OMNISMART700HG
OMNISMART700HG
    TRIPPLITE
    UPS 700VA 4OUT HOSPITAL GRADE
OMNISMART700HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Omni Smart UPS System - Line-interactive, tower battery backup with hospital grade plug and receptacles Highlights ● 700VA line interactive tower UPS system ● Hospital grade plug and 4 NEMA5-15R hospital grade output receptacles ● Corrects brownouts and overvoltages from 75 to 147V without using battery power ● Enhanced DB9 communications port MODEL NUMBER: OMNISMART700HG Description Tripp Lite's OMNI SMART 700HG offers UPS protection, built-in line interactive voltage regulation, intelligent monitoring and unattended shutdown capability. 700VA power handling capacity supports computers, internetworking equipment and other critical loads during commercial power failures. Line interactive voltage regulation corrects brownouts as low as 75V and overvoltages as high as 147V back to normal 120V levels, saving battery reserves for use only during complete power failures. Includes 4 hospital grade outlets, diagnostic LEDs and built-in DB9 communications port that works with web downloadable PowerAlert Software and cabling to provide automatic unattended shutdown of connected network and PC applications. Features ● Ideal UPS protection for mission critical equipment and computers where hospital-grade input/output connections are required ● Provides connected equipment with continuous power during short and long duration loss of commercial power ● Line-interactive voltage regulation corrects brownouts and overvoltages from 75 to 147 volts back to usable 120v output levels, without using battery power ● Hospital-grade plug and outlets offer added degree of safety to input/output connections ● Supports loads up to 700VA/425 watts ● 22 minutes half load runtime (with 350VA load), 9 minutes full load runtime (with 700VA load) ● Hospital grade input plug and 4 NEMA5-15R hospital grade output receptacles ● 1-DB9 serial port for network interface; SNMP compatible ● Surge protection and EMI/RFI noise filtering ● PowerAlert UPS monitoring and auto-shutdown software available for free download from www.tripplite.com ● Includes complete cabling for remote monitoring via PowerAlert software ● 4 diagnostic LEDs indicate AC present, on battery, voltage correction & battery low/replace ● Battery replacement door ● 2 year product warranty Specifications OVERVIEW UPC Code 037332100504 INPUT Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P-HG UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 1/4 Package Includes ● OMNI SMART 700HG UPS System ● RS-232 monitoring cable ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service 15A 120V Maximum Input Amps 3.8 Maximum Input Watts 460 Input Connection Type NEMA 5-15P Hospital-Grade Voltage Compatibility (VAC) 120 Input Phase Single-Phase OUTPUT Output Capacity (VA) 700 Frequency Compatibility 60 Hz Output Nominal Voltage 120V nominal Output Voltage Regulation LINE MODE: Sine wave line voltage 120V (-18% / +8%) BATTERY MODE: PWM sine wave output 120V +/-5% Output Frequency Regulation LINE MODE: Passes line frequency of 60Hz +/-10% BATTERY MODE: Inverter output regulated to 60Hz +/0.5Hz BATTERY Runtime Full Load (min.) 9 minutes (700VA) Runtime Half Load (min.) 22 minutes (350VA) DC System Voltage (VDC) 12 Battery Access Battery access door allows hot swap battery replacement without powering connected equipment off Replacement Battery Cartridge  RBC52  (quantity 2) Typical Battery Lifespan 3-6 years, depending on usage Battery Charge 2-4 hours to 90% VOLTAGE REGULATION Voltage Regulation Description Automatic Voltage Regulation (AVR) circuits maintain clean, regulated computer-grade 120V nominal output, without using battery power, during brownouts to 75V and overvoltages to 147V Overvoltage Correction Input voltages between 128 and 147V AC are reduced by 12% Brownout Correction Input voltages between 93 and 107V AC are boosted by 14% Severe Brownout Correction Input voltages between 75 and 92V AC are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs 4 front-panel indicator LEDs to display line power status, battery power status, battery low/replace status and voltage regulation operation Switches Yes, includes 2 front panel mounted push-button switches for system enable, self-test and alarm cancel functions Audible Alarm Audible alarm indicates power failure conditions, silenceable via alarm cancel switch. Once cancelled, alarm will resume when approximately 2 minutes of battery operation remain (assuming full load). SURGE / NOISE SUPPRESSION 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous Dataline Suppression - PHYSICAL Primary Form Factor Tower Material of Construction PVC Cooling Method Convection Form Factors Supported Tower Shipping Dimensions (hwd / in.) 14.00 x 8.50 x 11.00 Shipping Dimensions (hwd / cm) 35.56 x 21.59 x 27.94 Shipping Weight (lbs.) 23.00 Shipping Weight (kg) 10.43 Unit Dimensions (hwd / in.) 10.750 x 5.250 x 7.500 Unit Dimensions (hwd / cm) 27.3 x 13.3 x 18.4 Unit Weight (lbs.) 20 Unit Weight (kg) 9.07 ENVIRONMENTAL Relative Humidity 0 to 95%, non-condensing COMMUNICATIONS Network Monitoring Port DB9 LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) 2-4 milliseconds Low Voltage Transfer to Battery Power 75V (resets to line power as voltage increases to 79V) High Voltage Transfer to Battery Power 147V (resets to line power as voltage decreases to 143V) FEATURES & SPECIFICATIONS Cold Start Yes, inverter can be "cold started" to enable temporary AC output during a power failure WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Optional Coverage 3 year, 5 year, next day and on-site warranty coverage available 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
OMNISMART700HG 价格&库存
很抱歉,暂时无法提供与“OMNISMART700HG”相匹配的价格&库存,您可以联系我们找货
