SM1050NAFTA
SM1050NAFTA
    TRIPPLITE
    UPS 1050VA 705W 6OUT TOWER
SM1050NAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Smart Pro Tower UPS System - NAFTA assembled version of SMART1050 MODEL NUMBER: SM1050NAFTA Highlights ● 1050VA line interactive tower UPS system ● Enhanced USB communications port ● Corrects brownouts and overvoltages from 75 to 147V ● 6 outlets ● $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) Package Includes Description Tripp Lite's SM1050NAFTA intelligent, line interactive UPS system protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 23 minutes half load runtime and 8 minutes at full load during power failures. 1050VA/705 watt power handling capability supports a variety of networking, telecom and various other application types, including the support of multiple network workstations. Includes a total of 6 UPS supported outlets. Supports remote monitoring of UPS and site power conditions via built-in USB monitoring port. Includes PowerAlert UPS monitoring and unattended shutdown software with complete cabling. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level. Wall mountable with UPSWM wallmount bracket. Networkgrade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. Attractive, small-footprint tower housing uses less than 53 square inches of floor or desktop space. $250,000 connected equipment insur. Features ● 1050VA/705 watt power handling capability supports a variety of networking, telecom and various other application types ● Built-in voltage regulation and battery support prevents equipment damage, data loss and downtime ● Large internal batteries offer 23 minutes half load runtime and 8 minutes at full load during power failures ● Automatic Voltage Regulation (AVR) circuits with two boost and one voltage reduction level maintains usable 120V nominal output over an input voltage range of 75-147V ● Includes a total of 6 NEMA5-15R outlets ● Includes 1 USB communications port for remote monitoring of UPS status and site power conditions ● Communications port enables safe unattended shutdown without data loss during extended power failures ● Communications port supports messaging of UPS and line power status, including on-battery, lowbattery, power-restored, AC line voltage, DC battery voltage and battery capacity ● Communications port supports timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment ● PowerAlert UPS monitoring and unattended shutdown software with complete cabling included ● Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically 1/5 ● SMART 1050 UPS System ● USB monitoring cable ● PowerAlert unattended shutdown and UPS/Power monitoring software ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States restarting them and rebooting completely locked computers by automatically switching UPS power off and back on again ● Notification of system status via 5 LEDs and multi-function audible alarms ● Wall mountable with UPSWM wallmount bracket ● Attractive small footprint beige tower housing uses less than 53 square inches ● Hot-swappable/user replaceable batteries allow on-site battery replacement ● Cold start capability enables UPS turn-on in battery mode during blackout conditions ● UL (USA), cUL (Canada), NOM (Mexico), Class B (Emmisions) ● $250,000 Ultimate Lifetime Insuran Specifications OVERVIEW UPC Code 037332137500 INPUT Rated input current (Maximum Load) 6.7A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 12A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1050 Output Capacity (kVA) 1 Output Capacity (Watts) 705 Power Factor 0.7 Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15R 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States BATTERY Runtime Full Load (min.) 8 min. (705w) Runtime Half Load (min.) 23 min. (355w) DC System Voltage (VDC) 18 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC52  (quantity 3) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 183 Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 15.50 x 11.00 x 11.25 Shipping Dimensions (hwd / cm) 39.37 x 27.94 x 28.58 Shipping Weight (lbs.) 32.00 Shipping Weight (kg) 14.51 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 18.29 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.2 UPS Power Module Weight (kg) 13.15 UPS Power Module Weight (lbs.) 29 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 99.9 Battery Mode BTU / Hr. (Full Load) 326.9 AC Mode Efficiency Rating (100% Load) 96% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software Included Communications Cable USB cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SM1050NAFTA 价格&库存
很抱歉,暂时无法提供与“SM1050NAFTA”相匹配的价格&库存,您可以联系我们找货
