SMART700
SMART700
    TRIPPLITE
    UPS 700VA 450W 6OUT W/SOFTWARE
SMART700 数据手册
SmartPro Tower UPS - Intelligent, line-interactive battery backup and network power management MODEL NUMBER: SMART700 Highlights ● 700VA line interactive tower UPS ● Maintains 120V nominal output over an input range of 75 to 147V ● Network communications supported via USB port ● Current monitoring ● Input: NEMA 5-15P (120V 15A) / Output: 6 NEMA 5-15R (120V) ● 2 year product warranty / $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) Package Includes Description Tripp Lite's SMART 700 intelligent, line interactive UPS system protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 20 minutes half load runtime and 6 minutes at full load during power failures. 700VA/450 watt power handling capability supports a variety of networking, telecom and various other application types, including the support of multiple network workstations. Includes a total of 6 UPS supported outlets. Supports remote monitoring of UPS and site power conditions via built-in USB monitoring port. Includes PowerAlert UPS monitoring and unattended shutdown software with complete cabling. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level. Wall mountable with UPSWM wallmount bracket. Networkgrade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. Attractive, small-footprint tower housing uses less than 53 square inches of floor or desktop space. Two year warranty with $250,000 connected equipment insur. Features ● 700VA/450 watt power handling capability supports a variety of networking, telecom and various other application types ● Built-in voltage regulation and battery support, plus complete AC line surge suppression prevents equipment damage, data loss and downtime ● Large internal batteries offer 20 minutes half load runtime and 6 minutes at full load during power failures ● Automatic Voltage Regulation (AVR) circuits with two boost and one voltage reduction level maintains usable 120V nominal output over an input voltage range of 75-147V ● Includes a total of 6 NEMA5-15R outlets ● Includes USB communications port for remote monitoring of UPS status and site power conditions ● Communications port enables safe unattended shutdown without data loss during extended power failures ● Communications port supports messaging of UPS and line power status, including on-battery, lowbattery, power-restored, AC line voltage, DC battery voltage and battery capacity ● Communications ports support timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment ● PowerAlert UPS monitoring and unattended shutdown software with complete cabling included 1/5 ● SMART 700 UPS System ● Monitoring cable ● PowerAlert unattended shutdown and UPS/Power monitoring software ● Instruction manual with warranty information ● Battery replacement door ● Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically restarting them and rebooting completely locked computers by automatically switching UPS power off and back on again ● Notification of system status via 5 LEDs and multi-function audible alarms ● Wall mountable with UPSWM wallmount bracket ● Attractive small footprint black tower housing uses less than 53 square inches ● Hot-swappable batteries allow on-site battery replacement ● Cold start capability enables UPS turn-on in battery mode during blackout conditions ● UL (USA), cUL (Canada), NOM (Mexico), Class A (Emissions) Listed ● $250,000 Ultimate Lifetime Insuran. ● 2 year manufacturers product warranty Specifications OVERVIEW UPC Code 037332033765 INPUT Rated input current (Maximum Load) 4.4A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V Input Phase Single-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Volt Amp Capacity (VA) 700 Output Watt Capacity (Watts) 450 Power Factor 0.6 Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) 115V (+/- 5%) Output AC Waveform (AC Mode) Sine wave 2/5 Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 115V; 120V Output Receptacles (6) 5-15R BATTERY Full Load Runtime (min.) 6 min. (450w) Half Load Runtime (min.) 20 min. (225w) DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC52  (x2) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75V to 147V Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 450 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 1800 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Tower 3/5 Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 191 Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / cm) 39.37 x 27.94 x 28.58 Shipping Dimensions (hwd / in.) 15.50 x 11.00 x 11.25 Shipping Weight (kg) 11.34 Shipping Weight (lbs.) 25.00 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 19.05 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.5 UPS Power Module Weight (kg) 9.98 UPS Power Module Weight (lbs.) 22 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 133 Battery Mode BTU / Hr. (Full Load) 565.9 AC Mode Efficiency Rating (100% Load) 92% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software Included Communications Cable USB cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 4/5 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 5/5
SMART700 价格&库存
很抱歉,暂时无法提供与“SMART700”相匹配的价格&库存,您可以联系我们找货
