SU20KRTHW
SU20KRTHW
    TRIPPLITE
    UPS SMART ONLINE RACKMOUNT
SU20KRTHW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 200-240V, 20kVA 18kW DoubleConversion UPS, N+1, 12U, Network Card Slot, USB, DB9, Bypass, Hardwire Highlights ● 20kVA / 20,000VA / 18,000W on-line double-conversion UPS; 0.9 power factor ● 200/208/220/230/240V 50/60Hz output ● Hot-swap power and battery modules, N+1 fault tolerance at loads up to 10kVA ● Add optional WEBCARDLX with latest version of PADM20 for enhanced remote management ● Front panel LEDs with detailed LCD monitoring and control screen ● Expandable runtime with optional external battery packs ● Hardwire input (3 wire); Hardwire output (3 wire) MODEL NUMBER: SU20KRTHW Package Includes ● Two SU10000RT3UPM UPS power modules ● Two BP240V10RT3U battery packs ● SUPDMB20KHW PDU with Bypass switch ● 4-post rackmount installation rails ● USB, DB9 & EPO cabling Description Tripp Lite SU20KRTHW 20,000VA / 20kVA / 18,000 watt online, double-conversion UPS system offers complete power protection for critical server, network and telecommunications equipment in a 12U rack/tower configuration. This system delivers complete N+1 redundancy when used at loads up to 10kVA, and non-redundant operation at loads between 10 and 20kVA. Fault-tolerant auto-bypass prevents unexpected service interruptions during UPS overload or internal fault conditions. Included parallel PDU with manual bypass switching enables hot-swappable replacement of all major UPS system components in both N+1 and combined operating modes. Enhanced availability, fault tolerance and simple hot-swap replacement options make this UPS ideal for advanced networking applications in data centers, computer rooms, network closets and rugged industrial locations. Features ● Tripp Lite SU20KRTHW 20kVA, 20,000VA / 18,000 watt on-line, double-conversion UPS system in 12U total rack/tower configuration ● Unique configuration offers 20kVA non-redundant operation and automatic N+1 redundancy at load levels of 10kVA and under ● Included Parallel PDU with manual bypass switch enables hot-swap replacement power modules at any supported load level ● Hardwire input (3 wire) and hardwire output (3 wire) connections ● Supports North American (L1,L2,G) 208/240v hardwire input / output, plus International 230/220/240v (L,N,PE) hardwire input / output ● Optional SU6000XFMR2U transformer offers 120v output in North American 208/240V (L1,L2,G) input configurations ● Maintains full-time sine wave output within 2% of selectable 200/208/220/230/240V nominal ● Supports 50/60Hz operation for worldwide frequency compatibility ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD (NOTE: Applications utilizing any supported network management card option, require the installation of two of the same model network card – install one card per included UPS power module) ● Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities 1/6 1000 Eaton Boulevard Cleveland, OH 44122 United States ● PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations ● Expandable runtime with optional external battery packs ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Battery independent restart ensures automatic UPS power-up after lengthy power outages, even with expired batteries ● Intelligent battery management system with temperature-compensated charging extends battery life ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (4 required) ● Optional 2-9USTAND supports upright tower placement (2 required) ● Supports Emergency Power Off (EPO) via built-in interface ● Front panel LEDs and LCD readout with scroll controls ● LED / LCD display panel rotates for viewing in rackmount or tower configurations ● External battery packs are field replaceable and hot swappable ● Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating) Specifications OVERVIEW UPC Code 037332158291 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 112.2A (200V), 108A (208V), 102A (220V), 97.6A (230V), 93.6A (240V) Nominal Input Voltage(s) Supported 200V AC; 208V AC; 220V AC; 230V AC; 240V AC UPS Input Connection Type Hardwire UPS Input Connection Description Supports North American 208/240V input (L1,L2,G) and International 230/220/240V (L,N,PE) input wiring Recommended Electrical Service 120A @ 200V-240V (L, N, PE), or 125A @ 200V, 208V, or 240V (L1, L2, G) OUTPUT Output Capacity (VA) 20000 Output Capacity (kVA) 20 Output Capacity (Watts) 18000 Output Capacity (kW) 18 Output Capacity Details Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power; Double conversion mode is automatically restored as load levels are reduced to 95% or less Power Factor 0,9 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Crest Factor 3:1 Nominal Voltage Details Voltage selection via front panel LCD interface Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details Output frequency matches input nominal on startup; Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating) Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Battery Mode) +/- 2% Output Receptacle Details Supports North American 208/240V* output (L1,L2,G) and International 230/220/240V (L,N,PE) hardwire output; *For 120V output with 208/240V (L1,L2,G) input wiring, use optional SU6000XFMR2U transformer Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 200V; 208V; 220V; 230V; 240V Output Receptacles Hardwire Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.3 min. (18kW) Runtime Half Load (min.) 12.5 min. (9000W) Expandable Runtime Yes Expandable Runtime Description For best results, add external batteries in multiples of two so that both included 10kVA power modules have an equal number and type of connected battery packs External Battery Pack Compatibility  BP240V10RT3U ;  BP240V787C-1PH  DC System Voltage (VDC) 240 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% (typical, full load discharge) Battery Replacement Description Hot-swappable, user replaceable external battery packs VOLTAGE REGULATION Voltage Regulation Description 2% output voltage regulation in standard online, double-conversion mode Overvoltage Correction Corrects overvoltages up to 300V Undervoltage Correction Corrects undervoltages as low as 100V USER INTERFACE, ALERTS & CONTROLS 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Front Panel LCD Display Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options; LED/LCD panel rotates for viewing in rack/tower formats; LCD Display supports ENGLISH, FRENCH, GERMAN, ITALIAN, SPANISH and PORTUGUESE (see manual) Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and execute scrolling LCD functions; bundled PDU includes bypass switch to enable hot-swap UPS power module replacement Alarm Cancel Operation Alarm cancel switch Audible Alarm Unique audible alarms for all major UPS, environmental and power conditions (see manual) LED Indicators 6 LEDs indicate line power, online mode, bypass mode, on-battery, charger and AC output status; LCD screen offers additional information and control options SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 2565 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 12U Cooling Method Fans Included Battery Pack Dimensions (hwd / in.) 5.25 x 17.5 x 25 Included Battery Pack Weight (lbs.) 158.7 Included Battery Pack Weight (kg) 71.99 Included Mounting Accessory Description 4 sets of adjustable 4 post rack rails included (one for each included 3U module) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Maximum Device Depth (cm) 82.55 Maximum Device Depth (in.) 32.5 Maximum Device Depth (mm) 826 Minimum Required Rack Depth (cm) 96.52 Minimum Required Rack Depth (inches) 38 Optional Mounting Accessory Notes Qty 4  2POSTRMKITHD  required; Qty 2  2-9USTAND  required Primary UPS Depth (mm) 656 Primary UPS Height (mm) 131 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 31.00 x 40.00 x 51.00 Shipping Dimensions (hwd / cm) 78.74 x 101.60 x 129.54 Shipping Weight (lbs.) 601.00 Shipping Weight (kg) 272.61 Unit Dimension Details Includes 2 SU10000RT3UPM UPS/Power modules, 2 BP240V10RT3U Battery packs and SUPDMB20KHW parallel bypass PDU; Listed weights and dimensions for UPS/Power module and Included battery pack each refer to a single unit; MAXIMUM DEVICE DEPTH specification refers to the whole UPS installed depth with parallel bypass PDU installed UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 13.06 x 44.45 x 65.58 UPS Power Module Dimensions (hwd, in.) 5.14 x 17.5 x 25.82 UPS Power Module Weight (kg) 20.00 UPS Power Module Weight (lbs.) 44.1 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 6830 Battery Mode BTU / Hr. (Full Load) 9185 AC Mode Efficiency Rating (100% Load) 90% Operating Elevation (ft.) 0-3000m (0 to 10,000 ft.) Audible Noise 60 dBA at front side 1 meter Operating Elevation (m) 0-3000 m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Applications utilizing any supported network management card option, require the installation of two of the same model network card – install one card per included UPS power module; RELAYIOMINI installation requires removal of panel containing USB ports on each included UPS power module PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB, DB9 serial and EPO cables included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 100V High Voltage Transfer to Battery Power (Setpoint) 300V FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Expandable battery backup; Hot swappable UPS power module; Hot swappable batteries; Manual bypass switch; N+1 Redundant up to 50% capacity; On-Line/Double-Conversion; Remote management; Sine wave output; Surge/noise protection; Zero transfer time Green Energy-Saving Features Support for daily startup and shutoff STANDARDS & COMPLIANCE Product Certifications IEC 61000; CSA (Canada); UL 1778 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SU20KRTHW
物料型号:SU20KRTHW
器件简介:Tripp Lite SU20KRTHW是一款20,000VA/18,000瓦的在线双变换不间断电源(UPS)系统,用于保护关键服务器、网络和电信设备。
该系统提供N+1冗余,输入和输出硬线连接,适用于北美和国际电压。
引脚分配:硬线输入(3线)、硬线输出(3线)。
参数特性: - 输入电压:200V/208V/220V/230V/240V AC - 输出容量:20,000VA/18,000瓦 - 功率因数:0.9 - 电池类型:阀控式铅酸(VRLA) - 电池更换:热插拔,用户可替换 - 运行温度:0至40摄氏度 - 湿度:0至95%,非凝结
功能详解: - 双变换在线UPS - 支持50/60Hz操作 - 前面板LCD显示,支持多种语言 - 支持热插拔电源和电池模块 - 可扩展的运行时间 - 支持紧急电源关闭(EPO)
应用信息:适用于数据中心、计算机房、网络机柜和恶劣的工业环境。
封装信息:机架式安装,12U高度,冷却方式为风扇散热。
SU20KRTHW 价格&库存
很抱歉,暂时无法提供与“SU20KRTHW”相匹配的价格&库存,您可以联系我们找货
