AVRX550UD
AVRX550UD
    TRIPPLITE
    550VA UPS
AVRX550UD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States AVR Series 230V 550VA 300W Ultra-Compact Line-Interactive UPS with USB port, CEE7/7 Schuko Outlets MODEL NUMBER: AVRX550UD Highlights ● 550VA ultra-compact 230V line interactive UPS ● Corrects brownouts and overvoltages from 159V to 282V ● 4 UPS battery supported outlets, 4 surge-only outlets ● USB port, TEL/DSL protection, Wall mountable, 99% efficient ● CEE 7/7 Schuko input & output connections Package Includes Description Tripp Lite's AVRX550UD Ultra-Compact Line Interactive UPS offers complete power protection for desktop PCs, network workstations and a wide variety of professional and consumer electronic devices. Uninterruptible Power Supply / UPS circuits switch to battery backup mode within milliseconds to keep connected equipment running without interruption or data loss during power failures. Automatic Voltage Regulation / AVR power conditioning maintains smooth, continuous operation of connected equipment during brownouts and overvoltages. Surge-only outlets offer convenient protection for printers and other desktop accessories not requiring battery support. AC and dataline surge suppression prevents connected equipment damage. USB communications port supports built-in power management and auto-shutdown features of Windows and Mac OS X or full featured monitoring and data-saving auto-shutdown options using Tripp Lite's free PowerAlert monitoring software. Features ● AVRX550UD ultra-compact 230V line interactive UPS offers complete AC power protection from blackouts, brownouts and transient surges ● 550VA / 300 watt UPS output capacity ● Uninterruptible Power Supply / UPS operation maintains battery-derived AC output during blackouts to prevent data loss and system downtime for connected equipment ● Built-in USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● HID-compliant USB port also enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Automatic Voltage Regulation / AVR corrects extended brownouts and overvoltages from 159 to 282V, without using battery power ● 3 minutes runtime at 100% load (300 watts), 9.7 minutes runtime at 50% load (150 watts) ● 20 minutes runtime for a desktop computer system consuming 80 watts continuous ● 8 total CEE7/7 SCHUKO outlets ● 4 UPS battery backup outlets, plus 4 additional surge-only outlets ● CEE7/7 SCHUKO input connection with 1.8m line cord ● Network grade AC surge protection is available from all outlets 1/5 ● AVRX550UD UPS System ● USB Cable ● Quick start guide 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Built-in data line surge suppression protects a single dialup or DSL line ● 99% line mode efficiency rating uses less energy and BTU emissions ● Supports Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application/OS or hard power off/on reboot of connected equipment, ideal for unattended kiosk applications ● Hot swappable user battery replacement ● Space saving, ultra-compact housing with support for wall-mount, desktop or floor placement Specifications OVERVIEW UPC Code 037332156822 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type CEE 7/7 Schuko UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 OUTPUT Output Capacity (VA) 550 Output Capacity (kVA) 0.55 Output Capacity (Watts) 300 Output Capacity (kW) 0.3 Nominal Voltage Details 230V nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) +8%, -21% Output Voltage Regulation (Battery Mode) +/- 5% UPS Output Receptacles (Surge Suppression Only) 4 UPS outlets, 4 surge-only outlets Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (8) CEE7/7 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 3 min. (300W) Runtime Half Load (min.) 9.7 min. (150W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 15 hours from 10% to 90% Battery Access Battery access door Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 159 to 282VAC Overvoltage Correction Input voltages between 245 and 282 are reduced by 12% Undervoltage Correction Input voltages between 159 and 205 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches Combination switch controls on/off power status and self-test operation Audible Alarm Audible alarm indicates power-failure and overload status LED Indicators 2 LEDs indicate power status and overload/check battery status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 320 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out) EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 152 Primary UPS Height (mm) 120 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Width (mm) 279 Shipping Dimensions (hwd / in.) 7.30 x 14.20 x 9.53 Shipping Dimensions (hwd / cm) 18.54 x 36.07 x 24.21 Shipping Weight (lbs.) 12.30 Shipping Weight (kg) 5.58 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 12.01 x 27.94 x 15.24 UPS Power Module Dimensions (hwd, in.) 4.73 x 11 x 6 UPS Power Module Weight (kg) 5.22 UPS Power Module Weight (lbs.) 11.5 Unit Weight (lbs.) 11.5000 Unit Weight (kg) 5.22 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 16 AC Mode Efficiency Rating (100% Load) 99% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management not supported Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 5 milliseconds (line to battery mode) / 1 millisecond (battery to line mode) Low Voltage Transfer to Battery Power (Setpoint) 159 High Voltage Transfer to Battery Power (Setpoint) 282 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications IEC/EN 62040 Product Compliance RoHS; CE (Europe); FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
AVRX550UD
物料型号: - 型号编号:AVRX550UD
器件简介: - AVRX550UD是一款超紧凑型230V 550VA 300W的在线互动式UPS,带有USB端口和CEE7/7 Schuko插座。它为桌面电脑、网络工作站以及各种专业和消费类电子设备提供完整的电源保护。
引脚分配: - 8个CEE7/7插座,其中4个为UPS电池支持插座,另外4个为仅浪涌保护插座。
参数特性: - 输入电压:230V AC - 输出容量:550VA/300W - 频率兼容性:50/60 Hz自动选择 - 效率:99%在线模式效率 - 电池类型:阀控式铅酸电池(VRLA) - 运行时间:100%负载下3分钟,50%负载下9.7分钟 - 电池更换:支持热插拔,用户可更换电池
功能详解: - 提供不间断电源/UPS操作,在停电期间维持电池派生的交流输出,防止连接设备的数据丢失和系统停机。 - 内置USB端口支持使用PowerAlert软件实现数据保存的无人值守关闭。 - 自动电压调节/AVR功能在不使用电池电源的情况下校正从159V到282V的长时低电压和过电压。 - 提供对打印机和其他不需要电池支持的桌面附件的浪涌保护。
应用信息: - 适用于家庭/办公室桌面、音视频设备。
封装信息: - 主要外形尺寸:桌面型 - 安装形式:支持塔式、超紧凑型桌面和壁挂式安装 - 尺寸:152mm深 x 120mm高 x 279mm宽 - 重量:5.58kg
AVRX550UD 价格&库存
很抱歉,暂时无法提供与“AVRX550UD”相匹配的价格&库存,您可以联系我们找货
