SM1000RMNAFTA
SM1000RMNAFTA
    TRIPPLITE
    UPS 1000VA 640W 6OUT RACK/TOWER
SM1000RMNAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Smart Pro Line Interactive Rack/Tower UPS NAFTA assembled version of SMART1000RM2U MODEL NUMBER: SM1000RMNAFTA Highlights ● 1000VA / 1kVA line interactive 1U rackmount UPS ● Maintains sine-wave 120V nominal output over an input range of 83 to 147V ● Network communications supported via USB port, serial port, SNMP/Web card slot and EPO interface ● Current monitoring and switched PDU control via 2 single-outlet load banks ● Input: NEMA 5-15P (120V 15A) / Output: 6 NEMA 5-15R (120V) ● 2 year product warranty / $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) Package Includes Description 1000VA line interactive UPS for server, network and telecommunications equipment/1U rackmount form factor/Corrects brownouts and overvoltages from 83 to 147/Sine wave output in both AC and battery ● SM1000RMNAFTA UPS System ● Mounting hardware ● Cabling for USB & DB9 monitoring and EPO switching ● PowerAlert unattended shutdown and UPS/Power monitoring software ● Warranty information and instruction manual mode/Uninterruptible Power Supply (UPS) maintains battery derived AC output during blackouts and severe voltage fluctuations/NEMA 5-15P input plug/Network-grade AC surge and noise suppression/Network management interfaces includes USB port, DB9 serial port and SNMPWEBCARD slot/Supports simultaneous detailed monitoring of equipment load levels, self-test data and mains power conditions via all 3 network interfaces at once/Includes PowerAlert monitoring software and complete cabling/Emergency Power Off (EPO) interface/Integrated 2 bank switched PDU/3 stage metered current monitoring and battery charge LEDs/Mains power and voltage regulation LEDs/Audible alarm/Selftest/Supports 2 or 4 post rackmount installation/Field replaceable, hot swappable internal batteries/Attractive all-black UPS design/Two year warranty with $250,000 Ultimate Lifetime Insurance/Extended warranty and service contracts available. Features ● 1000VA/640 watt output power capacity compatible with North American 120V/60Hz power ● 1U rackmount UPS installs in standard 2 or 4 post 19 inch racks with a depth of only 16.75 inches ● Protects sensitive networking equipment from blackouts, voltage fluctuations and transient surges ● Regulation (AVR) corrects inputs from 83-147VAC back to usable 120V levels without consuming battery power ● Line interactive Automatic Voltage Regulation (AVR) corrects inputs from AVR circuits boost undervoltages by 14% depending on the severity and reduces overvoltages by 12% ● Network interfaces support simultaneous communications via USB, DB9 serial and SNMPWEBCARD slot ● Included PowerAlert UPS monitoring software supports safe unattended shutdown, monitoring and control via local connected servers, plus any number of additional servers over IP ● Communications ports support on-battery, low-battery, power-restored, AC-voltage, DC-voltage, output current monitoring, battery charge current, battery capacity, internal UPS temperature, AC line 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States frequency, timed inverter shutoff, activate self-test and load bank output power control ● Built in Emergency Power Off (EPO) interface with cable ● Sine wave output in AC and battery modes ● Half load runtime of 15 minutes (500VA/320 watts)/Full load runtime of 7 minutes (1000VA/640 watts) ● Includes 6 NEMA 5-15R output receptacles arranged in 2 switchable single-outlet load banks ● Integrated 2 bank switched PDU enables remote outlet management for load shedding or remote reboot of individual devices ● 3 stage metered LEDs offer current monitoring and battery charge level ● Mains power and voltage regulation LEDs offer at-a-glance power status information ● Front panel switches support self-test and alarm cancel functions ● UPS ships fully assembled in full compliance with DOT regulations, no time consuming connection of internal batteries by user required ● UL (USA), cUL (Canada), NOM (Mexico), FCC Class A (Emissions) listed ● 2 year manufacturer's product warranty, $250,000 Ultimate Lifetime Insurance Specifications OVERVIEW UPC Code 037332137487 INPUT Rated input current (Maximum Load) 9.2A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity (VA) 1000 Output Capacity (kVA) 1 Output Capacity (Watts) 640 Power Factor 0.6 Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -21%, +8% 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15R BATTERY Runtime Full Load (min.) 7 min. (640w) Runtime Half Load (min.) 15 min. (320w) DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC64-1U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 83 and 107 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 480 AC Suppression Response Time Instantaneous PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary Form Factor Rackmount Rack Height 1U Cooling Method Fan Included Mounting Accessory Description Adjustable mounting rail kit included Primary UPS Depth (mm) 427 Primary UPS Height (mm) 43 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 9.00 x 24.00 x 20.25 Shipping Dimensions (hwd / cm) 22.86 x 60.96 x 51.44 Shipping Weight (lbs.) 41.50 Shipping Weight (kg) 18.82 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 4.32 x 44.45 x 42.67 UPS Power Module Dimensions (hwd, in.) 1.7 x 17.5 x 16.8 UPS Power Module Weight (kg) 14.51 UPS Power Module Weight (lbs.) 32 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 138.9 Battery Mode BTU / Hr. (Full Load) 477.7 AC Mode Efficiency Rating (100% Load) 94% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software Included Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface USB; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries Green Energy-Saving Features Individually controllable load banks Grounding Lug Back panel grounding lug WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SM1000RMNAFTA
物料型号: - 型号编号:SM1000RMNAFTA
器件简介: - 1000VA的在线互动式UPS,适用于服务器、网络和电信设备,1U机架式安装,可以纠正电压暂降和过电压,从83至147V的电压范围内提供稳定的120V输出。在停电和严重电压波动期间维持由电池提供的AC输出。具有网络级AC浪涌和噪声抑制,支持通过USB端口、DB9串行端口和SNMPWEBCARD插槽进行网络管理。
引脚分配: - 输入:NEMA 5-15P(120V 15A) - 输出:6个NEMA 5-15R(120V)
参数特性: - 输出功率容量:1000VA/640W - 功率因数:0.6 - 频率兼容性:60Hz - 输出电压调节(在线模式):-21%,+8% - 输出电压调节(电池模式):1 +/-5% - 负载管理插座:两个可切换的双口5-15R负载银行
功能详解: - 自动电压调节(AVR)功能可以在83至147V的输入电压范围内维持线路电力操作。 - 网络接口支持通过USB、DB9串行和SNMPWEBCARD插槽的同时通信。 - 包括的PowerAlert UPS监控软件支持安全无人值守关闭、监控和通过本地连接的服务器以及IP上的任何数量的附加服务器进行控制。 - 通信端口支持电池状态、低电池状态、电力恢复、交流电压、直流电压、输出电流监测、电池充电电流、电池容量、内部UPS温度、交流线路频率、定时逆变器关闭、激活自测和负载银行输出功率控制。
应用信息: - 适用于需要稳定电力供应的服务器、网络和电信设备,特别是在电压波动或停电的情况下。
封装信息: - 主要UPS尺寸:高43mm x 宽445mm x 深427mm - 发货尺寸:高9.00英寸 x 宽24.00英寸 x 深20.25英寸 - 发货重量:41.50磅(约18.82公斤)
SM1000RMNAFTA 价格&库存
很抱歉,暂时无法提供与“SM1000RMNAFTA”相匹配的价格&库存,您可以联系我们找货
