Internet Office 500VA Low-profile Standby 120V
UPS
MODEL NUMBER: TM500
Highlights
6 outlets (3 UPS/surge, 3 surgeonly)
Built-in RJ11 jacks provide
complete modem/fax surge
protection
Under-monitor design supports
virtually any monitor
$150,000 Ultimate Lifetime
Insurance (USA, Puerto Rico &
Canada only)
Package Includes
Description
Tripp Lite's space-saving TM500 Under-Monitor UPS System provides complete power protection for your
entire computer set-up, even power hungry peripherals. 500 VA of battery backup maintains your Internet
connection, allowing you to work online through short blackouts or safely shut down during longer ones.
Unique design features 6 outlets (3 UPS & surge + 3 surge-only), individually switched outlets and
diagnostic LEDs. Built-in RJ11 jacks prevent surges from damaging your modem/fax equipment. A 6-ft.
telephone cord is also included. $150,000Ultimate Lifetime Insurance (USA, Puerto Rico, & Canada Only).
Features
500 VA output power rating (300 watts)
Up to 30 minutes typical backup time
6 protected outlets (3 UPS & surge + 3 surge-only); 6 ft. cord
Unique space-saving, under-monitor console design
Built-in RJ11 jacks prevent surges from damaging your modem/fax equipment; 6 ft. telephone cord
included
Complete surge protection and EMI/RFI noise filtering
$150,000Ultimate Lifetime Insurance (USA, Puerto Rico. & Canada Only) —
Master switch and 4 auxiliary switches give you control over multiple pieces of your equipment
4 diagnostic LEDs indicate AC Present, line fault, On Battery & Battery Low/Replace
Specifications
OVERVIEW
UPC Code
037332033154
UPS Type
Standby
1/4
TM500 UPS System
6-ft. telephone cord
Warranty information
Instruction manual
INPUT
Rated input current (Maximum Load)
15A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
Input Phase
Single-Phase
OUTPUT
Output Volt Amp Capacity (VA)
500
Output Watt Capacity (Watts)
300
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
+/- 5%
UPS Output Receptacles (Surge
Suppression Only)
3 UPS outlets, 3 surge-only outlets
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(6) 5-15R
BATTERY
Full Load Runtime (min.)
6 min. (300w)
Half Load Runtime (min.)
17 min. (150w)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation, plus 4 switches control individual output
receptacles
Audible Alarm
Audible alarm indicates power-failure
LED Indicators
Front panel LEDs indicate line power status, battery power status and battery low/replace status
SURGE / NOISE SUPPRESSION
2/4
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out)
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Desktop
Installation Form Factors Supported
with Included Accessories
Under-monitor console
Primary UPS Depth (mm)
318
Primary UPS Height (mm)
51
Primary UPS Width (mm)
343
Shipping Dimensions (hwd / cm)
40.64 x 38.10 x 10.16
Shipping Dimensions (hwd / in.)
16.00 x 15.00 x 4.00
Shipping Weight (kg)
5.44
Shipping Weight (lbs.)
12.00
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
5.08 x 34.29 x 31.75
(hwd, in.)
2 x 13.5 x 12.5
UPS Power Module Weight (kg)
5.31
UPS Power Module Weight (lbs.)
11.7
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
65.1
Battery Mode BTU / Hr. (Full Load)
88.7
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
Communications Interface
None
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
3/4
Low Voltage Transfer to Battery
Power (Setpoint)
101
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
WARRANTY
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
很抱歉,暂时无法提供与“TM500”相匹配的价格&库存,您可以联系我们找货
