SU20KRT-1TF
SU20KRT-1TF
    TRIPPLITE
    UPS SMART ONLINE RACKMOUNT
SU20KRT-1TF 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 208/240 & 120V 20kVA 18kW, Double-Conversion UPS, N+1, 14U, Network Card Slot, USB, DB9, Bypass Switch Highlights ● 20kVA / 20,000VA / 18,000W on-line double-conversion UPS; 0.9 power factor ● 208/120V or 240/120V 60Hz output ● Hot-swap power and battery modules, N+1 fault tolerance at loads up to 10kVA ● USB, RS232 & EPO ports; slot for network management card options ● Front panel LEDs with detailed LCD monitoring and control screen ● Expandable runtime with optional external battery packs ● Hardwire input (3 wire); L6-30R, C19, 5-15/20R & 5-15R outlets MODEL NUMBER: SU20KRT-1TF Package Includes ● Two SU10000RT3UPM UPS power modules ● Two BP240V10RT3U battery packs ● One SU6000XFMR2U 208/240V to 120V transformer ● SUPDMB20K parallel PDU with Bypass switch ● 4-post rackmount installation kit ● USB, DB9 & EPO cables Description Tripp Lite SU20KRT-1TF 20,000VA / 20kVA / 18,000 watt online, double-conversion UPS system offers complete power protection for critical server, network and telecommunications equipment in a 14U rack/tower configuration. This system delivers complete N+1 redundancy when used at loads up to 10kVA, and non-redundant operation at loads between 10 and 20kVA. Fault-tolerant auto-bypass prevents unexpected service interruptions during UPS overload or internal fault conditions. Included parallel PDU with manual bypass switching enables hot-swappable replacement of all major UPS system components in both N+1 and combined operating modes. Enhanced availability, fault tolerance and simple hot-swap replacement options make this UPS ideal for advanced networking applications in data centers, computer rooms, network closets and rugged industrial locations. Features ● Tripp Lite SU20KRT-1TF 20kVA, 20,000VA / 18,000 watt on-line, double-conversion UPS system in 14U total rack/tower configuration ● Unique configuration offers 20kVA non-redundant operation and automatic N+1 redundancy at load levels of 10kVA and under ● Included Parallel PDU with manual bypass switch enables hot-swap replacement of power modules at any supported load level ● Hardwire input; 2 L6-30R (208/240v), 8 C19 (208/240v), 8 5-15/20R (120v) and 4 5-15R (120v) outlets ● Maintains full-time sine wave output within 2% of selectable 200/208/220/230/240V & 120V nominal ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD (NOTE: Applications utilizing any supported network management card option, require the installation of two of the same model network card – install one card per included UPS power module) ● Expandable runtime with optional external battery packs ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Battery independent restart ensures automatic UPS power-up after lengthy power outages, even with expired batteries ● Intelligent battery management system with temperature-compensated charging extends battery life ● HID-compliant USB interface 1/6 1000 Eaton Boulevard Cleveland, OH 44122 United States ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (6 required) ● Optional 2-9USTAND supports upright tower placement (2 required) ● Supports Emergency Power Off (EPO) via built-in interface ● Front panel LEDs and LCD readout with scroll controls ● LED / LCD display panel rotates for viewing in rackmount or tower configurations ● External battery packs are field replaceable and hot swappable Specifications OVERVIEW UPC Code 037332158260 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 108A (208V), 93.6A (240V) Nominal Input Voltage(s) Supported 208V AC; 240V AC UPS Input Connection Type Hardwire UPS Input Connection Description 3 wire single phase input (L1, L2, G) Recommended Electrical Service 125A @ 208V, or 240V (L1, L2, G) OUTPUT Output Capacity (VA) 20000 Output Capacity (kVA) 20 Output Capacity (Watts) 18000 Output Capacity (kW) 18 Output Capacity Details Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power; Double conversion mode is automatically restored as load levels are reduced to 95% or less Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details This configuration requires the Power Module be set to 208 or 240V output voltage; included step-down transformer supports 120V output (when the voltage-selection switch on the transformer module is set to match the 208 or 240V power module setting) Frequency Compatibility 60 Hz Frequency Compatibility Details Output frequency regulation +/- 0.05Hz (free running) Output Voltage Regulation (Line Mode) +/- 2% 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) +/- 2% Output Receptacle Details Total 120V output is limited to 4992 watts for 208V input and 5760 watts for 240V input. Additional 120V capacity is available by adding a second SU6000XFMR2U step-down transformer. Output Circuit Breakers POWER MODULE: Two built-in 30A breakers protect one L6-30R outlet each, Eight built-in 20A breakers protect one C19 outlet each; TRANSFORMER MODULE: Two 15A breakers protect 2 5-15R outlets each, Two 20A breakers protect 4 5-15/20R outlets each Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V; 208V; 240V Output Receptacles (4) 5-15R; (8) 5-15/20R; (2) L6-30R; (8) C19 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.3 min. (18kW) Runtime Half Load (min.) 12.5 min. (9000W) Expandable Runtime Yes Expandable Runtime Description For best results, add external batteries in multiples of two so that both included 10kVA power modules have an equal number and type of connected battery packs External Battery Pack Compatibility  BP240V10RT3U ;  BP240V787C-1PH  DC System Voltage (VDC) 240 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% (typical, full load discharge) Battery Replacement Description Hot-swappable, user replaceable external battery packs VOLTAGE REGULATION Voltage Regulation Description 2% output voltage regulation in standard online, double-conversion mode Overvoltage Correction Corrects overvoltages up to 300V Undervoltage Correction Corrects undervoltages as low as 100V USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options; LED/LCD panel rotates for viewing in rack/tower formats; LCD Display supports ENGLISH, FRENCH, GERMAN, ITALIAN, SPANISH and PORTUGUESE (see manual) Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and execute scrolling LCD functions; bundled PDU includes bypass switch to enable hot-swap UPS power module replacement Alarm Cancel Operation Alarm cancel switch 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Audible Alarm Unique audible alarms for all major UPS, environmental and power conditions (see manual) LED Indicators 6 LEDs indicate line power, online mode, bypass mode, on-battery, charger and AC output status; LCD screen offers additional information and control options SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 2565 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 14U Cooling Method Fans Included Battery Pack Dimensions (hwd / in.) 5.25 x 17.5 x 25 Included Battery Pack Weight (lbs.) 158.7 Included Battery Pack Weight (kg) 71.99 Included Mounting Accessory Description 5 sets of adjustable 4 post rack rails included (one for each included 2U/3U module) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Maximum Device Depth (cm) 82.55 Maximum Device Depth (in.) 32.5 Maximum Device Depth (mm) 826 Minimum Required Rack Depth (cm) 96.52 Minimum Required Rack Depth (inches) 38 Optional Mounting Accessory Notes Qty 5  2POSTRMKITHD  required; Qty 2  2-9USTAND  required Primary UPS Depth (mm) 656 Primary UPS Height (mm) 131 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 31.50 x 40.00 x 51.00 Shipping Dimensions (hwd / cm) 80.01 x 101.60 x 129.54 Shipping Weight (lbs.) 630.00 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 285.76 Stepdown Transformer Dimensions (hwd / cm) 8.89 x 44.45 x 55.37 Stepdown Transformer Dimensions (hwd / in.) 3.5 x 17.5 x 21.8 Stepdown Transformer Height (mm) 89 Stepdown Transformer Width (mm) 445 Stepdown Transformer Depth (mm) 554 Stepdown Transformer Weight (kg) 32.93 Stepdown Transformer Weight (lbs.) 72.6 Unit Dimension Details Includes 2 SU10000RT3UPM UPS/Power modules, 2 BP240V10RT3U Battery packs, 1 SU6000XFMR2U transformer and SUPDMB20K parallel bypass PDU; Listed weights and dimensions for UPS/Power module, battery pack and transformer each refer to a single unit; MAXIMUM DEVICE DEPTH specification refers to the whole UPS installed depth with parallel bypass PDU installed UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 13.06 x 44.45 x 65.58 UPS Power Module Dimensions (hwd, in.) 5.14 x 17.5 x 25.82 UPS Power Module Weight (kg) 20.00 UPS Power Module Weight (lbs.) 44.1 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 6830 Battery Mode BTU / Hr. (Full Load) 9185 AC Mode Efficiency Rating (100% Load) 90% Operating Elevation (ft.) 0-3000m (0 to 10,000 ft.) Audible Noise 60 dBA at front side 1 meter Operating Elevation (m) 0-3000 m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Applications utilizing any supported network management card option, require the installation of two of the same model network card – install one card per included UPS power module; RELAYIOMINI installation requires removal of panel containing USB ports on each included UPS power module 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB, DB9 serial and EPO cables included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 100V High Voltage Transfer to Battery Power (Setpoint) 300V FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Expandable battery backup; Hot swappable UPS power module; Hot swappable batteries; Manual bypass switch; N+1 Redundant up to 50% capacity; On-Line/Double-Conversion; Remote management; Sine wave output; Surge/noise protection; Zero transfer time Green Energy-Saving Features Support for daily startup and shutoff STANDARDS & COMPLIANCE Product Certifications IEC 61000; CSA (Canada); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SU20KRT-1TF 价格&库存
很抱歉,暂时无法提供与“SU20KRT-1TF”相匹配的价格&库存,您可以联系我们找货
