SU1500RMNAFTA
SU1500RMNAFTA
    TRIPPLITE
    UPS TRUEONLINE 1.5KVA 1200W 6OUT
SU1500RMNAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline Expandable 2U Rack/Tower UPS System - NAFTA assembled version of SU1500RTXL2Ua Highlights ● 1500VA/1.5kVA online, doubleconversion, extended-run 2U rack/tower UPS ● Maintains sine-wave 100/110 or 120V +/-2% output during overvoltages to 138V and brownouts as low as 65V (50/60Hz auto-sensing) ● Simultaneous communications via HID-compliant USB port, serial port, SNMP/Web card slot and EPO interface ● Fault tolerant auto-bypass mode, current monitoring and switched PDU control via 2 switchable output load banks ● Input: NEMA 5-15P (120V). Output: 6 NEMA 5-15R (120V). ● 2-year product warranty; $250,000 Ultimate Lifetime Insurance (USA & Canada only) MODEL NUMBER: SU1500RMNAFTA Description 1500VA online, double-conversion UPS system for critical server, network and telecommunications equipment. 2U rackmount form factor with an installed depth of only 19 in. Expandable battery runtime with optional BP48V60-3UNAFTA external battery packs. Full-time sine wave 100, 110 or 120V +/-2% output. Uninterruptible Power Supply (UPS) actively converts raw incoming AC power to DC, then reconverts output back to completely regulated, filtered AC output. Operates continuously without using battery power during brownouts to 65V and overvoltages to 138V. NEMA 5-15P input plug and NEMA 515R output receptacles. Network-grade AC surge and noise suppression. Zero transfer time between AC and battery operation. Network management interfaces support simultaneous communications via USB port, DB9 serial port and SNMPWEBCARD slot. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports simultaneous detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces simultaneously. Includes PowerAlert monitoring software and complete cabling. Package Includes ● SU1500RMNAFTA Online Double-Conversion UPS System ● PowerAlert Software and cabling ● Mounting hardware for 4 post rack enclosures ● Instruction manual with warranty information Emergency Power Off (EPO) interface. Integrated two-bank PDU switching supports load shedding and remote reboot of connected equipment. Three-stage metered current monitoring and battery charge status LEDs. LED display panel easily rotates for better viewing in rackmount or tower configurations.Dataline surge suppression for dialup, DSL or network ethernet connection. Utility power and voltage regulation LEDs. Audible alarm. Self-test. Fault-tolerant auto-bypass mode. 4-post rackmount accessories included; 2-9USTAND tower kit and 2POSTRMKITWM 2-post rack & wallmount accessories available. Field replaceable, hot-swappable internal batteries and external battery packs. Attractive all-black color scheme. Two-year warranty and $250,000 Ultimate Lifetime Insurance; extended warranty and service contracts available. Features ● SmartOnline high-performance UPS system is ideal for critical voice, data, medical and industrial network applications ● True on-line, double-conversion UPS provides perfectly regulated sine wave output within 2% of 100/110/120V (user selectable) under all usage conditions ● Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer time ● Removes harmonic distortion, fast electrical impulses, frequency variations and other hard to solve power problems not addressed by other UPS types ● Corrects line voltage conditions as low as 65V and as high as 138V back to selectable 100/110/120V (+/-2%) values ● Standard internal battery set offers 17 min. runtime at half load (600W) and 5 min. at full load (1200W) ● Optional BP48V60-3UNAFTA external battery pack increases runtime to 168 min. at half load (600W) and 82 min. at full load (1200W/multi-pack compatible) ● Compact rackmount form factor installs using only 2 rack spaces (2U) with a maximum installed depth of only 19 in. ● Ships with all mounting accessories for 4-post rackmount installation ● Optional 2POSTRMKITWM enables 2-post rackmount or wallmount installation 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Optional 2-9USTAND accessory enables small-footprint upright tower placement ● Fault tolerant auto-bypass maintains continuous utility output to connected equipment, even in cases where the UPS suffers internal failure and requires maintenance ● Network interfaces support simultaneous communications via built-in USB, DB9 serial and SNMPWEBCARD slot ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. ● Included PowerAlert UPS monitoring software supports safe unattended shutdown, monitoring and control via local connected servers, plus any number of additional servers over IP ● UPS interface supports on-battery, low-battery, power-restored, AC-voltage, DC-voltage, output current monitoring, battery charge current, battery capacity, AC line frequency, timed inverter shutoff, activate self-test, load bank output power control and remote reboot, UPS nominal voltage adjustment and UPS line to battery power voltage setpoints ● Built-in Emergency Power Off (EPO) interface with cable ● NEMA 5-15P input plug; NEMA 5-15R output receptacles ● Integrated 2-bank switched PDU enables remote outlet management for load shedding or remote reboot of individual load banks (bank one has 2 outlets, bank two has 4 outlets) ● Front panel LEDs offer current monitoring and battery charge level information ● UPS ships fully assembled in full compliance with DOT regulations; no time-consuming connection of internal batteries by user required ● Supports 2-post rackmount installation with optional 2POSTRMKITWM accessory ● Single-line tel/DSL or network Ethernet surge suppression ● 2-year manufacturer's product warranty; $250,000 Ultimate Lifetime Insurance Specifications OVERVIEW UPC Code 037332137722 INPUT UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 120V 15A Maximum Input Amps 12 Input Connection Type NEMA 5-15P Voltage Compatibility (VAC) 120 OUTPUT Frequency Compatibility 50 / 60 Hz Output Nominal Voltage 120V AC (100/110/120V) Output Voltage Regulation Maintains full-time sine wave output within 2% of selected nominal, less than 3% total harmonic distortion (linear load) / 5% total harmonic distortion (computer load) (Less than 5% THD on-line and on-battery) Output Frequency Regulation Regulates line frequency to 50/60Hz +/- 0.05Hz 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Overload Protection 20A input breaker Customized Load Management Receptacles 2 controllable load banks support load shedding and remote reboot on demand of locked network devices (bankone has 2 outlets, bank two has 4 outlets) BATTERY Runtime Full Load (min.) 5 min. with internal batteries (1200W) Runtime Half Load (min.) 17 min. with internal batteries (600W) Expandable Runtime Yes Expandable Runtime Description Supports extended runtime with optional external battery pack BP48V60-3UNAFTA (multi-pack compatible) DC System Voltage (VDC) 48 Battery Access User replaceable, hot swap battery replacement supported via front access panel Replacement Battery Cartridge  RBC94-2U  Battery Pack Accessory (Optional) BP48V60-3UNAFTA (optional) Typical Battery Lifespan 3-6 years, depending on usage Battery Charge Less than 5 hours to 90% VOLTAGE REGULATION Voltage Regulation Description On-line, double-conversion power conditioning maintains output within 2% of 100/110/120 volts at all times Overvoltage Correction Maintains output of selected nominal +/-2% during overvoltages to 138V AC Brownout Correction Maintains output of selected nominal +/-2% during undervoltages to 65V AC (at loads greater than 70% undervoltage correction extends to 80V) USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs LED STATUS DISPLAY: line power (green), on-line (green), bypass (yellow), on battery (green), overload (red), battery low (yellow) - 4 LED LOAD / BATTERY LEVEL DISPLAY (100%, 75%, 50%, 25%). LED display panel easily rotates for better viewing in rackmount or tower configurations. Switches Includes power off/on switch to enable system turn on (press ON switch), UPS battery test (press ON switch during normal AC operation), buzzer silence (press ON switch during battery operation) and OFF (press OFF switch) - all switch functions require that the switch be pressed and held for longer than 2 seconds, but less than 4 seconds Audible Alarm Multi-function audible alarm with distinctive ring patterns offer notification of backup operation (2 seconds on/0.5 seconds off), low battery warning (1.25 seconds on/0.5 seconds off), overload (sounds continuously), UPS fault (4.2 seconds on / 1 second off), input voltage out of frequency (2.1 seconds on/0.14 seconds off) and high input voltage (2.1 seconds on/0.07 seconds off) SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous Dataline Suppression Set of 8-wire RJ style interface jacks offer surge suppression for network ethernet or TEL/DSL connection. Pins 1,2,3 and 6 offer ethernet protection starting at 7.5V and the center two wires, pins 4 & 5, offer TEL/DSL line suppression starting at 260V PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Material of Construction Steel Cooling Method Built-in cooling fan Form Factors Supported Rack/Tower (2U) Shipping Dimensions (hwd / in.) 9.75 x 20.25 x 24.00 Shipping Dimensions (hwd / cm) 24.76 x 51.44 x 60.96 Shipping Weight (lbs.) 54.00 Shipping Weight (kg) 24.49 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 19.000 Unit Dimensions (hwd / cm) 8.9 x 44.4 x 48.3 Unit Weight (lbs.) 44.1 Unit Weight (kg) 20.00 ENVIRONMENTAL Relative Humidity 0 to 95%, non-condensing Line Mode BTU / Hr. (max.) 612 btu/hr. (87% efficiency line mode) Battery Mode BTU / Hr. (max.) 667 btu/hr. (86% efficiency battery mode) COMMUNICATIONS WatchDog Compatibility Yes, compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application / OS or hard power off/on reboot of connected equipmentideal for unattended kiosk applications Network Monitoring Port Includes USB and DB9 serial ports. Built-in DB9 port offers both enhanced RS-232 enabled monitoring data, plus contact closure monitoring ability. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. EPO Port Supports "Emergency Power Off" via set of dedicated built-in EPO jacks SNMP Compatibility Yes, includes slot for optional SNMPWEBCARD accessory (#SNMPWEBCARD) LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) Zero, online UPS continuously converts incoming AC to DC, then back to AC. When commercial power is interrupted, UPS maintains continuous output from battery reserves with absolutely no disruption in output AC power Low Voltage Transfer to Battery Power Maintains continuous operation during undervoltages as low as 65V (80V at load levels over 70%). Below this switchover point, output is supported from battery-derived AC power High Voltage Transfer to Battery Power Maintains continuous operation without using battery power during overvoltages to 138V. Above this point, output is supported from battery derived AC power FEATURES & SPECIFICATIONS Cold Start Inverter can be cold started to enable temporary AC output during a power failure WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Optional Coverage 3-5 year warranties, plus next-day and on-site warranty coverage available for select opportunities. Contact Tripp Lite for additional information. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SU1500RMNAFTA
物料型号: - 型号编号:SU1500RMNAFTA
器件简介: - 这是一个1500VA在线式双变换UPS系统,用于关键的服务器、网络和电信设备。2U机架式安装,安装深度仅为19英寸。通过可选的BP48V60-3UNAFTA外接电池包扩展电池运行时间。提供全时正弦波100V、110V或120V±2%输出。
引脚分配: - 输入:NEMA 5-15P(120V) - 输出:6个NEMA 5-15R(120V)
参数特性: - 标准内部电池组提供半载(600W)时17分钟的运行时间,全载(1200W)时5分钟。 - 可选的BP48V60-3UNAFTA外接电池包将半载(600W)时的运行时间延长至168分钟,全载(1200W/多包兼容)时延长至82分钟。 - 2U机架式安装,仅占用2个机架空间,最大安装深度仅为19英寸。
功能详解: - SmartOnline高性能UPS系统适用于关键语音、数据、医疗和工业网络应用。 - 真正的在线式、双变换UPS在所有使用条件下提供完美调节的正弦波输出,保持在100/110/120V(用户可选)的2%以内。 - 通过零转换时间维持连续运行,即使在停电、电压波动和浪涌情况下。 - 消除谐波失真、快速电脉冲、频率变化等其他UPS类型未能解决的电力问题。 - 将线路电压条件校正为低至65V和高达138V,恢复到可选的100/110/120V(±2%)值。
应用信息: - 适用于关键语音、数据、医疗和工业网络应用。
封装信息: - 2U机架式安装,仅占用2个机架空间,最大安装深度仅为19英寸。 - 随附所有4柱机架安装的安装配件。 - 可选的2POSTRMKITWM配件支持2柱机架安装或壁挂安装。 - 可选的2-9USTAND配件支持小型占地面积的直立塔式放置。
SU1500RMNAFTA 价格&库存
很抱歉,暂时无法提供与“SU1500RMNAFTA”相匹配的价格&库存,您可以联系我们找货
