SU3000XLNAFTA
SU3000XLNAFTA
    TRIPPLITE
    UPS TRUEONLINE 3.0KVA 2400W 9OUT
SU3000XLNAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline Expandable Tower UPS System NAFTA assembled version of SU3000XL MODEL NUMBER: SU3000XLNAFTA Highlights ● 3000VA / 3KVA on-line, doubleconversion, extended-run tower UPS ● Maintains sine-wave 110/120V +/-2% output during overvoltages to 138 and brownouts as low as 65V (50/60Hz auto-sensing) ● Simultaneous use communications via HID compliant USB port, serial port, SNMP/Web card slot and EPO interface ● Fault tolerant auto-bypass mode, current monitoring and switched PDU control via 2 switchable output load banks ● Input: NEMA L5-30P (120V) / Output: 4 NEMA5-15R, 4 NEMA5-15/20R & 1 NEMA L530R ● $250,000 Ultimate Lifetime Insurance (USA and Canada Only) Description 3000VA on-line, double-conversion UPS system for critical server, network and telecommunications equipment. Upright tower form factor. Expandable battery runtime with optional BP72V28-3UNAFTA external battery packs. Full-time sine wave 110 or 120V +/-2% output. Online, double-conversion Uninterruptible Power Supply (UPS) actively converts raw incoming AC power to DC, then re-converts output back to completely regulated, filtered AC output. Operates continuously without using battery power during brownouts to 65V and overvoltages to 138V. NEMA L5-30P input plug; NEMA 5-15R, NEMA 5-15/20R and NEMA L5-30R output receptacles. Network-grade AC surge and noise suppression. Zero transfer time between AC and battery operation. Network management interfaces support simultaneous communications via USB port, DB9 serial port and SNMPWEBCARD slot. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports simultaneous detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces. Includes PowerAlert monitoring software and complete cabling. Emergency Power Off (EPO) interface. Integrated 2-bank PDU switching supports load shedding and remote-reboot of connected equipment. 3-stage metered current monitoring and battery charge status LEDs. Dataline surge suppression for dialup, DSL or network Ethernet connection. Utility power and voltage regulation LEDs. Audible alarm. Self-test. Fault-tolerant auto-bypass mode. Field-replaceable, hotswappable internal batteries and external battery packs. Attractive all-black color scheme. $250,000 connected equipment insur; Features ● SmartOnline high performance UPS system is ideal for critical voice, data, medical and industrial network applications ● True on-line, double-conversion UPS provides perfectly regulated sine wave output within 2% of 110/120V (user selectable) under all usage conditions ● Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer time ● Removes harmonic distortion, fast electrical impulses, frequency variations and other hard to solve power problems not addressed by other UPS types ● Corrects line voltage conditions as low as 65V and as high as 138V back to selectable 110/120V (+/2%) values ● Standard internal battery set offers 14 minutes runtime at half load (1200W) and 5 minutes at full load (2400W) ● Optional BP72V28-3UNAFTA external battery packs offer expandable battery runtime 1/5 Package Includes ● SU3000XLNAFTA UPS System ● PowerAlert Software and Cabling ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Space saving upright tower format ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Network interfaces support simultaneous communications via built-in USB, DB9 serial/contact-closure and SNMPWEBCARD slot ● HID compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. ● Included PowerAlert UPS monitoring software supports safe unattended shutdown, monitoring and control via local connected servers, plus any number of additional servers over IP ● UPS interface supports on-battery, low-battery, power-restored, AC-voltage, DC-voltage, output current monitoring, battery charge current, battery capacity, AC line frequency, timed inverter shutoff, activate self-test, load bank output power control and remote reboot, UPS nominal voltage adjustment and UPS line to battery power voltage setpoints ● Built-in Emergency Power Off (EPO) interface with cable ● NEMA L5-30P input plug/NEMA 5-15/20R, L5-20R & L5-30R output receptacles ● Integrated 2 bank switched PDU enables remote outlet management for load shedding or remote reboot of individual load banks (each bank has four outlets) ● Front panel LEDs offer current monitoring and battery charge level information ● UPS ships fully assembled in full compliance with DOT regulations; no time consuming connection of internal batteries by user required ● Single line TEL/DSL or network ethernet line surge suppression ● $250,000 Ultimate Lifetime Insuran Specifications OVERVIEW UPC Code 037332137715 INPUT Rated input current (Maximum Load) 24A (120V), 26.2A (110V) Nominal Input Voltage(s) Supported 110V AC; 120V AC UPS Input Connection Type L5-30P Input Circuit Breakers 40A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 30A 120V OUTPUT Output Capacity (VA) 3000 Output Capacity (kVA) 3 Output Capacity (Watts) 2400 Output Capacity (kW) 2.4 Power Factor 0.8 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Crest Factor 3:1 Nominal Voltage Details 120V default Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Load Management Receptacles Two switchable four-outlet load banks, (bank 1 - four 5-15/20R, bank 2 - four 5-15R outlets) Output Circuit Breakers 15A branch rated (x2) - each breaker protects 4 outlets, L5-30R is unbreakered Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 120V Output Receptacles (4) 5-15R; (4) 5-15/20R; (1) L5-30R BATTERY Runtime Full Load (min.) 6 min. (2400w) Runtime Half Load (min.) 17 min. (1200w) Expandable Runtime Yes External Battery Pack Compatibility  BP72V15-2U  (limit 1);  BP72V28RT-3U  (multi-pack compatible); BP72V28-3UNAFTA (multi-pack compatible) DC System Voltage (VDC) 72 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 80% Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC96-3U  (quantity 1) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 138 Undervoltage Correction 2% output voltage regulation during undervoltages to 80 Severe Undervoltage Correction 2% output voltage regulation during undervoltages to 65 (under 70% load only) USER INTERFACE, ALERTS & CONTROLS 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators 14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery and fault status information; 4-LED meter displays load and battery charge levels SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 521 Primary UPS Height (mm) 259 Primary UPS Width (mm) 229 Shipping Dimensions (hwd / in.) 15.25 x 13.00 x 24.00 Shipping Dimensions (hwd / cm) 38.74 x 33.02 x 60.96 Shipping Weight (lbs.) 75.20 Shipping Weight (kg) 34.11 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.91 x 22.86 x 52.07 UPS Power Module Dimensions (hwd, in.) 10.2 x 9 x 20.5 UPS Power Module Weight (kg) 31.43 UPS Power Module Weight (lbs.) 69.3 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 1112.7 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Economy Mode BTU / Hr. (Full Load) 520.9 Battery Mode BTU / Hr. (Full Load) 1219.3 AC Mode Efficiency Rating (100% Load) 88% AC Economy Mode Efficiency Rating (100% Load) 94% Audible Noise
SU3000XLNAFTA 价格&库存
很抱歉,暂时无法提供与“SU3000XLNAFTA”相匹配的价格&库存,您可以联系我们找货
