SM700NAFTA
SM700NAFTA
    TRIPPLITE
    UPS 700VA 450W 6OUT TOWER
SM700NAFTA 数据手册
Smart Pro Tower UPS System - NAFTA assembled version of SMART700 Highlights ● MODEL NUMBER: SM700NAFTA 700VA line interactive tower UPS system for 120V network applications ● Enhanced USB communications port, free software and cabling Description ● Corrects brownouts and overvoltages from 75 to 147V ● 6 outlets ● $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) Tripp Lite's SM700NAFTA intelligent, line interactive UPS system protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 20 minutes half load runtime and 6 minutes at full load during power failures. 700VA/450 watt power handling capability supports a variety of networking, telecom and various other application types, including the support of multiple network workstations. Includes a total of 6 UPS supported outlets. Supports remote monitoring of UPS and site power conditions via built-in USB monitoring port. Includes PowerAlert UPS monitoring and unattended shutdown software with complete cabling. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level. Wall mountable with UPSWM wallmount bracket. Networkgrade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. Attractive, small-footprint tower housing uses less than 53 square inches of floor or desktop space. Two year warranty with $250,000 connected equipment insur. Package Includes ● SM700NAFTA UPS System ● Monitoring cable ● PowerAlert unattended shutdown and UPS/Power monitoring software ● Instruction manual with warranty information Features ● 700VA/450 watt power handling capability supports a variety of networking, telecom and various other application types ● Built-in voltage regulation and battery support, plus complete AC line surge suppression prevents equipment damage, data loss and downtime ● Large internal batteries offer 20 minutes half load runtime and 6 minutes at full load during power failures ● Automatic Voltage Regulation (AVR) circuits with two boost and one voltage reduction level maintains usable 120V nominal output over an input voltage range of 75-147V ● Includes a total of 6 NEMA5-15R outlets ● Includes USB communications port for remote monitoring of UPS status and site power conditions ● Communications port enables safe unattended shutdown without data loss during extended power failures ● Communications port supports messaging of UPS and line power status, including on-battery, lowbattery, power-restored, AC line voltage, DC battery voltage and battery capacity ● Communications ports support timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment ● PowerAlert UPS monitoring and unattended shutdown software with complete cabling included ● Battery replacement door ● Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically restarting them and rebooting completely locked computers by automatically switching UPS power off and back on again ● Notification of system status via 5 LEDs and multi-function audible alarms ● Wall mountable with UPSWM wallmount bracket ● Attractive small footprint black tower housing uses less than 53 square inches ● Hot-swappable batteries allow on-site battery replacement ● Cold start capability enables UPS turn-on in battery mode during blackout conditions ● UL (USA), cUL (Canada), NOM (Mexico), Class A (Emissions) Listed ● $250,000 Ultimate Lifetime Insuran. ● 2 year manufacturers product warranty Specifications 1/4 OVERVIEW UPC Code 037332137562 INPUT UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V Maximum Input Amps 4.4 Input Connection Type NEMA 5-15P Voltage Compatibility (VAC) 120 OUTPUT Frequency Compatibility 60 Hz Output (VA) 700 Output (Watts) 450 Output Nominal Voltage 120V AC Output Voltage Regulation LINE MODE: Sine wave line voltage 120V (-18% / +8%) Output Frequency Regulation LINE MODE: Passes line frequency of 60Hz +/-10% BATTERY Full Load Runtime (min.) 6 minutes (700VA) Half Load Runtime (min.) 20 minutes (350VA) DC System Voltage (VDC) 12 Battery Access Battery access door allows user replacement of UPS batteries Replacement Battery Cartridge  RBC52  (quantity 2) Typical Battery Lifespan 3-6 years, depending on usage Battery Charge 2-4 hours to 90% VOLTAGE REGULATION Voltage Regulation Description Automatic Voltage Regulation (AVR) circuits maintain clean, regulated computer-grade 120V nominal output, without using battery power, during brownouts to 75V and overvoltages to 147V Overvoltage Correction Input voltages between 128 and 147V AC are reduced by 12% Brownout Correction Input voltages between 93 and 107V AC are boosted by 14% Severe Brownout Correction Input voltages between 75 and 92V AC are boosted by 30% USER INTERFACE, ALERTS & CONTROLS 2/4 Front Panel LEDs Includes 5 front panel LEDs to indicate BATTERY CHARGE LEVEL, AC LINE POWER STATUS, VOLTAGE REGULATION STATUS, UPS LOAD LEVEL and BATTERY LOW / REPLACE information Switches Includes 2 front panel switchesone main on/off power switch and one dual function "alarm cancel" / "self test" button Audible Alarm Audible alarm with 15 second delay sounds to indicate loss of utility power. Alarm can be silenced by pressing front panel alarm cancel button. Once silenced, alarm will re-sound when approximately 2 minutes runtime remain. SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous PHYSICAL Material of Construction PVC Cooling Method Convection Form Factors Supported Tower Shipping Dimensions (hwd / cm) 39.37 x 27.94 x 28.58 Shipping Dimensions (hwd / in.) 15.50 x 11.00 x 11.25 Shipping Weight (kg) 11.61 Shipping Weight (lbs.) 25.60 Unit Dimensions (hwd / in.) 11.75 x 7.25 x 7.5 Unit Dimensions (hwd / cm) 29.8 x 18.4 x 19.1 Unit Weight (lbs.) 22 Unit Weight (kg) 9.98 ENVIRONMENTAL Relative Humidity 0 to 95%, non-condensing COMMUNICATIONS WatchDog Compatibility Yes, compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application / OS or hard power off/on reboot of connected equipment - ideal for unattended kiosk applications Network Monitoring Port Built-in USB port supports on battery, low battery, power restored, AC line voltage, DC battery voltage, load percentage, battery charge current, battery capacity, internal UPS temperature and line frequency status messaging. Interface supports timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment. Supports reboot of all connected devices at once via software interface. Compatible with Tripp Lite's PowerAlert software. LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) 2-4 milliseconds Low Voltage Transfer to Battery Power Switches to battery power as line voltage decreases to 75 volts or less. Resets back to line power mode as line voltage increases to 79V or higher. 3/4 High Voltage Transfer to Battery Power Switches to battery power as line voltage increases to 147 volts or higher. Resets to line power mode as line voltage decreases to 143V or less. FEATURES & SPECIFICATIONS Cold Start Yes, inverter can be "cold started" to enable temporary AC output during a power failure WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty Optional Coverage 3-5 year warranties, plus next day and on-site warranty coverage available for select opportunities. Contact Tripp Lite for additional information. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
SM700NAFTA
物料型号:SM700NAFTA 器件简介: - Tripp Lite的SM700NAFTA智能在线互动式UPS系统,保护服务器、网络配件和电信设备免受停电、电压波动和瞬态浪涌的影响。
- 700VA/450瓦功率处理能力,支持多种网络、电信和其他应用类型,包括支持多个网络工作站。
- 内置USB监控端口,支持远程监控UPS和现场电源状况。
- 提供PowerAlert UPS监控和无人值守关机软件及完整布线。
- 具有内置的听觉报警和5个前面板LED指示灯,显示线路电源、电池电源、电池低/更换、电压调节和负载水平的状态。
- 壁挂式设计,使用UPSWM壁挂支架,占地面积小于53平方英寸。
- 提供两年保修和价值25万美元的连接设备保险。
引脚分配: - 提供总计6个NEMA5-15R插座。
参数特性: - 20分钟半载运行时间和6分钟全载运行时间。
- 自动电压调节(AVR)电路,通过两个增压和一个电压降低级别,保持在输入电压范围75-147V内的可用120V标称输出。
- 支持远程监控UPS状态和现场电源状况的USB通信端口。
- 支持UPS和线路电源状态的消息,包括电池状态、低电池、电源恢复、交流线路电压、直流电池电压和电池容量。
- 支持在无人值守关机后定时逆变器关闭、激活自检和连接设备的10秒重启。
功能详解: - 提供Tripp Lite的WatchDog软件应用,通过自动重启不响应的程序和通过自动切换UPS电源来完全重新启动锁定的计算机,以恢复系统状态。
- 通过5个LED和多功能听觉报警通知系统状态。
- 支持热插拔电池,允许现场电池更换。
- 冷启动功能允许在停电条件下以电池模式打开UPS。
- UL(美国)、cUL(加拿大)、NOM(墨西哥)、Class A(发射)认证。
- 25万美元终极终身保险。
- 2年制造商产品保修。
封装信息: - 产品保修期限:2年有限保修。
- 可选覆盖范围:3-5年保修,以及选择机会的次日和现场保修覆盖。
联系Tripp Lite以获取更多信息。
- 连接设备保险(美国、加拿大和波多黎各):25万美元终极终身保险。
以上信息是针对Tripp Lite的SM700NAFTA智能在线互动式UPS系统的详细分析。
SM700NAFTA 价格&库存
很抱歉,暂时无法提供与“SM700NAFTA”相匹配的价格&库存,您可以联系我们找货
