SU2200RMNAFTA
SU2200RMNAFTA
    TRIPPLITE
    UPS TRUEONLINE 2.2KVA 1600W 7OUT
SU2200RMNAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline Expandable 2U Rack / Tower UPS System - NAFTA assembled version of SU2200RTXL2Ua Highlights ● 2200VA / 2.2kVA on-line, double-conversion, extendedrun 2U rack / tower UPS ● Maintains sine-wave 100/110/120V +/-2% output during overvoltages to 138 and brownouts as low as 65V (50/60Hz auto-sensing) ● Simultaneous communications via HID compliant USB port, serial port, SNMP/Web card slot and EPO interface ● Fault tolerant auto-bypass mode, current monitoring and switched PDU control via 2 switchable output load banks ● Input: NEMA 5-20P (120V) / Output: 6 NEMA 5-15/20R and 1 NEMA L5-20R (120V) ● $250,000 Ultimate Lifetime Insurance (USA and Canada Only) MODEL NUMBER: SU2200RMNAFTA Package Includes ● SU2200RMNAFTA On-line Double-Conversion UPS System ● PowerAlert Software and cabling ● Mounting hardware for 4 post rack enclosures ● Instruction manual with warranty information Description 2200VA on-line, double-conversion UPS system for critical server, network and telecommunications equipment. 2U rackmount form factor with an installed depth of only 19 in. Expandable battery runtime with optional BP48V60-3UNAFTA external battery packs. Full-time sine wave 100, 110 or 120V +/-2% output. Online, double-conversion Uninterruptible Power Supply (UPS) actively converts raw incoming AC power to DC, then re-converts output back to completely regulated, filtered AC output. Operates continuously without using battery power during brownouts to 65V and overvoltages to 138V. NEMA 520P input plug; NEMA 5-15/20R and NEMA L5-20R output receptacles. Network-grade AC surge and noise suppression. Zero transfer time between AC and battery operation. Network management interfaces support simultaneous communications via USB port, DB9 serial port and SNMPWEBCARD slot. HIDcompliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports simultaneous detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces. Includes PowerAlert monitoring software and complete cabling. Emergency Power Off (EPO) interface. Integrated 2-bank PDU switching supports load shedding and remote-reboot of connected equipment. 3-stage metered current monitoring and battery charge status LEDs. LED display panel easily rotates for better viewing in rackmount or tower configurations. Dataline surge suppression for dialup, DSL or network Ethernet connection. Utility power and voltage regulation LEDs. Audible alarm. Self-test. Fault-tolerant auto-bypass mode. 4-post rackmount accessories included; 2-9USTAND tower kit and 2POSTRMKITWM two post rack & wallmount accessories available. Field-replaceable, hot-swappable internal batteries and external battery packs. Attractive all-black color scheme. $250,000 connected equipment insur; Features ● SmartOnline high performance UPS system is ideal for critical voice, data, medical and industrial network applications ● True on-line, double-conversion UPS provides perfectly regulated sine wave output within 2% of 100/110/120V (user selectable) under all usage conditions ● Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer time ● Removes harmonic distortion, fast electrical impulses, frequency variations and other hard to solve power problems not addressed by other UPS types ● Corrects line voltage conditions as low as 65V and as high as 138V back to selectable 100/110/120V (+/-2%) values 1/6 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Standard internal battery set offers 18 minutes runtime at half load (800W) and 6 minutes at full load (1600W) ● Optional BP48V60-3UNAFTA external battery pack increases runtime to 132 minutes at half load (800W) and 61 minutes at full load (1600W/multi-pack compatible) ● Compact rackmount form factor installs using only 2 rack spaces (2U) with a maximum installed depth of only 19 inches ● Ships with all mounting accessories for 4 post rackmount installation ● Optional 2POSTRMKITWM enables 2 post rackmount or wallmount installation ● Optional 2-9USTAND accessory enables small-footprint upright tower placement ● Fault tolerant auto-bypass maintains continuous utility output to connected equipment, even in cases where the UPS suffers internal failure and requires maintenance ● Network interfaces support simultaneous communications via built-in USB, DB9 serial and SNMPWEBCARD slot ● HID compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Included PowerAlert UPS monitoring software supports safe unattended shutdown, monitoring and control via local connected servers, plus any number of additional servers over IP ● UPS interface supports on-battery, low-battery, power-restored, AC-voltage, DC-voltage, output current monitoring, battery charge current, battery capacity, AC line frequency, timed inverter shutoff, activate self-test, load bank output power control and remote reboot, UPS nominal voltage adjustment and UPS line to battery power voltage setpoints ● Built-in Emergency Power Off (EPO) interface with cable ● NEMA 5-20P input plug /NEMA 5-15/20R & NEMA L5-20R output receptacles ● Integrated 2 bank switched PDU enables remote outlet management for load shedding or remote reboot of individual load banks (bank 1 has two outlets/bank two has four outlets) ● Front panel LEDs offer current monitoring and battery charge level information ● UPS ships fully assembled in full compliance with DOT regulations, no time consuming connection of internal batteries by user required ● Single line TEL/DSL or network ethernet line surge suppression ● $250,000 Ultimate Lifetime Insurance Specifications OVERVIEW UPC Code 037332137685 INPUT Rated input current (Maximum Load) 16A Nominal Input Voltage(s) Supported 100V AC; 110V AC; 120V AC UPS Input Connection Type 5-20P Input Circuit Breakers 30A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 20A 120V Input Cord Length (m) 3 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1600 Output Capacity (kW) 1.6 Power Factor 0.7 Crest Factor 3:1 Nominal Voltage Details 120V default Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Load Management Receptacles Two switchable three-outlet 5-15/20R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 100V; 110V; 120V Output Receptacles (6) 5-15/20R; (1) L5-20R BATTERY Runtime Full Load (min.) 6 min. (1600w) Runtime Half Load (min.) 18 min. (800w) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible); BP48V60-3UNAFTA (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 80% Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  Battery Replacement Description Hot-swappable, user replaceable batteries 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 138 Undervoltage Correction 2% output voltage regulation during undervoltages to 80 Severe Undervoltage Correction 2% output voltage regulation during undervoltages to 65 (under 70% load only) USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators 14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in rack/tower formats SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 1320 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); Wallmount ( 2POSTRMKITWM ); Tower ( 29USTAND ) Primary UPS Depth (mm) 483 Primary UPS Height (mm) 89 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 9.75 x 20.25 x 24.00 Shipping Dimensions (hwd / cm) 24.76 x 51.44 x 60.96 Shipping Weight (lbs.) 57.30 Shipping Weight (kg) 25.99 UPS Housing Material Steel 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Dimensions (hwd, cm) 8.89 x 44.45 x 48.26 UPS Power Module Dimensions (hwd, in.) 3.5 x 17.5 x 19 UPS Power Module Weight (kg) 21.50 UPS Power Module Weight (lbs.) 47.4 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 812.9 AC Economy Mode BTU / Hr. (Full Load) 347.2 Battery Mode BTU / Hr. (Full Load) 885.6 AC Mode Efficiency Rating (100% Load) 87% AC Economy Mode Efficiency Rating (100% Load) 94% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure communications PowerAlert Software Included Communications Cable DB9 cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface DB9 Serial; Contact closure; EPO (emergency power off); Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 80V (100% load), 65V (
SU2200RMNAFTA 价格&库存
很抱歉,暂时无法提供与“SU2200RMNAFTA”相匹配的价格&库存,您可以联系我们找货
