SU2200RTXL2U
SU2200RTXL2U
    TRIPPLITE
    UPS TRUEONLINE 2200VA 1600W 7OUT
SU2200RTXL2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Smart Online Expandable Rack/Tower UPS System - On-line, double-conversion protection for mission-critical applications Highlights ● 2200VA on-line 2U expandable rack / tower UPS ● Enhanced serial communications port and SNMP/Web card slot ● Maintains 120V +/-2% output during overvoltages to 138 and brownouts as low as 65V ● 2 load banks, 7 outlets (5-15/20, L5-20) ● Fault tolerant auto-bypass ● $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) MODEL NUMBER: SU2200RTXL2U Description Tripp Lite's Smart Online SU2200RTXL2U on-line, double conversion UPS protects critical server, networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Multi-use form factor occupies only 2 rack spaces (2U) in standard 19 inch rackmount configuration and includes tower stands to support upright placement. Large capacity 2.2kVA/1600 watt UPS continuously converts incoming AC power to DC power, then back to perfect sine wave AC output at 120V AC (+/-2%). Removes harmonic distortion, fast electrical impulses, frequency fluctuations and other hard-to-solve power problems not addressed by other UPS types. True sine wave output and zero transfer time offers guaranteed compatibility with all equipment types. Includes 7 outlets arranged in two individually switchable load banks. These outlet banks can be independently controlled via software interface to selectively reboot remote equipment, or shed less critical loads to extend battery runtime for more critical equipment. Battery support can be extended indefinitely through the addition of external 2U rackmount battery packs (part# BP48V21-2U). Includes slot for internal SNMP/web card, plus DB9 enhanced serial monitoring port for unattended shutdown, remote control and monitoring of UPS system and power data. Compatible with Tripp Lite's Watchdog system service software. Package Includes ● SU2200RTXL2U On-line Double-Conversion UPS System ● PowerAlert Software and cabling ● Mounting hardware for 4 post rackmount installation/tower stands ● Instruction manual with warranty information Features ● True on-line, double conversion UPS provides pure, sine wave AC output at all times ● Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer time ● Removes harmonic distortion, electrical impulses, frequency variations and other hard to solve power problems ● Accepts input voltages between 80 and 138 (65 to 138 at loads under 70%), regulating output to 120v +/-2% ● 2200VA/1600 watt power capacity with 7 total outlets (6 NEMA 5-15/20R & 1 NEMA L5-20) ● Standard internal battery set provides 18 minutes runtime at half load ● Expandable runtime with multiple external battery packs (part# BP48V21-2U) ● Innovative design makes unit adaptable for rackmount or tower applications (tower stands included) ● Uses only 2 rack spaces (2U) in standard 19 inch rack ● DB9 serial port for network interface; SNMP compatible ● Slot for optional SNMP/web card (part# SNMPWEBCARD) ● PowerAlert unattended shutdown software and 6 ft. network cable included ● Fault tolerant auto-bypass maintians continuous utility output to connected equipment, even in cases where the UPS is overloaded or suffers an internal failure that requires service ● Compatible with Tripp Lite's Watchdog system service software ● Mounting hardware included for 4 post rackmount installation, optional separate purchase accessory 2POSTRMKIT enables installation in 2 post telecom racks ● Installed NEMA 5-20P input plug connects to 20A wall receptacle, includes user installable NEMA 515P replacement plug to enable connection to a standard 15A wall socket ● Diagnostic LEDs ● Battery replacement door ● $250,000 Ultimate Lifetime connected equipment insur ● 2 year manufacturers product warranty 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332100580 INPUT UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 120v Maximum Input Amps 16.2 Maximum Input Watts 1885 Input Connection Type NEMA 5-20P (includes user installable NEMA 5-15P replacement plug) Voltage Compatibility (VAC) 120 OUTPUT Frequency Compatibility 50 / 60 Hz Output Nominal Voltage 120V AC Output Voltage Regulation Maintains full-time sine wave output within 2% of 120V, less than 5% total harmonic distortion Output Frequency Regulation Regulates line frequency to 50/60Hz +/- 0.05Hz Overload Protection Via 30A input breaker and dual 15A output breakers Customized Load Management Receptacles "2 individually controllable load banks support automated load shedding and remote reboot on demand of locked network devices. Configurable via PowerAlert software to automatically switch off optional loads, like monitors, to increase available runtime for servers and other critical devices. (each bank includes 3 outlets)" BATTERY Runtime Full Load (min.) Internal batteries — 6 min. 1 BP48V212U battery pack (2200VA) — 24 min. Runtime Half Load (min.) Internal batteries — 18 min. 1 BP48V212U battery pack (1100VA) — 64 min. Expandable Runtime Yes Expandable Runtime Description Supports extended runtime with optional external battery pack BP48V212U (multi-pack compatible) DC System Voltage (VDC) 48 Battery Access User replaceable, hot swap battery replacement supported via front access panel Battery Pack Accessory (Optional) BP48V212U (optional) Typical Battery Lifespan 3-6 years, depending on usage Battery Charge 2-4 hours to 90% VOLTAGE REGULATION Voltage Regulation Description On-line, double-conversion power conditioning maintains output within 2% of 120 volts at all times Overvoltage Correction Maintains output of 120V +/-2% during overvoltages to 138V AC 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Brownout Correction Maintains output of 120V +/-2% during undervoltages to 80V AC Severe Brownout Correction At load levels less than 70%, UPS maintains output of 120V +/-2% during undervoltages to 65V AC USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs 6 LED STATUS DISPLAY: line power (green), online (green), bypass (yellow), on battery (green), overload (red), battery low (yellow) 4 LED LOAD / BATTERY LEVEL DISPLAY (100%, 75%, 50%, 25%) Switches Includes main power off/on switch, plus 1 switch to select battery charge / load level display Audible Alarm Multi-function audible alarm offers notification of UPS start, backup operation, low battery warning, overload, UPS fault and remote shutdown SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 2440 EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous PHYSICAL Material of Construction Steel Cooling Method Built-in cooling fan Form Factors Supported Supports 2U rackmount installation in 4 post rack enclosures. 2 post rackmount installation supported with optional 2POSTRMKIT. Upright tower installation supported with included tower stands Shipping Dimensions (hwd / in.) 8.00 x 23.50 x 31.00 Shipping Dimensions (hwd / cm) 20.32 x 59.69 x 78.74 Shipping Weight (lbs.) 69.40 Shipping Weight (kg) 31.48 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 22.000 Unit Dimensions (hwd / cm) 8.89 x 44.5 x 52.8 Unit Weight (lbs.) 54.6 Unit Weight (kg) 24.77 ENVIRONMENTAL Relative Humidity 0 to 95%, non-condensing COMMUNICATIONS WatchDog Compatibility Yes, compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application / OS or hard power off/on reboot of connected equipment - ideal for unattended kiosk applications Network Monitoring Port One built-in DB9 port offers both enhanced RS-232 enabled monitoring data, plus contact closure basic monitoring capability EPO Port Supports "Emergency Power Off" via special-order cabling, contact Tripp Lite for more information SNMP Compatibility Yes, includes slot for optional SNMPWEBCARD accessory (#SNMPWEBCARD) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) Zero, online UPS continuously converts incoming AC-to-DC, then back to AC. When commercial power is interrupted, UPS maintains continuous output from battery reserves with absolutely no disruption in output AC power. Low Voltage Transfer to Battery Power Maintains continuous operation during undervoltages as low as 80V (65V at load levels under 70%). Below this switchover point, output is supported from battery derived AC power. High Voltage Transfer to Battery Power Maintains continuous operation without using battery power during overvoltages to 138V. Above this point, output is supported from battery derived AC power. FEATURES & SPECIFICATIONS Cold Start Yes, inverter can be "cold started" to enable temporary AC output during a power failure WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Optional Coverage 3-5 year warranties, plus next day and on-site warranty coverage available for select opportunities. Contact Tripp Lite for additional information. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SU2200RTXL2U
物料型号:Tripp Lite的SU2200RTXL2U是一款在线式、双变换UPS系统。
器件简介:SU2200RTXL2U UPS为关键的服务器、网络和电信设备提供持续的保护,防止停电、电压波动和瞬时浪涌。
它具有2.2kVA/1600瓦的容量,将输入的交流电连续转换为直流电,然后再转换为完美的正弦波交流电输出,输出电压为120V交流电(+/-2%)。
引脚分配:该UPS具备7个插座,分为两个可独立控制的负载组,这些插座组可以通过软件界面独立控制,以选择性地重新启动远程设备或减少不太关键的负载,以延长电池运行时间,确保更关键的设备使用。
参数特性:该UPS为真在线、双变换设计,无论何时都能提供纯净的正弦波交流电输出。
它能够在停电、电压波动和浪涌期间通过零转换时间持续运行,消除谐波失真、电气脉冲、频率变化等难以解决的电力问题。
功能详解:SU2200RTXL2U UPS具备多种功能,包括但不限于:真正的在线双变换UPS,提供纯正弦波交流电输出;在停电、电压波动和浪涌期间维持连续运行,零转换时间;接受80至138V的输入电压(负载低于70%时为65至138V),并调节输出至120V+/-2%的电压;具备2200VA/1600瓦的功率容量;支持通过多个外部电池包扩展运行时间。
应用信息:这款UPS适用于需要不间断电源保护的服务器、网络和电信设备等关键应用场合,同时也适用于需要远程控制和监控的场合。
封装信息:SU2200RTXL2U采用了2U机架式设计,适用于标准的19英寸机架安装,也可支持塔式独立放置(附带塔式支架)。
它还具备一个用于内部SNMP/Web卡的插槽以及一个DB9增强型串行监控端口,用于实现无人值守的关闭、远程控制和监控UPS系统以及电力数据。
以上信息均根据您提供的PDF文档内容进行了中文翻译和分析。
如果需要更详细的技术细节或有其他问题,请随时告知。
SU2200RTXL2U 价格&库存
很抱歉,暂时无法提供与“SU2200RTXL2U”相匹配的价格&库存,您可以联系我们找货
