SU30K3/3
SU30K3/3
    TRIPPLITE
    UPS SMARTONLINE 30KVA 24KW IGBT
SU30K3/3 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 3-Phase 120/208V 30kVA 24kW Double-Conversion UPS, Extended Run, 2 internal batteries, Network Card Options, Tower, DB9 Serial, Hardwire Highlights ● 30,000 VA (30kVA) tower UPS with internal batteries ● Saves valuable space and simplifies runtime scalability ● 3-phase hardwire input and output (120/208VAC). Wide input voltage correction range (96 - 144V AC / 166 - 250V AC) ● IGBT technology and zero transfer time, on-line, doubleconversion operation ● 3 communication ports, Network card slot and EPO jack MODEL NUMBER: SU30K3/3 Package Includes Description Tripp Lite's SU30K3/3 30kVA SmartOnline 3-Phase Intelligent, True On-Line UPS System has been redesigned to save valuable space and simplify runtime scalability. Power and battery components are combined into a single, small-footprint module (the smallest in its class). A robust internal battery runtime capability can be easily extended by installing additional optional internal battery packs through the convenient front panel access door. The SU30K3/3 provides mission-critical equipment with the highest level of power protection available. Large capacity 30,000VA/24,000 watt UPS continually converts incoming AC power into filtered DC power, and then resynthesizes it back into AC power with a pure sine wave. Perfectly regulated, continuous sine wave output with zero transfer time offers compatibility with all equipment types. IGBT inverter technology produces output power with
SU30K3/3 价格&库存
很抱歉,暂时无法提供与“SU30K3/3”相匹配的价格&库存,您可以联系我们找货
