SU20K3/3
SU20K3/3
    TRIPPLITE
    UPS SMARTONLINE 20KVA 16KW IGBT
SU20K3/3 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 3-Phase 120/208V 20kVA 16kW Double-Conversion UPS, Extended Run, 2 internal batteries, Network Card Options, Tower, DB9 Serial, Hardwire MODEL NUMBER: SU20K3/3 Highlights ● 20,000 VA (20kVA) tower UPS with internal batteries ● Saves valuable space: power and battery components combined into a single smallfootprint module ● Simplifies runtime scalability: convenient front panel battery access for expandable runtime with additional internal battery packs ● 3-phase hardwire input and output (120/208VAC). Wide input voltage correction range (96 - 144V AC / 166 - 250V AC) ● IGBT technology and zero transfer time, on-line, doubleconversion operation ● 3 communication ports, Slot for network card options and EPO jack Package Includes ● SU20K3/3 UPS System (power and battery components in one module) Description ● DB9 cabling Tripp Lite's SU20K3/3 20kVA SmartOnline 3-Phase Intelligent, True On-Line UPS System has been ● Warranty information redesigned to save valuable space and simplify runtime scalability. Power and battery components are ● Instruction manual combined into a single, small-footprint module (the smallest in its class). A robust internal battery runtime capability can be easily extended by installing additional optional internal battery packs through the convenient front panel access door. The SU20K3/3 provides mission-critical equipment with the highest level of power protection available. Large capacity 20,000VA/16,000 watt UPS continually converts incoming AC power into filtered DC power, and then resynthesizes it back into AC power with a pure sine wave. Perfectly regulated, continuous sine wave output with zero transfer time offers compatibility with all equipment types. IGBT inverter technology produces output power with
SU20K3/3
物料型号:SU20K3/3 器件简介:Tripp Lite的SU20K3/3是一款20kVA的SmartOnline三相智能真在线UPS系统,具有内置电池,节省空间并简化了运行时间的可扩展性。
它通过将电源和电池组件合并到一个小型模块中,并通过前面板方便地安装额外的内部电池包来扩展运行时间。
引脚分配:该UPS系统具有硬线输入和输出连接,支持120/208V AC,3相,4线(加地线),Y形输入和输出。
参数特性:20,000VA/16,000瓦功率容量,3相硬线120/208V AC输入/输出连接,具有宽输入电压校正范围:96-144/166-250V AC,3:1峰值因数,可安全支持各种设备。
功能详解:真正的在线双转换UPS,采用IGBT技术,始终提供纯净的正弦波AC输出,通过停电、电压波动和浪涌维持持续运行,零转换时间,去除谐波失真、电脉冲、频率变化等电力问题。
应用信息:适用于关键任务应用,为连接的设备提供最高级别的电力保护。
封装信息:UPS系统(电源和电池组件在一个模块中),DB9电缆,保修信息,使用手册。
SU20K3/3 价格&库存
很抱歉,暂时无法提供与“SU20K3/3”相匹配的价格&库存,您可以联系我们找货
