SU80KX
SU80KX
    TRIPPLITE
    INTL UPS SYSTEM SMART
SU80KX 数据手册
SmartOnline 80kVA Modular 3-Phase UPS System, On-line Double-Conversion International UPS (not expandable to 120kVA) Highlights ● 80,000 VA (80kVA) 3-phase tower UPS ● N+1 redundant modular architecture helps assure 100% availability ● 1+1 parallel capability allows for system redundancy or increased capacity ● Low THDi reduces installation costs by permitting 1:1 generator sizing ● 3-phase hardwire (220/380V, 230/400V or 240/415V AC, 3phase, 4-wire + ground, wye) input/output ● IGBT technology and zero transfer time, on-line, doubleconversion operation ● Runtime is expandable via external battery cabinet options MODEL NUMBER: SU80KX Package Includes Description ● SU80KX UPS System ● Serial cable ● Instruction manual ● Warranty information Tripp Lite's SU80KX (80kVA) SmartOnline Modular 3-Phase Intelligent, True On-Line UPS System provides 100% system availability with N+1 modular architecture and 1+1 parallel capability. In N+1 configuration, the SU80KX provides four self-contained, redundant 20kVA power modules that can be hotswapped (load remaining powered) if maintenance is required. In 1+1 configuration , two SU80KX models connected in parallel can provide fail-safe redundancy (two 80kVA models supporting a 80kVA load) or increased capacity (two 80kVA models supporting a 160kVA load). Large capacity 80,000VA/64,000W UPS continually converts incoming AC power into filtered DC power, and then resynthesizes it back into AC power with a pure sine wave. Perfectly regulated, continuous sine wave output with zero transfer time assures compatibility with all equipment types. High input power factor, advanced IGBT inverter technology and Digital Signal Processor (DSP) technology produce less than 3% input total harmonic distortion (THDi). With low THDi, generators run cooler and last longer, allowing managers to save installation costs by installing a generator with a capacity equal to the equipment load (1:1 ratio). Extremely efficient operation (up to 97%) saves money by lowering electricity consumption. Hardwire input and output connections. Frequency is 50 or 60 Hz (auto-selectable). SU80KX power modules are housed in a single small-footprint tower compartment. Battery module (Model BP480V40C) is housed in a separate stand-alone hardwired external battery compartment (required for UPS operation/backup battery support; order separately). Battery runtime can be extended with additional stand-alone hardwired external battery modules. A manual bypass breaker and an automatic bypass function ensure 100% availability of connected equipment by safely passing through AC power if the UPS requires maintenance. Features ● N+1 configuration: If maintenance is required, four self-contained, redundant 20kVA power modules can be hot-swapped with the load remaining powered ● 1+1 configuration: Two SU80KX can be connected in parallel to provide either fail-safe redundancy or increased capacity 1/5 ● High input power factor, advanced IGBT inverter technology and Digital Signal Processor (DSP) technology produce low input total harmonic distortion (THDi) ● Low THDi (less than 3%) reduces installation costs by allowing 1:1 generator sizing ● Extremely efficient operation (up to 97%) saves money by reducing electricity consumption ● True on-line, double-conversion UPS with IGBT technology provides pure sine wave AC output at all times ● Maintains continuous operation with zero transfer time through blackouts, voltage fluctuations and surges ● Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power problems ● 80,000VA/64,000W power capacity with 3-phase, hardwire input/output connections ● Wide input voltage correction range: 173-300V/276-477V AC ● Precision +/-1% output voltage regulation ● Battery modules (Model BP480V40C) are housed in a separate, stand-alone hardwired external battery compartment (required for UPS operation/backup battery support; order separately) ● Battery runtime can be extended with additional stand-alone hardwired external battery modules (Model BP480V40C; order separately) ● Front panel combination LCD/LED display includes a real-time event log screen with up to 500 events listed ● Dynamic battery management screen optimizes battery function to lengthen service life and allow cold restart of the UPS ● Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from www.tripplite.com/poweralert ● Compatible Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD support a wide variety of UPS control and monitoring capabilities ● Emergency Power Off button turns UPS output OFF and disables Bypass output ● Built-in Emergency Power Off (EPO) dry-contact interface supports remote emergency shutdown in large facilities Specifications OVERVIEW UPC Code 037332141422 UPS Type On-Line INPUT Rated input current (Maximum Load) 121A / 116A / 111A Nominal Input Voltage(s) Supported 220/380V 3-PH Wye; 230/400V 3-PH Wye; 240/415V 3-PH Wye Nominal Input Voltage Description 3-Phase Wye, 4 wire (L1, L2, L3, N, G) UPS Input Connection Type Hardwire Input Phase 3-Phase OUTPUT Output Volt Amp Capacity (VA) 80000 Output Capacity (kVA) 80 2/5 Output Watt Capacity (Watts) 64000 Output kW Capacity (kW) 64 Power Factor 0.8 Crest Factor 3:1 Frequency Compatibility 50 / 60 Hz Output Voltage Regulation (Line Mode) +/-1% Output Voltage Regulation (Battery Mode) +/-1% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 220/380V 3-PH Wye; 230/400V 3-PH Wye; 240/415V 3-PH Wye Output Receptacles Hardwire Individually Controllable Load Banks No BATTERY Expandable Battery Runtime Battery set sold separate Expandable Runtime Yes Expandable Runtime Description External battery pack wiring is contractor supplied External Battery Pack Compatibility  BP480V200 ;  BP480V300 ;  BP480V400 ;  BP480V40C ;  BP480V500  DC System Voltage (VDC) +/- 240VDC Battery Replacement Description Hot-swappable, replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction Maintains continuous operation without using battery power during overvoltages to 276-477 (3-phase, 4-wire, wye), reducing output within 1% of nominal Undervoltage Correction Maintains continuous operation without using battery power during brownout/undervoltage conditions to 173-300 (3phase, 4-wire, wye) USER INTERFACE, ALERTS & CONTROLS Switches ON button turns UPS inverter on. OFF button turns UPS inverter off. LCD Display Control Buttons browse through and select items displayed on LCD screen. EPO (Emergency Power Off) button turns UPS output off and disables Bypass output Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Alarms signal a variety of operational conditions: low-battery, overload, shutdown, bypass and more 3/5 LED Indicators 4-LED Display: Displays normal AC input, on battery power, bypass input and fault conditions SURGE / NOISE SUPPRESSION EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 5950 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Tower Cooling Method Fans Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 856 Primary UPS Height (mm) 1,168 Primary UPS Width (mm) 521 Shipping Dimensions (hwd / cm) 139.70 x 72.39 x 107.95 Shipping Dimensions (hwd / in.) 55.00 x 28.50 x 42.50 Shipping Weight (kg) 311.98 Shipping Weight (lbs.) 687.80 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 116.84 x 52.07 x 85.60 UPS Power Module Dimensions (hwd, in.) 46 x 20.5 x 33.7 UPS Power Module Weight (kg) 244.03 UPS Power Module Weight (lbs.) 538 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 14016 Battery Mode BTU / Hr. (Full Load) 13951 COMMUNICATIONS Network Management Cards  SNMPWEBCARD ;  TLNETCARD ;  WEBCARDLX  4/5 PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert Local software at http://www.tripplite.com/poweralert Communications Cable DB9 cabling included Communications Interface DB9 Serial; Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) Maintains continuous operation without using battery power during brownout/undervoltage conditions to 173-300V AC (3-phase, 4-wire, wye). Below this point, output is maintained utilizing reserve battery power High Voltage Transfer to Battery Power (Setpoint) Maintains continuous operation without using battery power during overvoltages to 276-477V AC (3-phase, 4-wire, wye), reducing output within 1% of nominal. Above this point, output is maintained utilizing reserve battery power FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic inverter bypass; Hot swappable batteries Green Energy-Saving Features High efficiency economy mode operation; Schedulable daily hours of economy mode operation STANDARDS & COMPLIANCE UPS Certifications CE WARRANTY Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty 3-Phase Warranty Statement Tripp Lite 3-Phase UPS Factory Warranty © 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 5/5
SU80KX 价格&库存
很抱歉,暂时无法提供与“SU80KX”相匹配的价格&库存,您可以联系我们找货
