SU80K
SU80K
    TRIPPLITE
    UPS SMART ONLINE
SU80K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 120/208V 3-Phase Wye 80kVA Modular 3-Phase UPS System, On-line DoubleConversion UPS for North America Highlights ● 80,000 VA (80kVA) tower UPS with 4 hot-swappable power modules ● N+1 redundant modular architecture helps ensure 100% availability ● 1+1 parallel capability allows for system redundancy or increased capacity ● Low THDi saves installation costs by allowing 1:1 generator sizing ● 3-phase hardwire (120/208VAC) input/output. Wide input voltage correction range (94150VAC/163-260VAC) ● On-line, double-conversion operation with zero transfer time; IGBT technology; extremely efficient operation (up to 96%) ● Runtime is expandable via external battery cabinet options MODEL NUMBER: SU80K Package Includes Description ● SU80K UPS System ● DB9 serial cable ● Parallel cable (for 1+1 operation) ● Instruction manual and startup checklist ● Warranty information Tripp Lite's SU80K (80kVA) SmartOnline Modular 3-Phase Intelligent, True On-Line UPS System provides 100% system availability with N+1 modular architecture and 1+1 parallel capability. In an N+1 configuration, the SU80K features four self-contained, redundant 20kVA power modules that can be hotswapped (with the load powered) if maintenance is required. Connect two SU80K models in parallel (1+1 configuration) to provide fail-safe redundancy (two 80kVA models supporting a 80kVA load) or to increase capacity (two 80kVA models supporting a 160kVA load). The SU80K provides mission-critical equipment with the highest level of power protection available. Large capacity 80,000VA/64,000W UPS continually converts incoming AC power into filtered DC power, and then resynthesizes it back into AC power with a pure sine wave. Perfectly regulated, continuous sine wave output with zero transfer time offers compatibility with all equipment types. The SU80K's high input power factor, advanced IGBT inverter technology and Digital Signal Processor (DSP) technology create less than 3% input Total Harmonic Distortion (THDi). With SU80K's low THDi, generators run cooler and last longer, allowing managers to save installation costs by installing a generator with a capacity equal to their equipment load (a 1:1 ratio). Extremely efficient operation (up to 96%) saves money by lowering electricity consumption. Hardwire input and output connections support a variety of permanent or PDU style power connections. The SU80K features 120/208V AC, 3-phase, 4-wire (plus ground), wye input and output. It also features a wide input voltage correction range: 94-150/163-260VAC. Frequency is 50 or 60 Hz (autoselectable). The SU80K features a single small-footprint tower power module. A stand-alone hardwired external battery module (Model BP480V40C with matching battery cabinets, available separately) is required for operation and to provide battery backup support. Additional external BP480V40C battery modules can be connected for extended runtime. Other battery cabinets for extended runtime solutions also available; contact Tripp Lite for more information. A manual bypass breaker as well as an automatic bypass function ensure 100% availability of connected equipment by safely passing through AC power if 1/6 1000 Eaton Boulevard Cleveland, OH 44122 United States the UPS requires maintenance. A built-in RS-232 communication port works with PowerAlert Software, available via free download, to provide shutdown commands and condition reporting. An accessory slot accepts an optional internal network management card. Front panel combination LCD/LED display alerts users to a variety of UPS operational modes and conditions. The LCD display includes a real-time event log screen with up to 500 events listed. A dynamic battery management screen optimizes battery function to lengthen service life and allows cold restart of UPS during a prolonged blackout to utilize its batteries for periodic system access or data retrieval. An Emergency Power Off button turns UPS output OFF and disables Bypass output. Built-in Emergency Power Off (EPO) dry-contact interface supports remote emergency shutdown in large facilities. A start-up service program is recommended to enhance the reliability of the installation. Features ● N+1 configuration: four self-contained, redundant 20kVA power modules can be hot-swapped (with the load powered) if maintenance is required ● 1+1 configuration: connect two SU80K models in parallel to provide fail-safe redundancy or to increase capacity ● High input power factor, advanced IGBT inverter technology and Digital Signal Processor (DSP) technology create low input Total Harmonic Distortion (THDi) ● Extremely efficient operation (up to 96%) saves money by lowering electricity consumption ● True on-line, double conversion UPS with IGBT technology provides pure, sine wave AC output at all times ● Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer time ● Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power problems ● 80,000VA/64,000W power capacity with 3-phase, hardwire 120/208VAC input/output connections ● Features a wide input voltage correction range: 94-150/163-260VAC ● Precision +/-1% output voltage regulation ● A stand-alone hardwired external battery module (Models BP480V40C, available separately from Tripp Lite) is required for operation and to provide battery backup support. Additional external battery modules can be connected for extended runtime. ● Front panel combination LCD/LED display includes a real-time event log screen with up to 500 events listed ● Dynamic battery management screen optimizes battery function to lengthen service life and allows cold restart of UPS ● Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● Emergency Power Off button turns UPS output OFF and disables Bypass output ● Built-in Emergency Power Off (EPO) dry-contact interface supports remote emergency shutdown in large facilities ● Start-up service program is recommended to enhance the reliability of the installation Specifications OVERVIEW 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332141330 UPS Type On-Line INPUT Input Phase 3-Phase Nominal Input Voltage(s) Supported 120/208V 3-PH Wye Nominal Input Voltage Description 3-Phase Wye, 4 wire (L1, L2, L3, N, G) UPS Input Connection Type Hardwire OUTPUT Output Capacity (VA) 80000 Output Capacity (kVA) 80 Output Capacity (Watts) 64000 Output Capacity (kW) 64 Power Factor 0.8 Crest Factor 3:1 Frequency Compatibility 50 / 60 Hz Output Voltage Regulation (Line Mode) +/-1% Output Voltage Regulation (Battery Mode) +/-1% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120/208V 3-PH Wye Output Receptacles Hardwire Individually Controllable Load Banks No BATTERY Expandable Runtime Yes Expandable Runtime Description External battery pack wiring is contractor supplied External Battery Pack Compatibility BP480V200; BP480V300; BP480V400;  BP480V40C ;  BP480V500  DC System Voltage (VDC) +/- 240VDC Battery Recharge Rate (Included Batteries) 2 - 4 hours from 10% to 90% Battery Replacement Description Hot-swappable, replaceable batteries 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction Maintains continuous operation without using battery power during overvoltages to 150 / 260 (3-Phase, 4-Wire, wye), reducing output within 1% of nominal Undervoltage Correction Maintains continuous operation without using battery power during brownout / undervoltage conditions to 94 / 163 (3-Phase, 4-Wire, wye) USER INTERFACE, ALERTS & CONTROLS Switches ON button turns UPS's inverter ON. OFF button turns UPS's inverter OFF. LCD Display Control Buttons browses through and selects items displayed on LCD screen. Emergency Power Off button turns UPS output OFF and disables Bypass output. Manual Bypass breaker bypasses the UPS's inverter during maintenance. Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Alarms warn against a variety of operational conditions: low-battery, overload, shutdown, bypass and more LED Indicators 4-LED Display: Displays normal AC input, on battery power, bypass input and fault conditions SURGE / NOISE SUPPRESSION EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 4675 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Tower Cooling Method Fans Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 986 Primary UPS Height (mm) 1,697 Primary UPS Width (mm) 521 Shipping Dimensions (hwd / in.) 75.00 x 28.50 x 48.00 Shipping Dimensions (hwd / cm) 190.50 x 72.39 x 121.92 Shipping Weight (lbs.) 1642.50 Shipping Weight (kg) 745.03 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 169.67 x 52.07 x 98.55 UPS Power Module Dimensions (hwd, in.) 66.8 x 20.5 x 38.8 UPS Power Module Weight (kg) 654.99 UPS Power Module Weight (lbs.) 1444 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 18665 Battery Mode BTU / Hr. (Full Load) 19005 COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable DB9 cabling included Communications Interface DB9 Serial; Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) Maintains continuous operation during undervoltages as low as 94 / 163V AC (3-Phase, 4-Wire, wye). Below this point, output is maintained utilizing battery reserves. High Voltage Transfer to Battery Power (Setpoint) Maintains continuous operation during overvoltages as high as 150 / 260V AC (3-Phase, 4-Wire, wye). Above this point, output is maintained utilizing battery reserves. FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic inverter bypass; Hot swappable batteries; Auto Probe Monitoring (requires WEBCARDLX); Zero transfer time; On-Line/Double-Conversion Green Energy-Saving Features High efficiency economy mode operation; Schedulable daily hours of economy mode operation WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 1-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty 3-Phase Warranty Statement Tripp Lite 3-Phase UPS Factory Warranty 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SU80K
物料型号: - 型号编号:SU80K
器件简介: - Tripp Lite的SU80K是一款80kVA的SmartOnline模块化3相智能真在线UPS系统,提供N+1模块化架构和1+1并行能力,确保100%系统可用性。SU80K具有四个独立的、冗余的20kVA电源模块,如果需要维护,可以进行热插拔(负载供电状态下)。通过连接两个SU80K型号并行(1+1配置),可以提供故障安全冗余(两个80kVA型号支持80kVA负载)或增加容量(两个80kVA型号支持160kVA负载)。
引脚分配: - SU80K具有3相硬线(120/208VAC)输入/输出。具有宽输入电压校正范围:94-150/163-260VAC。
参数特性: - SU80K提供最高级别的电力保护,大容量80,000VA/64,000W UPS持续将输入交流电转换为过滤后的直流电,然后重新合成为纯正弦波的交流电。完美调节的连续正弦波输出,零转换时间,与所有设备类型兼容。 - 高输入功率因数、先进的IGBT逆变技术和数字信号处理器(DSP)技术,创造小于3%的输入总谐波失真(THDi)。 - 极低的THDi使得发电机运行更冷却,寿命更长,允许管理者通过安装与设备负载相等容量(1:1比例)的发电机来节省安装成本。 - 极高效率运行(高达96%)通过降低电力消耗节省资金。 - 硬线输入和输出连接支持各种永久或PDU风格的电力连接。
功能详解: - N+1配置:四个独立的、冗余的20kVA电源模块,如果需要维护,可以进行热插拔(负载供电状态下)。 - 1+1配置:连接两个SU80K型号并行,以提供故障安全冗余或增加容量。 - 真正的在线双转换UPS,采用IGBT技术,始终提供纯净的正弦波AC输出。 - 通过零转换时间维持连续运行,通过停电、电压波动和浪涌来维持连续运行。 - 消除谐波失真、电气脉冲、频率变化等难以解决的电力问题。
应用信息: - SU80K适用于需要最高级别电力保护的关键任务设备。
封装信息: - SU80K采用单塔式小型电源模块。需要一个独立的硬线外部电池模块(型号BP480V40C,需另购)来操作并提供电池备份支持。可以连接额外的外部电池模块以延长运行时间。其他延长运行时间的电池柜解决方案也可用;请联系Tripp Lite了解更多信息。
SU80K 价格&库存
很抱歉,暂时无法提供与“SU80K”相匹配的价格&库存,您可以联系我们找货
