can be extended with optional standalone hardwired external battery modules (Models BP480V26B and BP480V40C, available separately) ● Front panel combination LCD/LED display includes a real-time event log screen with up to 500 events listed ● Dynamic battery management screen optimizes battery function to lengthen service life and allow cold restart of the UPS ● Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● Emergency Power Off button turns UPS output OFF and disables Bypass output ● Built-in Emergency Power Off (EPO) dry-contact interface supports remote emergency shutdown in large facilities Specifications OVERVIEW UPC Code 037332141354 UPS Type On-Line INPUT Input Phase 3-Phase Rated input current (Maximum Load) 28A / 29A / 30A Nominal Input Voltage(s) Supported 220/380V 3-PH Wye; 230/400V 3-PH Wye; 240/415V 3-PH Wye Nominal Input Voltage Description 3-Phase Wye, 4 wire (L1, L2, L3, N, G) UPS Input Connection Type Hardwire OUTPUT Output Capacity (VA) 20000 Output Capacity (kVA) 20 Output Capacity (Watts) 16000 Output Capacity (kW) 16 Power Factor 0.8 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Crest Factor 3:1 Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) +/-1% Output Voltage Regulation (Battery Mode) +/-1% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 220/380V 3-PH Wye; 230/400V 3-PH Wye; 240/415V 3-PH Wye Output Receptacles Hardwire Individually Controllable Load Banks No BATTERY Runtime Full Load (min.) 5.5 min. (16kw) Runtime Half Load (min.) 13 min. (8kw) Expandable Runtime Yes Expandable Runtime Description External battery pack wiring is contractor supplied External Battery Pack Compatibility BP480V200; BP480V26B; BP480V300; BP480V400;  BP480V40C ;  BP480V500  DC System Voltage (VDC) +/- 240VDC Internal UPS Replacement Battery Cartridge  SURBC2030  Battery Replacement Description Hot-swappable, replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction Maintains continuous operation without using battery power during overvoltages to 276-477 (3-phase, 4-wire, wye), reducing output within 1% of nominal Undervoltage Correction Maintains continuous operation without using battery power during brownout/undervoltage conditions to 173-300 (3phase, 4-wire, wye) USER INTERFACE, ALERTS & CONTROLS Switches ON button turns UPS inverter on. OFF button turns UPS inverter off. LCD Display Control Buttons browse through and select items displayed on LCD screen. EPO (Emergency Power Off) button turns UPS output off and disables Bypass output Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Alarms signal a variety of operational conditions: low-battery, overload, shutdown, bypass and more LED Indicators 4-LED Display: Displays normal AC input, on battery power, bypass input and fault conditions 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States SURGE / NOISE SUPPRESSION EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 5950 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Tower Cooling Method Fans Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 856 Primary UPS Height (mm) 1,168 Primary UPS Width (mm) 521 Shipping Dimensions (hwd / in.) 55.00 x 28.50 x 42.50 Shipping Dimensions (hwd / cm) 139.70 x 72.39 x 107.95 Shipping Weight (lbs.) 738.50 Shipping Weight (kg) 334.98 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 116.84 x 52.07 x 85.60 UPS Power Module Dimensions (hwd, in.) 46 x 20.5 x 33.7 UPS Power Module Weight (kg) 266.98 UPS Power Module Weight (lbs.) 588.6 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 3053 Battery Mode BTU / Hr. (Full Load) 3488 COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Communications Cable DB9 cabling included Communications Interface DB9 Serial; Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) Maintains continuous operation without using battery power during brownout/undervoltage conditions to 173-300V AC (3-phase, 4-wire, wye). Below this point, output is maintained utilizing reserve battery power High Voltage Transfer to Battery Power (Setpoint) Maintains continuous operation without using battery power during overvoltages to 276-477V AC (3-phase, 4-wire, wye), reducing output within 1% of nominal. Above this point, output is maintained utilizing reserve battery power FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic inverter bypass; Hot swappable batteries; Auto Probe Monitoring (requires WEBCARDLX); Zero transfer time; On-Line/Double-Conversion Green Energy-Saving Features High efficiency economy mode operation; Schedulable daily hours of economy mode operation WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty 3-Phase Warranty Statement Tripp Lite 3-Phase UPS Factory Warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SU20KX
物料型号:SU20KX
器件简介:Tripp Lite的SU20KX是一款20kVA的SmartOnline模块化三相UPS系统,提供100%系统可用性。
它通过1+1并联配置,可提供故障安全冗余或增加容量。
引脚分配:三相硬线输入/输出。
参数特性: - 额定输入电流(最大负载):28A/29A/30A - 额定输入电压(支持):220/380V 3PH WYE; 230/400V 3PH WYE; 240/415V 3PH WYE - 输出容量:20,000VA/16,000W - 功率因数:0.8 - 电池运行时间:满载5.5分钟,半载13分钟 - 扩展电池运行时间:是
功能详解: - 双转换UPS,提供纯正弦波AC输出 - 低总谐波失真(THDi)小于3% - 效率高达97%,节省电力消耗 - 内部电源和电池模块集成在单一小型塔式机箱中 - 前面板LCD/LED显示屏,包括实时事件日志屏幕 - 支持外部电池包扩展运行时间
应用信息:适用于关键任务应用。
封装信息:塔式设计,尺寸为856mm(深)x 1168mm(高)x 521mm(宽)。
SU20KX 价格&库存
很抱歉,暂时无法提供与“SU20KX”相匹配的价格&库存,您可以联系我们找货
