1000 Eaton Boulevard
Cleveland, OH 44122
United States
120V 1000VA 800W A/V Pure Sine Wave UPS,
Extended Run, 2U Rack-Mount, USB, 6 Outlets
MODEL NUMBER: HTR10-2U
Highlights
1000VA on-line, doubleconversion, extended-run UPS;
rackmount hardware included
6 outlets; 2 switchable load
banks
IP remote access, control and
diagnostics capability with email
notification (built-in accessory
slot; SNMPWEBCARD available
separately)
Zero transfer time to battery
takes incoming AC power and
remakes it into perfect output
power with a pure sine wave
Maintains sine wave 100/110 or
120V +/-2% output during
overvoltages to 138 and
brownouts as low as 65V
(50/60Hz auto-sensing)
Pure Sine Wave operation
completely isolates connected
components from power
problems
Drivers written for Crestron,
AMX and Savant for seamless
integration
Description
Tripp Lite's HTR10-2U Pure Sine Wave 1000VA / 800 Watt on-line, double-conversion UPS system
prevents media data loss, equipment freeze-ups, downtime and equipment damage due to power
outages, voltage fluctuations and transient surges. Provides full-time sine wave 100, 110 or 120V +/-2%
output with zero transfer time between AC and battery operation. Actively converts raw incoming AC
power to DC, then re-converts output back to completely regulated, filtered AC output. Operates
Package Includes
HTR10-2U Audio/Video Pure
Sine Wave UPS System
PowerAlert Software and
cabling
Mounting hardware for 4-post
rack enclosures
Instruction manual with warranty
information
continuously without using battery power during brownouts to 65V and overvoltages to 138V. Networkgrade AC surge and EMI/RFI line noise suppression. Dataline surge suppression for a dial-up, DSL or
network Ethernet connection. Requires only 2 rack spaces (2U). Large internal batteries provide 18 min.
half-load runtime and 6 min. full load runtime; runtime is expandable with optional BP48V24-2U and
BP48V60RT-3U external battery packs. 1000VA/800W power handling capacity is compatible with
audio/video components and other sensitive electronic applications. Includes 6 UPS-supported outlets
arranged in two switchable load banks that can be individually controlled via software interface to reboot
selected equipment on demand or automatically shed less significant loads to extend battery runtime for
more critical equipment. Supports simultaneous communications via USB port, DB9 serial port and
SNMPWEBCARD slot for the ultimate in IP remote access, control and diagnostics capability with email
notification. HID-compliant USB interface enables integration with built-in power management and autoshutdown features of Windows, Mac OS X and Linux. Supports simultaneous detailed monitoring of
equipment load levels, self-test data and utility power conditions via all 3 network interfaces. Includes
PowerAlert monitoring software and complete cabling. Multi-function audible alarms and front-panel LEDs
provide at-a-glance notification of UPS and line power status. Attractive all-black color scheme. $250,000
Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only).
Features
HTR10-2U Pure Sine Wave UPS provides perfectly regulated sine wave output within 2% of 110/120V
(user selectable) under all usage conditions
1000VA/800W power handling capacity compatible with control systems, high-definition sources,
1/5
Cleveland, OH 44122
United States
Audio/Video editing suites, digital consoles, DVD/music/PCs/servers, RAIDs, media centers,
PVRs/DVRs, boardrooms, digital processors/EFX, racks and other sensitive electronics
Removes harmonic distortion, fast electrical impulses, frequency variations and other hard-to-solve
power problems not addressed by other UPS types
Corrects line voltage conditions as low as 65V and as high as 138V back to selectable 110/120V (+/2%) values
2 switchable load banks (2 outlets bank one/4 outlets bank two) enable remote outlet management for
load shedding or remote reboot of individual devices from anywhere in the world
Single-line tel/DSL/Ethernet surge suppression
Internal battery set offers 22 min. runtime at half load (400W) and 12 min. a at full load (800W)
Optional BP48V24-2U (limit 1) and BP48V60RT-3U (no limit) external battery pack increases runtime
Fault-tolerant auto-bypass maintains continuous utility output to connected equipment, even in cases
where the UPS suffers internal failure and requires maintenance
Compact rackmount form factor installs in 2 rack spaces (2U) with a maximum installed depth of only 19
in.
Offers simultaneous monitoring by up to 3 directly connected devices through included USB, DB9 and
SNMP* interfaces (*requires optional SNMPWEBCARD), or the monitoring of any number of additional
UPS systems over IP with included PowerAlert monitoring software
HID-compliant USB interface enables integration with built-in power management and auto shutdown
PowerAlert UPS monitoring and unattended shutdown software enables configurable network broadcast
messaging, pager and email notification, event logging and running user-defined script commands
Front panel LEDs offer current monitoring and battery charge level information
UPS ships fully assembled in full compliance with DOT regulations; no time-consuming connection of
internal batteries by user required
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332126009
UPS Type
On-Line
INPUT
Rated input current (Maximum Load)
8.6A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
Voltage Compatibility (VAC)
120
Input Phase
Single-Phase
OUTPUT
2/5
Cleveland, OH 44122
United States
Output Capacity (VA)
1000
Output Capacity (Watts)
800
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup
Output Voltage Regulation (Line
Mode)
+/- 2%
Load Management Receptacles
Two controllable single-outlet 5-15R load banks
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
100V; 110V; 120V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
Yes
BATTERY
Runtime Full Load (min.)
6 min. (800w)
Runtime Half Load (min.)
22 min. (400w)
Expandable Runtime
Yes
Expandable Runtime Description
Supports extended runtime with optional external battery pack BP48V24-2U (limit 1); BP48V60RT3U (multi-pack compatible)
External Battery Pack Compatibility
BP48V24-2U (limit 1); BP48V60RT-3U (multi-pack compatible)
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80%
Battery Access
Hot-swap battery replacement supported via front access panel
Internal UPS Replacement Battery
Cartridge
RBC94-2U
Typical Battery Lifespan
3-6 years, depending on usage
VOLTAGE REGULATION
Voltage Regulation Description
On-line, double-conversion power conditioning maintains output within 2% of 110/120 volts at all times
Overvoltage Correction
Maintains output of selected nominal +/-2% during overvoltages to 138V AC
Undervoltage Correction
2% output voltage regulation during undervoltages to 80
Severe Undervoltage Correction
Maintains output within 2% of nominal during undervoltages to 65 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
Includes power off/on switch to enable system turn on (press ON switch), UPS battery test (press ON switch during
normal AC operation), buzzer silence (press ON switch during battery operation) and OFF (press OFF switch) - all
switch functions require tha
3/5
Cleveland, OH 44122
United States
Audible Alarm
Multi-function audible alarm with distinctive ring patterns offer notification of backup operation (2 sec. on / 0.5 sec.
off), low battery warning (1.25 sec. on / 0.5 sec. off), overload (sounds continuously), UPS fault (4.2 sec. on / 1 sec.
off), input voltage out of frequency (2.1 sec. on / 0.14 sec. off) and high input voltage (2.1 sec. on 0.07 sec. off)
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
Dataline Suppression
Set of 8-wire RJ style interface jacks offer surge suppression for tel/DSL/Ethernet connections. Pins 1,2,3 and 6
offer Ethernet protection starting at 7.5V and the center two wires, pins 4 & 5, offer tel/DSL line suppression starting
at 260V
PHYSICAL
Primary Form Factor
Tower; Rackmount
Rack Height
2U
Cooling Method
Built-in cooling fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
483
Primary UPS Height (mm)
89
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
9.75 x 20.25 x 24.00
Shipping Dimensions (hwd / cm)
24.76 x 51.44 x 60.96
Shipping Weight (lbs.)
54.00
Shipping Weight (kg)
24.49
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
8.89 x 44.45 x 48.26
(hwd, in.)
3.5 x 17.5 x 19
UPS Power Module Weight (kg)
20.00
UPS Power Module Weight (lbs.)
44.1
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
406.4
4/5
Cleveland, OH 44122
United States
Battery Mode BTU / Hr. (Full Load)
442.8
COMMUNICATIONS
WatchDog Compatibility
Compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot
of application / OS or hard power off/on reboot of connected equipment—ideal for unattended applications
EPO Port
Supports Emergency Power Off function via dedicated built-in EPO jack
SNMP Compatibility
Slot for optional SNMPWEBCARD accessory (#SNMPWEBCARD)
Communications Interface
USB (HID enabled); DB9 Serial; Contact closure; EPO (emergency power off); Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
80V (100% load), 65V (
