1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power It! 6-Outlet Safety Power Strip, 9 ft. (2.74
m) Cord & Clip, Hang Holes, Safety Covers, GFCI
Plug
MODEL NUMBER: TLM609GF
Highlights
6 outlets (including transformer
outlets and 4 safety covers)
9-ft. (2.74 m) cord with GFCI
plug
Cord wrap with hang holes
Rugged metal case
Package Includes
Description
This Tripp Lite power strip is designed to safely distribute power to connected equipment in harsh
environments. It provides a convenient source for multiple outlets wherever they're needed. 6 outlets
distribute AC power to a wide range of power tools, drill presses, air compressors, power sanders and
more. Convenient transformer outlets accommodate multiple transformers without blocking other outlets.
A 9-ft. (2.74 m) grounded cord with integrated cord clip reaches distant outlets. A GFCI plug protects
users from electrical shock in wet or humid environments. A lighted on/off switch provides power control
over connected equipment. 4 safety covers shield unused outlets from debris and accidental contact. A
rugged metal case stands up to the harshest environments. Built-in cord wrap with hang holes provides
convenient cord management. Integrated keyhole slots on bottom panel provide convenient wall/desk
mounting. Its bright yellow color alerts you and others that power cords and tools are in use.
Features
6 outlets distribute AC power to a wide range of band saws, drill presses, air compressors, power
sanders and more.
A GFCI plug protects users from electrical shock in wet or humid environments.
A lighted on/off switch with integrated 15 amp circuit breaker provides power control and overload
protection over connected equipment.
A rugged metal case stands up to the harshest environments.
Built-in cord wrap with hang holes provides convenient cord management.
Integrated keyhole slots on bottom panel provide convenient wall/desk mounting.
OSHA color guidelines, outlined in Document 1910.145, alert users to hazardous situations, which may
cause minor or moderate injury. This Tripp Lite product complies with those guidelines.
Specifications
1/3
TLM609GF Safety Power Strip
4 safety covers
Owner's manual
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332140142
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
15A 120V
Input Cord Gauge Type
14 gauge; SJT
Voltage Compatibility (VAC)
120
Input Plug Type
NEMA 5-15P
Input Cord Length (ft.)
9
Right-Angle Plug
No
Input Cord Length (m)
2.74
Integrated Cord Clip
Yes
OUTPUT
Frequency Compatibility
60 Hz
Output Receptacles
(6) 5-15R
Circuit Breaker (amps)
15
Overload Protection
GFCI plug
Transformer Accommodation
(4) Yes
Outlet Orientation
Single row
Right-Angle Outlets
Yes
Outlet Safety Covers Detail
Includes 4 outlet safety covers
USER INTERFACE, ALERTS & CONTROLS
Switches
Combination AC circuit breaker and 2 position red illuminated on/off power switch
PHYSICAL
Color
Yellow; Black
Material of Construction
Metal
Power Cord Color
Yellow
Housing Color
Yellow; Black
Mounting Holes or Slots
Yes
Slot or Hole Mount Measurement
(Center to Center)
209.55mm
Outlets Measurement (Center to
Center)
Distance between standard outlets = 1.19 in.; Distance between standard outlets and transformer outlets = 1.77 in.
2/3
Cleveland, OH 44122
United States
Receptacle Color
Black
Shipping Dimensions (hwd / in.)
2.00 x 7.00 x 16.70
Shipping Dimensions (hwd / cm)
5.08 x 17.78 x 42.42
Shipping Weight (lbs.)
3.20
Shipping Weight (kg)
1.45
Unit Dimensions (hwd / in.)
15.970 x 3.070 x 1.610
Unit Dimensions (hwd / cm)
40.56 x 7.80 x 4.09
Unit Weight (lbs.)
3.24
Unit Weight (kg)
1.47
FEATURES & SPECIFICATIONS
Antimicrobial
No
Built-In Circuit Breaker
Yes
STANDARDS & COMPLIANCE
Product Certifications
cUL Listed; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“TLM609GF”相匹配的价格&库存,您可以联系我们找货
