SU1000RTXL2U
SU1000RTXL2U
    TRIPPLITE
    UPS TRUE ONLINE 1KVA 800W 6OUT
SU1000RTXL2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Smart Online Expandable Rack / Tower UPS System - Online, double-conversion protection for mission critical applications Highlights ● 1000VA online 2U expandable rack/tower UPS ● Enhanced serial communications port and SNMP/Web card slot ● Maintains 120V +/-2% output during overvoltages to 138V and brownouts as low as 65V ● 2 load banks, 6 outlets ● Fault tolerant auto-bypass ● $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) MODEL NUMBER: SU1000RTXL2U Description Tripp Lite's Smart Online SU1000RTXL2U online, double conversion UPS protects critical server, networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Multi-use form factor occupies only 2 rack spaces (2U) in standard 19 inch rackmount configuration and includes tower stands to support upright placement. Large capacity 1kVA/800 watt UPS continuously converts incoming AC to DC, then back to perfect sine wave AC output at 120V AC (+/-2%). Removes harmonic distortion, fast electrical impulses, frequency fluctuations and other hard-to-solve power problems not addressed by other UPS types. True sine wave output and zero transfer time offers guaranteed compatibility with all equipment types. Includes 6 outlets arranged in two individually switchable load banks that can be independently controlled via software interface to selectively reboot remote equipment, or shed less critical loads to extend battery runtime for more critical equipment. Battery support can be extended indefinitely through the addition of external 2U rackmount battery packs (part# BP36V142U). Includes slot for internal SNMP/web card, plus DB9 enhanced serial monitoring port for unattended shutdown, remote control and monitoring of UPS system and power data. Compatible with Tripp Lite's Watchdog system service software. Package Includes ● SU1000RTXL2U Online DoubleConversion UPS System ● PowerAlert Software and cabling ● Mounting hardware for 4 post rack enclosures, tower stands ● Instruction manual with warranty information Features ● True online, double conversion UPS provides pure, sine wave AC output at all times ● Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer time ● Removes harmonic distortion, electrical impulses, frequency variations and other hard to solve power problems ● Accepts input voltages between 80 and 138 (65 to 138 at loads under 70%), regulating output to 120v +/-2% ● 1000VA/800 watt power capacity with 6 NEMA 5-15R outlets ● Standard internal battery set provides 18 minutes runtime at half load ● Expandable runtime with multiple external battery packs (part# BP36V142U) ● Innovative design makes unit adaptable for rackmount or tower applications ● Uses only 2 rack spaces (2U) in standard 19 inch rack ● Fault tolerant auto-bypass maintians continuous utility output to connected equipment, even in cases where the UPS is overloaded or suffers an internal failure that requires service ● DB9 serial port for network interface; SNMP compatible ● Slot for optional SNMP/web card (part# SNMPWEBCARD) ● PowerAlert unattended shutdown software and 6 ft. network cable included ● Compatible with Tripp Lite's Watchdog system service software ● Diagnostic LEDs ● Battery replacement door ● Mounting hardware included for 4 post rack enclosures, 2 post telecom rack compatible with separate purchase 2POSTRMKIT accessory ● 2 year manufacturers product warranty ● $250,000 Ultimate Lifetime connected equipment insur Specifications 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332117953 INPUT Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V Maximum Input Amps 8.6 Maximum Input Watts 955 Input Connection Type NEMA 5-15P Voltage Compatibility (VAC) 120 Input Phase Single-Phase OUTPUT Output Capacity (VA) 1000 Frequency Compatibility 50 / 60 Hz Output Nominal Voltage 120V AC Output Voltage Regulation Maintains full-time sine wave output within 2% of 120V, less than 5% total harmonic distortion Output Frequency Regulation Regulates line frequency to 50/60Hz +/- 0.05Hz Overload Protection 15A input breaker Customized Load Management Receptacles "2 individually controllable load banks support automated load shedding and remote reboot on demand of locked network devices. Configurable via PowerAlert software to automatically switch off optional loads, like monitors, to increase available runtime for servers and other critical devices. (bank A consists of 4 outlets / bank B consists of 2 outlets)" BATTERY Runtime Full Load (min.) Internal batteries — 6 min. 1 BP36V142U battery pack (1000VA) — 37 min. Runtime Half Load (min.) Internal batteries — 18 min. 1 BP36V142U battery pack (500VA) — 89 min. Expandable Runtime Yes Expandable Runtime Description Supports extended runtime with optional external battery pack BP36V142u (multi-pack compatible) DC System Voltage (VDC) 36 Battery Access User replaceable, hot swap battery replacement supported via front access panel Battery Pack Accessory (Optional) BP36V142U (optional) Typical Battery Lifespan 3-6 years, depending on usage Battery Charge 2-4 hours to 90% 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States VOLTAGE REGULATION Voltage Regulation Description On-line, double-conversion power conditioning maintains output within 2% of 120 volts at all times Overvoltage Correction Maintains output of 120V +/-2% during overvoltages to 138V AC Brownout Correction Maintains output of 120V +/-2% during undervoltages to 80V AC Severe Brownout Correction At load levels less than 70%, UPS maintains output of 120V +/-2% during undervoltages to 65V AC USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs 6 LED STATUS DISPLAY: line power (green), online (green), bypass (yellow), on battery (green), overload (red), battery low (yellow) 4 LED LOAD / BATTERY LEVEL DISPLAY (100%, 75%, 50%, 25%) Switches Includes main power off/on switch, plus 1 switch to select battery charge / load level display Audible Alarm Multi-function audible alarm offers notification of UPS start, backup operation, low battery warning, overload, UPS fault and remote shutdown SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount; Tower Material of Construction Steel Cooling Method Built-in cooling fan Form Factors Supported Supports 2U rackmount installation in 4 post rack enclosures. 2 post rackmount installation supported with optional 2POSTRMKIT. Upright tower installation supported with included tower stands Shipping Dimensions (hwd / in.) 10.20 x 23.50 x 24.50 Shipping Dimensions (hwd / cm) 25.91 x 59.69 x 62.23 Shipping Weight (lbs.) 63.60 Shipping Weight (kg) 28.85 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 19.000 Unit Dimensions (hwd / cm) 8.89 x 44.5 x 47 Unit Weight (lbs.) 41 Unit Weight (kg) 18.60 ENVIRONMENTAL Relative Humidity 0 to 95%, non-condensing COMMUNICATIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WatchDog Compatibility Yes, compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application / OS or hard power off/on reboot of connected equipment—ideal for unattended kiosk applications Network Monitoring Port Built-in DB9 port offers both enhanced RS-232 enable monitoring data, plus contact closure monitoring ability EPO Port Supports "Emergency Power Off" via special-order cabling, contact Tripp Lite for more information SNMP Compatibility Yes, includes slot for optional SNMPWEBCARD accessory (#SNMPWEBCARD) LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) Zero, online UPS continuously converts incoming AC to DC, then back to AC. When commercial power is interrupted, UPS maintains continuous output from battery reserves with absolutely no disruption in output AC power. Low Voltage Transfer to Battery Power Maintains continuous operation during undervoltages as low as 80V (65V at load levels under 70%). Below this switchover point, output is supported from battery derived AC power. High Voltage Transfer to Battery Power Maintains continuous operation without using battery power during overvoltages to 138V. Above this point, output is supported from battery derived AC power. FEATURES & SPECIFICATIONS Cold Start Yes, inverter can be "cold started" to enable temporary AC output during a power failure WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Optional Coverage 3-5 year warranties, plus next day and on-site warranty coverage available for select opportunities. Contact Tripp Lite for additional information. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SU1000RTXL2U
物料型号: - 型号编号:SU1000RTXL2U
器件简介: - Tripp Lite的SU1000RTXL2U是一款智能在线式可扩展机架/塔式UPS系统,提供在线双转换保护,适用于关键任务的应用。该设备可保护关键的服务器、网络和电信设备免受停电、电压波动和瞬时浪涌的影响。它具有1kVA/800瓦的容量,能够持续将输入交流电转换为直流电,然后再转换回完美的正弦波交流电输出,输出电压为120V AC(+/-2%)。
引脚分配: - 该UPS系统有6个NEMA 5-15R插座,分为两个可独立控制的负载组,可以通过软件界面独立控制,以选择性重启远程设备或减少非关键负载以延长电池运行时间。
参数特性: - 真正的在线双转换UPS在任何时候都能提供纯净的正弦波交流电输出。 - 在停电、电压波动和浪涌期间保持连续运行,零转换时间。 - 接受输入电压在80至138V之间(负载低于70%时为65至138V),调节输出至120V +/-2%。 - 1000VA/800瓦功率容量。 - 标准内部电池组在半负载下提供18分钟的运行时间。 - 通过多个外部电池包(型号BP36V142U)扩展运行时间。
功能详解: - 该UPS系统具有真正的在线双转换功能,始终提供纯正弦波交流电输出。 - 在输入电压在80V至138V之间时,能够调节输出至120V +/-2%。 - 具有6个插座,分为两个可独立控制的负载组,支持自动化负载卸载和远程重启锁定网络设备。 - 支持通过可选的SNMP/WEB卡(型号SNMPWEBCARD)进行网络监控。
应用信息: - 适用于大型网络、服务器和其他关键设备。
封装信息: - 物理形式:机架安装:塔式。 - 材质:钢。 - 冷却方式:内置冷却风扇。 - 支持2U机架安装在4柱机架中,2柱机架安装支持可选的2POSTRMKIT。支持使用附带的塔式支架进行直立塔式安装。
SU1000RTXL2U 价格&库存
很抱歉,暂时无法提供与“SU1000RTXL2U”相匹配的价格&库存,您可以联系我们找货
