SU10K
SU10K
    TRIPPLITE
    UPS TRUE ONLN 10KVA 7KW 120-240V
SU10K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10KVA 7000W SmartOnline UPS System - True online power for mission critical applications MODEL NUMBER: SU10K Highlights ● Hardwired AC terminals can be configured for 208V, 240V or 120V input ● Constant on-line operation isolates equipment from every AC power problem ● Two serial ports, one AS-400 port and free software facilitate unattended shutdown and network-wide power ● Accessory slot accepts optional SNMP, network management and connectivity products ● $100,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) Description Tripp Lite's SU10K UPS System provides continuous on-line power with extended-run capability for ultrasensitive equipment. On-line operation continually regulates incoming power and provides connected equipment with pure sine wave output. 10,000 VA of battery backup allows you to work through short blackouts or safely shut down during longer ones. Unique design features output hardwireable for 120-240 volts, selectable on-line/line interactive operation modes, and 3 built-in serial ports that work with PowerAlert Software to provide simultaneous automatic unattended shutdown of multiple servers. An accessory slot for use with optional SNMP card, network management, and connectivity products. $100,000 Ultimate Lifetime Insurance (USA & Canada Only). No warranty cards required for coverage! Features ● 10,000 VA output power rating (7,000 watts) ● Up to 8 hours typical backup time ● Selectable continuous on-line operation with pure sine wave output or line-interactive with 4 levels of automatic voltage regulation (AVR) Package Includes ● SU10K Power Module ● (1) 10K Battery Pack (SU10KBP) ● Accessory slot for use with optional SNMP card, network management, and connectivity products ● Output hardwireable for 120-240 volt; input hardwire to 208/240 volt, 50 amp service; 50/60 Hertz selectable ● PowerAlert Software and 3 (6 ft.) network cables ● Automatic bypass — if UPS experiences any problems, the unit will automatically provide AC power, surge protection, and voltage regulation without affecting connected equipment, while bypassing the UPS ● Warranty information ● Instruction manual ● Exclusive from Tripp Lite: 3 DB9 serial ports to manage multiple servers simultaneously; SNMPcompatible ● PowerAlert Unattended Shutdown Software and 3 (6') network cables included ● Exclusive from Tripp Lite: PowerAlert Software compatible with every brand of UPS, from every manufacturer ● Manual bypass — UPS can be placed in temporary bypass mode for maintenance without affecting connected equipment ● Complete surge protection and EMI/RFI noise filtering ● Start-up service and On-Site service plans available — contact Tripp Lite Service Plan Support ● $100,000 Ultimate Lifetime Insurance (USA & Canada Only). No warranty cards required for coverage! ● Diagnostic LEDs (indicate 17 performance conditions) ● Hot-swap battery replacement ● External battery capability; battery packs include built-in battery charger to maintain base recharge rate ● Retractable casters for ease of movement Specifications OVERVIEW UPC Code 037332118103 UPS Type On-Line INPUT 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Input Voltage(s) Supported 200V AC; 208V AC; 220V AC; 230V AC; 240V AC UPS Input Connection Type Hardwire Recommended Electrical Service 50A 208V Input Connection Type Hardwire Voltage Compatibility (VAC) 208; 240 Input Phase Single-Phase OUTPUT Output Capacity (VA) 10000 Frequency Compatibility 50 / 60 Hz Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V; 208V; 240V Output Receptacles Hardwire Output Nominal Voltage 208/240 & 120V (simultaneous) Output Voltage Regulation Maintains pure sine wave output at all times, regulated within 2% of selected nominal output voltage, less than 5% total harmonic distortion Output Frequency Regulation Regulates line frequency to 50/60Hz +/- 0.05Hz Overload Protection Resettable circuit breaker Individually Controllable Load Banks No BATTERY Runtime Full Load (min.) 12 min. (10kVA) Runtime Half Load (min.) 31 min. (5kVA) Expandable Runtime Yes Expandable Runtime Description Supports extended runtime with optional external battery pack  BP240V10RT3U  (multi-pack compatible) DC System Voltage (VDC) 240 Battery Access Batteries contained in separate battery enclosure Battery Pack Accessory (Optional) SUBP (optional) Typical Battery Lifespan 3-6 years, depending on usage Battery Charge 2-4 hours to 90% VOLTAGE REGULATION Voltage Regulation Description Voltage correction keeps output voltage within 3% of 208/240V (depending on setting) without depleting battery power when input voltage is between 156 and 280V AC. Overvoltage Correction 280 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Brownout Correction 156 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Yes, plus LCD screen Audible Alarm Yes SURGE / NOISE SUPPRESSION EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Tower Material of Construction Steel Cooling Method Cooling fan Form Factors Supported Tower Shipping Dimensions (hwd / in.) 61.00 x 60.00 x 34.00 Shipping Dimensions (hwd / cm) 154.94 x 152.40 x 86.36 Shipping Weight (lbs.) 745.00 Shipping Weight (kg) 337.93 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) Power Module 74.9 x 44.5 x 78.7, Battery Pack 74.9 x 44.5 x 78.7 ENVIRONMENTAL Relative Humidity 0 to 95%, non-condensing COMMUNICATIONS Network Monitoring Port 3 built-in DB9 communication ports (1 RS232, 1 Contact closure, 1 AS400) for use with PowerAlert software and cabling. SNMP Compatibility Yes, with SNMPWEBCARD external adapter Communications Interface Contact closure; DB9 Serial; Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) Zero Low Voltage Transfer to Battery Power 280 High Voltage Transfer to Battery Power 156 WARRANTY & SUPPORT 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 2-year limited warranty Optional Coverage 3-5 year warranties, plus next day and on-site warranty coverage available for select opportunities. Contact Tripp Lite for additional information. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SU10K 价格&库存
很抱歉,暂时无法提供与“SU10K”相匹配的价格&库存,您可以联系我们找货
