SM1500RMNAFTA
SM1500RMNAFTA
    TRIPPLITE
    UPS 1500VA 1000W 8OUT RACK/TOWER
SM1500RMNAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Smart Pro Line Interactive Rack/Tower UPS System - NAFTA assembled version of SMART1500RMXL2Ua Highlights ● 1500VA / 1.5kVA line interactive, extended-run 2U rack / tower UPS ● Maintains sine-wave 120V nominal output over an input range of 79 to 147V ● Network communications supported via USB port, serial port, SNMP/Web card slot and EPO interface ● Current monitoring and switched PDU control via 3 two-outlet load banks ● Input: NEMA 5-15P (120V 15A) / Output: 8 NEMA 5-15R (120V) ● $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico and Canada only) MODEL NUMBER: SM1500RMNAFTA Package Includes Description Tripp Lite's SM1500RMNAFTA intelligent, line interactive rack/tower uninterruptible power supply prevents data loss, downtime and equipment damage due to power outages, voltage fluctuations and transient surges. Requires only two rack spaces (2U) in a standard rack enclosure. Large internal batteries offer 21 minutes half load runtime and 7.5 minutes at full load. Runtime is expandable with optional BP36V15-2U external battery pack (limit 1) or BP36V42-3U (multi-pack compatible). Maintains regulated 120V nominal output without using battery power during brownouts and overvoltages from 75 to 147V. 1500VA / 1000 watt power handling capability supports a variety of networking, telecom and other sensitive electronic applications. Includes a total of 8 outlets with 3 load banks that are individually controllable via software interface to reboot select equipment on demand or shed less significant loads to extend battery runtime for more critical equipment. Supports remote monitoring of UPS and site power conditions via built-in USB and DB9 monitoring ports. Includes PowerAlert UPS monitoring and unattended shutdown software with complete cabling. Built-in accessory slot supports SNMP with optional SNMPWEBCARD adapter. Emergency Power Off (EPO) interface offers option for instantaneous power-off of UPS and connected equipment in the case of fire or emergency. Multi-function audible alarms and set of 5 front panel LEDs offer at-a-glance notification of UPS and line power status. Network-grade AC surge suppression protects equipment from damage and performance problems resulting from transient surges and line noise. Attractive all-black color scheme. $250,000 connected equipment insurance (USA and Canada Only). Features ● SM1500RMNAFTA line interactive UPS offers voltage regulation and battery support, plus complete AC surge suppression ● Supports 2U rackmount and upright tower applications ● Full time sine wave output offer guaranteed compatibility with all equipment types ● Supports a max load of 1500VA for 7.5 minutes and a half load of 750VA for 21 minutes ● Expandable runtime with BP36V15-2U (limit 1) or with multiple BP36V42-3U rack/tower external battery packs ● Maintains regulated 120V nominal output during brownouts and overvoltages from 75 to 147V ● 1500VA / 1000 watt power handling capability supports a variety of sensitive electronic loads ● Includes 8 UPS supported outlets arranged in 3 individually controllable load banks ● Built in USB and DB9 serial ports support remote monitoring of UPS and site power conditions 1/5 SM1500RMNAFTA UPS System PowerAlert software with USB and DB9 cables Mounting hardware for 4 post rackmount installation Cable for Emergency Power Off interface Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Built in accessory slot supports SNMP with optional SNMPWEBCARD adapter ● Emergency Power Off (EPO) interface with cable ● Multi-function audible alarms and set of 5 front panel LEDs ● Network-grade AC surge suppression ● Attractive all-black color scheme ● UPS battery set ships fully assembled and ready for installation, no time consuming connection of internal batteries by user is necessary ● $250,000 connected equipment insurance (USA and Canada Only) ● Mounting hardware included for 4 post rackmount enclosures, 2 post telecom rack compatible with separate purchase 2POSTRMKITWM, compatible with upright tower installation with included hardware Specifications OVERVIEW UPC Code 037332137739 INPUT Rated input current (Maximum Load) 10.1A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1000 Output Capacity (kW) 1 Power Factor 0.7 Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Three switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Output Voltage(s) Supported 120V Output Receptacles (8) 5-15R BATTERY Runtime Full Load (min.) 7.5 min. (1000w) Runtime Half Load (min.) 21 min. (500w) Expandable Runtime Yes External Battery Pack Compatibility  BP36V15-2U  (limit 1);  BP36V42-3U  (multi-pack compatible) DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC93-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 95 and 104 are boosted by 12% Severe Undervoltage Correction Input voltages between 75 and 94 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Adjustable mounting rail kit included Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); Wallmount ( 2POSTRMKITWM ); Tower ( 29USTAND ) Primary UPS Depth (mm) 343 Primary UPS Height (mm) 89 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 9.00 x 24.00 x 20.25 Shipping Dimensions (hwd / cm) 22.86 x 60.96 x 51.44 Shipping Weight (lbs.) 50.00 Shipping Weight (kg) 22.68 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.89 x 44.45 x 34.29 UPS Power Module Dimensions (hwd, in.) 3.5 x 17.5 x 13.5 UPS Power Module Weight (kg) 19.73 UPS Power Module Weight (lbs.) 43.5 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 34.3 Battery Mode BTU / Hr. (Full Load) 463.6 AC Mode Efficiency Rating (100% Load) 99% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software Included Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Communications Interface USB; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SM1500RMNAFTA
物料型号:SM1500RMNAFTA
器件简介: - 这是一款1500VA/1.5kVA的在线互动式机架/塔式UPS,能够在电源中断、电压波动和瞬时浪涌时保护数据和设备。 - 设备需要在标准机架中占用两个机架空间(2U)。 - 内部电池在半载情况下可提供21分钟的运行时间,在满载情况下可提供7.5分钟的运行时间。 - 运行时间可以通过可选的外部电池包扩展。
引脚分配: - 输入:NEMA 5-15P(120V 15A) - 输出:8个NEMA 5-15R(120V)
参数特性: - 输出容量:1500VA / 1.5kVA / 1000W - 功率因数:0.7 - 频率兼容性:60Hz - 输出电压调节(在线模式):-18%,+8% - 输出电压调节(电池模式):±5% - 电池运行时间:满载7.5分钟,半载21分钟 - 电池充电率:从10%到90%少于4.5小时
功能详解: - 提供电压调节和电池支持,以及完整的AC浪涌抑制。 - 支持2U机架安装和直立塔式应用。 - 全时正弦波输出,保证与所有设备类型的兼容性。 - 内置USB和DB9串行端口,支持远程监控UPS和现场电源条件。 - 内置附件插槽支持SNMP,可选SNMPWEBCARD适配器。
应用信息: - 适用于网络、电信和其他敏感电子应用。 - 提供8个UPS支持的输出插座,分布在3个可单独控制的负载组中。
封装信息: - 主要外形因素:机架安装 - 机架高度:2U - 冷却方法:风扇 - UPS外壳材料:钢
其他信息: - 包括紧急断电(EPO)接口和电缆。 - 多功能可听报警和5个前面板LED指示器。 - 网络级AC浪涌抑制,保护设备免受瞬时浪涌和线路噪声的损害。 - 提供$250,000的连接设备保险(仅限美国和加拿大)。
SM1500RMNAFTA 价格&库存
很抱歉,暂时无法提供与“SM1500RMNAFTA”相匹配的价格&库存,您可以联系我们找货
