1000 Eaton Boulevard
Cleveland, OH 44122
United States
Smart line interactive USB UPS System - NAFTA
assembled version of SMART550USB
MODEL NUMBER: SM550UNAFTA
Highlights
550VA line interactive tower
UPS
Maintains 120V nominal output
during brownout conditions
Workstation optimized features
include USB port, single line
TEL / DSL line surge
suppression and three surgeonly outlets
Input: NEMA 5-15P (120V 15A)
/ Output: 6 NEMA 5-15R (120V)
$200,000 Ultimate Lifetime
Insurance (USA, Puerto Rico
and Canada only)
Package Includes
Description
Tripp Lite's SM550UNAFTA line interactive UPS system offers voltage regulation, surge suppression and
long lasting battery support for personal computers, internetworking equipment and other sensitive
electronics. Internal UPS circuits support entry level PC systems for up to 30 minutes during power
failures so that connected equipment can be shutdown without data loss. Automatic Voltage Regulation
(AVR) circuits regulate brownouts as low as 89 volts back to usable levels without using battery power.
Offers complete desktop power protection in an attractive stealth black tower configuration. Includes 3
battery supported outlets for computer, monitor and one vital system peripheral, plus 3 additional surge
suppression-only outlets for printers and other system accessories not requiring battery support. USB port
enables optional unattended system shutdown without data loss in the case of extended power failure,
USB cable included. PowerAlert software available via free download from www.tripplite.eaton.com. Builtin single line RJ11 phone suppression jacks protect modem, fax machine, cordless phone or other
peripheral with a standard dialup/DSL phone connection. Built-in audible alarm and 4 front panel LEDs
indicate line power status, battery power status, battery low/replace status and overload status.
550VA/300 watt power handling ability supports entry-level PCs, network workstations, point-of-sale
equipment, small business phone systems, audio/video equipment and home theater systems. Offers 4
minutes battery runtime with a full load of 550VA/300 watts and 15 minutes with a half load of 275VA/150
watts. Supports battery replacement via built-in access panel. $200,000 connected equipment insurance
(USA and Canada Only).
Features
SM550UNAFTA line interactive UPS system offers voltage regulation and battery support, plus
complete AC and dialup/DSL modem line surge suppression
Supports entry level PC systems for up to 30 minutes during power failures to enable a safe system
shutdown
Supports a max load of 550VA/300 watts for 4 minutes and a half load of 275VA/150 watts for 15
minutes
Automatic Voltage Regulation (AVR) circuits correct brownouts as low as 89 volts without using battery
power
Attractive stealth black tower configuration
Includes 3 battery supported outlets, plus 3 additional surge suppression-only outlets, 6 foot AC line
cord (all NEMA 5-15)
USB port enables unattended shutdown without data loss during extended power failures, includes USB
cable
1/5
SM550UNAFTA UPS System
USB and Telephone
interconnection cables
Instruction manual with warranty
information
Cleveland, OH 44122
United States
PowerAlert software available via free download from tripplite.eaton.com
Built-in RJ11 phone suppression jacks protect modem, fax machine or other peripheral with a dialup or
DSL line phone connection
Built-in audible alarm and 4 front panel LEDs indicate UPS system and line power status
550VA/300 watt power handling ability supports a variety of computer, internetworking, telecom and
consumer electronics equipment
Compatible with 120V/60Hz applications for USA, Canada, Mexico and more
$200,000 connected equipment insurance (USA and Canada Only)
Specifications
OVERVIEW
UPC Code
037332137784
INPUT
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
550
Output Capacity (Watts)
300
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
115V (+/- 5%)
UPS Output Receptacles (Surge
Suppression Only)
3 UPS outlets, 3 surge-only outlets
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
115V; 120V
Output Receptacles
(6) 5-15R
BATTERY
Runtime Full Load (min.)
4 min. (300w)
Runtime Half Load (min.)
15 min. (150w)
2/5
Cleveland, OH 44122
United States
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 3.6 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 89
Undervoltage Correction
Input voltages between 89 and 104 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
4 LEDs indicate line power, battery power, overload and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out)
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
165
Primary UPS Height (mm)
216
Primary UPS Width (mm)
127
Shipping Dimensions (hwd / in.)
12.00 x 8.25 x 10.00
Shipping Dimensions (hwd / cm)
30.48 x 20.96 x 25.40
Shipping Weight (lbs.)
14.00
Shipping Weight (kg)
6.35
UPS Housing Material
PVC
3/5
Cleveland, OH 44122
United States
UPS Power Module Dimensions
(hwd, cm)
21.59 x 12.70 x 16.51
(hwd, in.)
8.5 x 5 x 6.5
UPS Power Module Weight (kg)
6.53
UPS Power Module Weight (lbs.)
14.4
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
65.1
Battery Mode BTU / Hr. (Full Load)
358.4
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
PowerAlert Software
Free download from https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
89
High Voltage Transfer to Battery
Power (Setpoint)
139
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
4/5
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SM550UNAFTA”相匹配的价格&库存,您可以联系我们找货
