SM1500NAFTA
SM1500NAFTA
    TRIPPLITE
    UPS 1500VA 980W 6OUT TOWER
SM1500NAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Smart Pro Line Interactive Tower UPS System NAFTA assembled version of the SMART1500 MODEL NUMBER: SM1500NAFTA Highlights ● 1500VA / 1.5kVA line interactive tower UPS ● Maintains 120V nominal output over an input range of 75 to 147V ● Network communications supported via USB port, serial port ● Input: NEMA 5-15P (120V 15A) / Output: 6 NEMA 5-15R (120V) ● $250,000 Ultimate Lifetime Insurance (USA, Puerto Rico and Canada only) Package Includes Description Tripp Lite's SM1500NAFTA intelligent, line interactive UPS system protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 20 minutes half load runtime and 7 minutes at full load during power failures. 1500VA/980 watt power handling capability supports a variety of networking, telecom and various other application types, including the support of multiple network workstations. Includes a total of 6 outlets, 1 of which can be individually powered on and off via software interface to selectively reboot remote equipment or to automatically shed less significant loads to extend battery runtime for more critical equipment. Supports remote monitoring of UPS and site power conditions via built-in USB and DB9 monitoring ports. Includes PowerAlert UPS monitoring and unattended shutdown software with complete cabling. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level. Wall mountable with optional UPSWM wallmount bracket. Network-grade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. Attractive, small-footprint tower housing uses less than 66 square inches of floor or desktop space. $250,000 connected equipment insurance (USA and Canada Only). Features ● 1500VA/980 watt power handling capability supports a variety of networking, telecom and various other application types ● Built-in voltage regulation and battery support, plus complete AC suppression prevents equipment damage, data loss and downtime ● Large internal batteries offer 20 minutes half load runtime and 7 minutes at full load during power failures ● Automatic Voltage Regulation (AVR) circuits with two boost and one voltage reduction level maintains usable 120V nominal output over an input voltage range of 75-147V ● Includes a total of 6 NEMA5-15R outlets, 1 of which can be individually powered on and off via software interface to selectively reboot remote equipment or shed less significant loads to extend battery runtime for more critical equipment 1/5 ● SM1500NAFTA UPS System ● USB and DB9 monitoring cables ● PowerAlert unattended shutdown and UPS/Power monitoring software ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Includes 1 USB and 1 DB9 monitoring port for remote monitoring of UPS status and site power conditions ● Communications ports enable safe unattended shutdown without data loss during extended power failures ● Communications ports support messaging of UPS and line power status, including on-battery, lowbattery, power-restored, AC line voltage, DC battery voltage and battery capacity ● Communications ports support timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment ● PowerAlert UPS monitoring and unattended shutdown software with complete cabling included ● Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically restarting them and rebooting completely locked computers by automatically switching UPS power off and back on again ● Notification of system status via 5 LEDs and multi-function audible alarms ● Wall mountable with UPSWM wallmount bracket ● Attractive small footprint beige tower housing uses less than 66 square inches ● Hot-swappable/user replaceable batteries allow on-site battery replacement ● Cold start capability enables UPS turn-on in battery mode during blackout conditions ● UL (USA), cUL (Canada), NOM (Mexico), Class A (Emissions) ● $250,000 Ultimate Lifetime Insurance (USA and Canada only) ● $250,000 connected equipment insurance (USA and Canada Only) Specifications OVERVIEW UPC Code 037332137678 INPUT Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 980 Power Factor 0.7 Frequency Compatibility 60 Hz 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles One switchable single-outlet 5-15R load bank Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15R BATTERY Runtime Full Load (min.) 7 min. (980w) Runtime Half Load (min.) 20 min. (490w) DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC53  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 229 Primary UPS Height (mm) 325 Primary UPS Width (mm) 191 Shipping Dimensions (hwd / in.) 18.25 x 12.00 x 13.75 Shipping Dimensions (hwd / cm) 46.36 x 30.48 x 34.92 Shipping Weight (lbs.) 42.60 Shipping Weight (kg) 19.32 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 32.51 x 19.05 x 22.86 UPS Power Module Dimensions (hwd, in.) 12.8 x 7.5 x 9 UPS Power Module Weight (kg) 17.42 UPS Power Module Weight (lbs.) 38.4 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 138.8 Battery Mode BTU / Hr. (Full Load) 454.4 AC Mode Efficiency Rating (100% Load) 96% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software Included Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface USB; DB9 Serial 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SM1500NAFTA 价格&库存
很抱歉,暂时无法提供与“SM1500NAFTA”相匹配的价格&库存,您可以联系我们找货
