1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240 & 120V 16kVA 11.2kW
Double-Conversion UPS, 8U, Extended Run,
Network Card Slot, USB, DB9, Bypass, Hardwire
Highlights
16kVA / 16,000VA / 11,200W
on-line double-conversion UPS,
split phase input
208/120V or 240/120V +/-3%
output at 60Hz, 94% Efficient
Economy-mode option
8U Rack/Tower compatible; Hotswappable power and battery
modules
USB, RS232 & EPO ports; slot
for network management card
options
Front panel LEDs with detailed
LCD monitoring and control
screen
Expandable runtime with
optional external battery packs
Hardwire input (4 wire split
phase); Hardwire output
MODEL NUMBER: SU16000RT4UHW
Package Includes
Description
Tripp Lite's SU16000RT4UHW SmartOnline Hot-Swappable Modular Rack/Tower UPS System provides
SU16000RT4UPM UPS Power
Module
BP192V18-4U External battery
pack
SUPDMB16KHW Detachable
PDU with manual bypass switch
4-post rackmount installation
brackets
16,000VA (16kVA) on-line, double-conversion UPS support for server, network and telecommunications
equipment. Maintains battery-derived AC output during blackouts with active, full-time power conditioning.
Fault-tolerant auto-bypass prevents unexpected service interruptions during overload or internal fault
conditions. 4U power module and 4U external battery pack installs in 8 rack spaces (8U). Upright tower
and two-post rackmount installation supported with optional accessories. Maintains full-time sine wave
output within 3% of selectable 208/120 or 240/120V AC. Corrects brownouts and overvoltages from 65V
to 140V (L-N). Expandable runtime with optional external battery packs. Converts raw input from AC to
DC, then resynthesizes output power back to perfect sine wave AC output with enhanced protection from
harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by
other UPS types. Highly efficient operation in optional economy mode setting, saving BTU heat output and
energy costs. Network-grade AC surge and noise suppression. Network management interfaces include
combination DB9 RS-232 enabled and dry contact serial port, enhanced USB port and slot for network
management card options. HID-compliant USB interface enables integration with built-in power
management and auto-shutdown features of Windows and Mac OS X. Supports simultaneous detailed
monitoring of equipment load levels, self-test data and utility power conditions via all three network
interfaces. PowerAlert UPS monitoring software is available via free download. Supports Emergency
Power Off (EPO) via built-in interface. Front panel LEDs and LCD readout with scroll controls support
visual monitoring of all major UPS functions. LED/LCD display panel easily rotates for viewing in
rackmount or tower configurations. Split-phase, four-conductor hardwire input. UPS supports hardwire
output. Output hardwire connections are mounted on a detachable backplate with manual bypass switch
to enable hot-swappable UPS replacement without powering off connected equipment. External battery
packs are field replaceable and hot swappable. Attractive all-black color scheme. $250,000 Ultimate
Lifetime Insurance (U.S., Canada, and Puerto Rico only).
1/6
Cleveland, OH 44122
United States
Features
True on-line, double-conversion UPS provides pure, full-time sine wave AC output free of surges,
voltage fluctuations and line noise
16,000VA/11,200W output power capacity with dual voltage output of 208/120V or 240/120V
4U high power density power module and 4U external battery pack support rackmount installation in 8
rack spaces (8U)
Dual conversion UPS actively converts raw input from AC to DC, then back to perfect sine wave AC
output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-tosolve power problems not addressed by other UPS types
Hardwire input and output terminals are mounted on a detachable backplate with manual bypass switch
Provides perfectly regulated, sine wave output power free of line noise, transient surges and frequency
variation for the most efficient operation of critical servers, networking and telecommunications
equipment
Maintains output within 3% of selected 208/120V or 240/120V nominal voltage during brownouts and
overvoltages
Supports connected equipment during blackouts for 12/5 min. at half/full load levels; runtime is further
expandable with optional external battery packs (Model BP192V18-4U)
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Intelligent battery management system extends battery life
Highly efficient Economy-mode option
Network interfaces support simultaneous communications via DB9 port, USB port and slot for network
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
DB9 port supports RS-232 and dry contact messaging. HID-compliant USB interface enables integration
with built-in power management and auto shutdown features of Windows and Mac OS X
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Built-in Emergency Power Off (EPO) interface with cable
Supports hardwire output at 208V and 120V
Split phase, four-conductor hardwire input connection on included detachable PDU
Front panel LEDs and LCD readout with scroll button enables visual confirmation of all major UPS
functions and current site electrical conditions
Front panel switches enable power on/off control, self-test and alarm cancel functions
Included adjustable mounting rails support installation in 4-post 19-in. rack enclosures
Optional 2-9USTAND tower stand set supports upright tower installation
Optional 2POSTRMKITHD accessory enables 2-post rackmount installation
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332140494
UPS Type
On-Line
2/6
Cleveland, OH 44122
United States
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
68A
Nominal Input Voltage(s) Supported
120/208V (Split phase L1,L2,N,G); 120/240V (Split phase L1,L2,N,G)
UPS Input Connection Type
Hardwire
UPS Input Connection Description
4 wire split-phase input (L1, L2, N, G)
Recommended Electrical Service
70A 208/240-120 Split Phase (L1, L2, N, G); 4 AWG wiring recommended
OUTPUT
Output Capacity (VA)
16000
Output Capacity (kVA)
16
Output Capacity (Watts)
11200
Output Capacity (kW)
11.2
Output Capacity Details
16,000VA, 11,200W (240V) / 13,860VA, 11,200W (208V); Supports up to 105% load continuously in double
conversion mode, 106 to 125% for 3 minutes, 126 to 150% for 30 seconds; Loads over 150% trigger immediate
bypass mode operation to support equipment directly from mains power; Double conversion mode is automatically
restored as the overload is cleared
Power Factor
0.7
Crest Factor
3:1
Nominal Voltage Details
240/120V or 208/120V split phase output
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
+/- 3%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 3%
Output Receptacle Details
Supports North American 208/120V or 240/120V split-phase output (L1, L2, N, G)
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V; 208V; 240V
Output Receptacles
Hardwire
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5 min. (11,200w)
Runtime Half Load (min.)
12 min. (5600w)
3/6
Cleveland, OH 44122
United States
Expandable Runtime
Yes
External Battery Pack Compatibility
BP192V18-4U
DC System Voltage (VDC)
192
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Replacement Description
Hot-swappable, user replaceable external battery packs
VOLTAGE REGULATION
Voltage Regulation Description
+/-3% output voltage regulation in online, double-conversion mode
Overvoltage Correction
Corrects overvoltages to 140 (measured L1-N : L2-N)
Undervoltage Correction
Corrects undervoltages to 65V (measured L1-N : L2-N)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and
execute scrolling LCD functions; bundled PDU includes bypass switch to enable hot-swap UPS power module
replacement
Alarm Cancel Operation
Alarm cancel switch
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD
screen offers additional information and control options
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
3620
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
8U
Cooling Method
Fan
Included Battery Pack Dimensions
(hwd / in.)
7 x 17.5 x 27.8
Included Battery Pack Weight (lbs.)
239
Included Battery Pack Weight (kg)
108.41
Included Mounting Accessory
Description
2 sets of adjustable 4 post rack rails included
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
4/6
Cleveland, OH 44122
United States
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Maximum Device Depth (cm)
86.36
Maximum Device Depth (in.)
34
Maximum Device Depth (mm)
864
Minimum Required Rack Depth (cm)
101.60
(inches)
40
Optional Mounting Accessory Notes
2 sets of 2POSTRMKITHD required for 2 post
rackmount installation of separate power module and battery pack
Primary UPS Depth (mm)
706
Primary UPS Height (mm)
178
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
36.50 x 24.00 x 33.50
Shipping Dimensions (hwd / cm)
92.71 x 60.96 x 85.09
Shipping Weight (lbs.)
455.80
Shipping Weight (kg)
206.75
Unit Dimension Details
Includes 4U battery pack, 4U UPS/power module and detachable bypass PDU; MAXIMUM DEVICE DEPTH
specification refers to the whole UPS installed depth with bypass PDU installed
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
17.78 x 44.45 x 70.61
(hwd, in.)
7 x 17.5 x 27.8
UPS Power Module Weight (kg)
39.01
UPS Power Module Weight (lbs.)
86
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius.
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius.
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
5717
AC Economy Mode BTU / Hr. (Full
Load)
2438
Battery Mode BTU / Hr. (Full Load)
4248
AC Economy Mode Efficiency Rating
(100% Load)
94%
Operating Elevation (ft.)
0-3000m (0 to 10,000 ft.)
5/6
Cleveland, OH 44122
United States
Audible Noise
60 dBA at front side 1 meter
Operating Elevation (m)
0-3000 m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
RS232 and contact closure communications are supported on one DB9 port
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Transfer Time (Economy Mode)
2 milliseconds typical in optional economy mode
Low Voltage Transfer to Battery
Power (Setpoint)
65V (L1-N:L2-N)
High Voltage Transfer to Battery
Power (Setpoint)
140V (L1-N:L2-N)
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Expandable battery backup; Hot
swappable UPS power module; Hot swappable batteries; Manual bypass switch; On-Line/Double-Conversion;
Remote management; Sine wave output; Surge/noise protection; Zero transfer time
Green Energy-Saving Features
High efficiency economy mode operation; Schedulable daily hours of economy mode operation
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
