SS7415-15
SS7415-15
    TRIPPLITE
    POWER STRIP 48" 16OUT RACK MOUNT
SS7415-15 数据手册
16-Outlet Industrial Surge Protector, 15 ft. (4.57 m) Cord, 1650 Joules, Metal Housing, 48 in. Length MODEL NUMBER: SS7415-15 Highlights ● 16 NEMA 5-15R outlets with 2.7 in. center-to-center spacing ● 1650-joule surge protection rating ● Filters out threatening EMI/RFI line noise ● 15-ft. (4.57 m) AC power cord with NEMA 5-15P plug ● Mounts horizontally or vertically on a variety of surfaces Package Includes Safeguard your valuable electronics against dangerous surges, spikes and line noise. Recommended for equipment racks, server rooms, workbenches, raceways and other commercial applications requiring AC line protection. Description Recommended for connecting multiple loads in commercial or retail environments, the SS7415-15 16Outlet Industrial Surge Protector features a surge protection rating of 1650 joules to defend your sensitive electronic components against strong surges and spikes. It filters out electromagnetic interference (EMI) and radio frequency interference (RFI) that can disrupt your electronics and inflict hardware damage or data loss. Your devices plug into 16 NEMA 5-15R outlets, which are spaced 2.7 inches apart center to center to reduce cable clutter and accommodate bulky transformers. An integrated 15A circuit breaker protects all outlets and shuts down connected equipment in case of overload. The lighted on/off switch with transparent safety cover provides one-touch control over connected equipment. A diagnostic LED confirms your connected equipment is protected. The long 15-ft. (4.57 m) AC power cord with NEMA 5-15P plug gives you flexibility to reach distant outlets while fitting easily into your setup. Adjustable clips are included for mounting the 48-inch all-metal housing horizontally or vertically on a variety of surfaces. Features 1650-Joule Surge Protection for Industrial Electronics ● Protects multiple loads against even the strongest surges and spikes in equipment racks, server rooms, workbenches, raceways and other commercial or retail environments ● Recommended for networks, telecom systems, audio/video systems and live sound applications requiring AC line protection ● Filters out disruptive EMI/RFI line noise that can cause equipment damage or data loss 16 Outlets Accept Wide Range of Electronic Devices ● 16 NEMA 5-15R AC outlets accept most computer, networking and telecom equipment ● Outlets are spaced 2.7 in. center to center to reduce cable clutter and accommodate bulky transformers 1/4 ● SS7415-15 16-Outlet Industrial Surge Protector, Metal Housing ● Adjustable mounting clips ● Owner’s manual Premium Safety Features ● Lighted on/off switch with transparent locking safety cover provides one-touch control over connected equipment ● Integrated 15A circuit breaker shuts down outlets in case of power overload ● Diagnostic LED confirms protection status at a glance ● Conforms to current UL 1449 3rd Edition safety standards Flexible Mounting Options ● Included clips allow mounting horizontally or vertically on a variety of surfaces ● Long 15-ft. (4.57 m) AC power cord with NEMA 5-15P plug reaches distant outlets ● All-metal 48 in. housing designed for long life Specifications OVERVIEW UPC Code 037332100290 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 22000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output (Watts) 1800 Output Receptacles (16) 5-15R Circuit Breaker (amps) 15 Right-Angle Outlets No Outlet Spacing 2.717-in. center-to-center spacing 2/4 USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and lighted 2-position power switch controls power to all outlets Locking Switch Cover Transparent locking switch cover SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 1650 UL1449 Let Through Rating 500V UL verified EMI / RFI Filtering Yes Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Power Cord Color Black Housing Color Silver Included Mounting Accessories Set of adjustable mounting clamps Mounting Holes or Slots No Outlets Measurement (Center to Center) 67mm Receptacle Color Black Shipping Dimensions (hwd / cm) 6.10 x 8.38 x 132.08 Shipping Dimensions (hwd / in.) 2.40 x 3.30 x 52.00 Shipping Weight (kg) 2.04 Shipping Weight (lbs.) 4.50 Unit Dimensions (hwd / in.) 48 x 1.5 x 1.5 Unit Dimensions (hwd / cm) 121.92 x 3.81 x 3.81 Unit Weight (lbs.) 2.89 Unit Weight (kg) 1.31 Outlet Spacing 2.717-in. center-to-center spacing FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No 3/4 STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
SS7415-15 价格&库存
很抱歉,暂时无法提供与“SS7415-15”相匹配的价格&库存,您可以联系我们找货
