SU16000RT4U
SU16000RT4U
    TRIPPLITE
    UPS SMART ONLINE RACKMOUNT
SU16000RT4U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 208/240 & 120V 16kVA 11.2kW Double-Conversion UPS, 8U, Extended Run, Network Card Slot, USB, DB9, Bypass, NEMA Outlets MODEL NUMBER: SU16000RT4U Highlights ● 16kVA / 16,000VA / 11,200W on-line double-conversion UPS, split phase input ● 208/120V or 240/120V +/-3% output at 60Hz, 94% Efficient Economy-mode option ● 8U Rack/Tower compatible; Hotswappable power and battery modules ● USB, RS232 & EPO ports; slot for network management card options ● Front panel LEDs with detailed LCD monitoring and control screen ● Expandable runtime with optional external battery packs ● Hardwire input (4 wire split phase); L6-30R, C19 & 515/20R outlets Package Includes ● SU16000RT4UPM UPS Power Module ● BP192V18-4U External battery pack ● SUPDMB16K Detachable PDU with manual bypass switch ● 4 post rackmount installation brackets Description Tripp Lite 16kVA SmartOnline Hot-Swappable Modular Rack/Tower UPS offers 16,000 VA on-line, double-conversion UPS support for server, network and telecommunications equipment. Maintains battery-derived AC output during blackouts with active, full-time power conditioning. Fault-tolerant autobypass prevents unexpected service interruptions during overload or internal fault conditions. 4U power module and 4U external battery pack installs in 8 rack spaces (8U). Upright tower installation supported with optional accessories. Maintains full-time sine wave output within 3% of selectable 208/120 or 240/120V AC. Corrects brownouts and overvoltages from 65V to 140V (L-N). Expandable runtime with optional external battery packs. Converts raw input from AC to DC, then resynthesizes output power back to perfect sine wave AC output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS types. Highly efficient operation in optional economy mode setting, saving BTU heat output and energy costs. Network-grade AC surge and noise suppression. Network management interfaces include combination DB9 RS-232 enabled and dry contact serial port, enhanced USB port and slot for network management card options. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports simultaneous detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces. PowerAlert UPS monitoring software is available via free download. Supports Emergency Power Off (EPO) via built-in interface. Front panel LEDs and LCD readout with scroll controls support visual monitoring of all major UPS functions. LED/LCD display panel easily rotates for viewing in rackmount or tower configurations. Split phase 4 conductor hardwire input and output supported. UPS supported outlets include two L6-30R, six C19 and 5 low voltage 5-15/20R. Output connections are mounted on a detachable backplate with manual bypass switch to enable hot-swappable UPS replacement without powering off connected equipment. External battery packs are field replaceable and hot swappable. Attractive all-black color scheme. $250,000 Ultimate 1/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● True online, double-conversion UPS provides pure, full-time sine wave AC output free of surges, voltage fluctuations and line noise ● 16,000 VA/11,200 watt output power capacity with dual voltage output of 208/120 or 240/120V ● 4U high power density power module and 4U external battery pack supports rackmount installation in 8 rack spaces ● Dual conversion UPS actively converts raw input from AC to DC, then back to perfect sine wave AC output with enhanced protection from harmonic distortion, fast electrical impulses and other hard-tosolve power problems not addressed by other UPS types ● Hardwire input terminals, hardwire output and output receptacles are mounted on a detachable backplate with manual bypass switch to enable hot-swappable UPS replacement without powering off connected equipment ● Provides perfectly regulated, sine wave output power free of line noise, transient surges and frequency variation for the most efficient operation of critical servers, networking and telecommunications equipment ● Maintains output within 3% of selected 208/120 or 240/120V nominal voltage during brownouts and overvoltages ● Supports connected equipment during blackouts for 12/5 minutes at half/full load levels, runtime is further expandable with optional external BP192V18-4U battery packs ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Intelligent battery management system extends battery life ● Highly efficient economy mode option ● Network interfaces support simultaneous communications via DB9 port, USB port and slot for network management card options ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● DB9 port supports RS-232 and dry contact messaging ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Built-in Emergency Power Off (EPO) interface with cable ● Includes 13 output receptacles (2 L6-30R, 6 C19, 5 NEMA 5-15/20R) plus hardwire output, all of which are available for simultaneous use ● Split phase, 4 conductor hardwire input connection (featured on included detachable PDU). ● Front panel LEDs and LCD readout with scroll button enables visual confirmation of all major UPS functions and current site electrical conditions ● Front panel switches enable power on/off control, self-test and alarm cancel functions ● Included adjustable mounting rails support installation in 4 post 19 inch rack enclosures ● Optional 2POSTRMKITHD enables 2 post rackmount installation ● Optional 2-9USTAND set of tower stands supports upright tower installation ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332140487 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 68A Nominal Input Voltage(s) Supported 120/208V (Split phase L1,L2,N,G); 120/240V (Split phase L1,L2,N,G) UPS Input Connection Type Hardwire UPS Input Connection Description 4 wire split-phase input (L1, L2, N, G) Recommended Electrical Service 70A 208/240-120 Split Phase (L1, L2, N, G); 4 AWG wiring recommended OUTPUT Output Capacity (VA) 16000 Output Capacity (kVA) 16 Output Capacity (Watts) 11200 Output Capacity (kW) 11.2 Output Capacity Details 16,000VA, 11,200W (240V) / 13,860VA, 11,200W (208V); Supports up to 105% load continuously in double conversion mode, 106 to 125% for 3 minutes, 126 to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support equipment directly from mains power; Double conversion mode is automatically restored as the overload is cleared Power Factor 0.7 Crest Factor 3:1 Nominal Voltage Details 240/120V or 208/120V split phase output Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) +/- 3% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 3% Output Receptacle Details Supports North American 208/120V or 240/120V split-phase hardwire output (L1, L2, N, G) Output Circuit Breakers 20A branch rated double pole breakers (x3) protect 2 C19 and 1 5-15/20R outlets each, 30A branch rated double pole breakers (x2) protect 1 L6-30R outlet each, 20A single pole breakers (x2) protect one 5-15/20R outlet each Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V; 208V; 240V Output Receptacles (5) 5-15/20R; (2) L6-30R; (6) C19; Hardwire 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5 min. (11,200w) Runtime Half Load (min.) 12 min. (5600w) Expandable Runtime Yes External Battery Pack Compatibility  BP192V18-4U  DC System Voltage (VDC) 192 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 80% (typical, full load discharge) Battery Replacement Description Hot-swappable, user replaceable external battery packs VOLTAGE REGULATION Voltage Regulation Description +/-3% output voltage regulation in online, double-conversion mode Overvoltage Correction Corrects overvoltages to 140 (measured L1-N : L2-N) Undervoltage Correction Corrects undervoltages to 65V (measured L1-N : L2-N) USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options; LED/LCD panel rotates for viewing in rack/tower formats Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and execute scrolling LCD functions; bundled PDU includes bypass switch to enable hot-swap UPS power module replacement Alarm Cancel Operation Alarm cancel switch Audible Alarm Unique audible alarms for all major UPS, environmental and power conditions (see manual) LED Indicators 6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD screen offers additional information and control options SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 3620 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 8U Cooling Method Fan 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Included Battery Pack Dimensions (hwd / in.) 7 x 17.5 x 27.8 Included Battery Pack Weight (lbs.) 239 Included Battery Pack Weight (kg) 108.41 Included Mounting Accessory Description 2 sets of adjustable 4 post rack rails included Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ); Tower ( 2-9USTAND ) Maximum Device Depth (cm) 86.36 Maximum Device Depth (in.) 34 Maximum Device Depth (mm) 864 Minimum Required Rack Depth (cm) 101.60 Minimum Required Rack Depth (inches) 40 Optional Mounting Accessory Notes 2 sets of  2POSTRMKITHD  required for 2 post rackmount installation of separate power module and battery pack Primary UPS Depth (mm) 706 Primary UPS Height (mm) 178 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 36.00 x 24.00 x 34.00 Shipping Dimensions (hwd / cm) 91.44 x 60.96 x 86.36 Shipping Weight (lbs.) 448.80 Shipping Weight (kg) 203.57 Unit Dimension Details Includes 4U battery pack, 4U UPS/power module and detachable bypass PDU; MAXIMUM DEVICE DEPTH specification refers to the whole UPS installed depth with bypass PDU installed UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 17.78 x 44.45 x 70.61 UPS Power Module Dimensions (hwd, in.) 7 x 17.5 x 27.8 UPS Power Module Weight (kg) 39.01 UPS Power Module Weight (lbs.) 86 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius. Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius. Relative Humidity 0 to 95%, non-condensing 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Mode BTU / Hr. (Full Load) 5717 AC Economy Mode BTU / Hr. (Full Load) 2438 Battery Mode BTU / Hr. (Full Load) 4248 AC Economy Mode Efficiency Rating (100% Load) 94% Operating Elevation (ft.) 0-3000m (0 to 10,000 ft.) Audible Noise 60 dBA at front side 1 meter Operating Elevation (m) 0-3000 m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description RS232 and contact closure communications are supported on one DB9 port PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Transfer Time (Economy Mode) 2 milliseconds typical in optional economy mode Low Voltage Transfer to Battery Power (Setpoint) 65V (L1-N:L2-N) High Voltage Transfer to Battery Power (Setpoint) 140V (L1-N:L2-N) FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Expandable battery backup; Hot swappable UPS power module; Hot swappable batteries; Manual bypass switch; On-Line/Double-Conversion; Remote management; Sine wave output; Zero transfer time Green Energy-Saving Features High efficiency economy mode operation; Schedulable daily hours of economy mode operation WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
SU16000RT4U
### 物料型号 - 型号:SU16000RT4U
### 器件简介 - Tripp Lite 16kVA SmartOnline系列是一款热插拔模块化机架/塔式不间断电源(UPS),提供16,000 VA在线双转换UPS支持,适用于服务器、网络和电信设备。在停电期间通过电池供电维持AC输出,并具有全时主动功率调节功能。
### 引脚分配 - 包含两个L6-30R、六个C19和五个5-15/20R插座。
### 参数特性 - 输出功率:16,000 VA/11,200瓦 - 双电压输出:208/120V或240/120V - 4U高功率密度电源模块和4U外置电池包,支持8U机架安装 - 硬线输入终端,硬线输出和输出插座安装在带手动旁路开关的可拆卸背板上,支持热插拔UPS更换
### 功能详解 - 提供纯净的全时正弦波AC输出,无浪涌、电压波动和线路噪音 - 在电压瞬变和频率变化期间维持输出在选定的208/120V或240/120V标称电压的3%以内 - 支持连接设备在停电期间分别以半载和全载水平运行12分钟和5分钟,可通过外置BP192V18-4U电池包扩展运行时间
### 应用信息 - UPS应用:关键任务应用
### 封装信息 - 主要形态因素:机架安装 - 机架高度:8U - 冷却方法:风扇 - 包括电池包尺寸(高宽深/英寸):7x17.5x27.8 - 包括电池包重量(磅):239 - 包括电池包重量(千克):108.41
SU16000RT4U 价格&库存
很抱歉,暂时无法提供与“SU16000RT4U”相匹配的价格&库存,您可以联系我们找货
